sharp lc-49cug8052k
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    sharp lc-49cug8052k
    Hi guys anyone have a link for the latest software update for sharp lc-49cug8052k i have tried updating it in the tv menu says upto date but its from 2018 issue apps etc freeze and apps slow to respond freeview and same apps played through firestick/hdmi playback all work ok
    Edit have now done a factory reset tv still doing the same thing on apps the app freezes then after a while tv reboots and goes back too normal freeview tv channel. so guess it is a mainboard fault as davi.p suggested.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4450
    • Italy - Milan
    I strongly doubt is a software issue, bad BGA balls on RAM chips is most probably, for me..
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      The tv works fine when watching freeview tv so i will probably advise them to just use a firestick or streaming box via hdmi for the apps
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4450
        • Italy - Milan
        ok, freeview needs almost no ram, all decoding is hardware based, same for HDMI playback..
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          Thanks davi.p makes perfect sense
          • advant
            by advant
            02-03-2020, 12:25 AM
          • sefoster
            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
            by sefoster
            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
            11-20-2022, 09:29 AM
          • gavenb
            Sharp LC-80LE661U 80 inch
            by gavenb
            Hi folks!
            I have a LC-80LE661U that had some interesting issues.
            Initially, it would come on and show the sharp logo and would show normal static before shutting off.
            I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
            11-12-2023, 02:05 PM
          • SONY_E-WASTER
            Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
            by SONY_E-WASTER
            Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
            The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
            then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
            does...
            12-26-2021, 05:46 PM
          • Superbee_dad
            Sharp 80” long short flash backlight error - Help
            by Superbee_dad
            Hello Sharp TV experts
            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
            01-24-2025, 11:51 PM
