Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    I picked this one up today.
    Previous owner says no signs of life.
    TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
    Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
    The TV model is QN65LS03BAFXZA - version: CB06
    The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
    I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
    Will keep you all posted!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    Yeah, take that one connect box apart, remove the heatsink and reflow the 3 large IC's. My guess is that the fan isn’t spinning either at the moment.
    There are videos on YouTube on how it's done,
    • EazyBone
      • Jun 2023
      • 1360
      • United states
      Nice tear it open and let's see!
      • KYBOSH
        • Oct 2011
        • 581
        • Unknown
        Per your request! CapLeaker EazyBone
        Click image for larger version  Name:	Screenshot 2025-04-06 at 6.08.00 PM.png Views:	0 Size:	6.81 MB ID:	3609238
        Click image for larger version  Name:	2025-04-06 17.25.37.jpg Views:	0 Size:	1.62 MB ID:	3609239
        Two bad components.
        Fuse: 250V 3.15A
        Mosfset: MagnaChip 70R380P
        Question: I read that MagnaChip went out of business not too long ago.
        I see a few of these fets online for ordering BUT i have a few of these MagnaChip Mosfets in my collection.
        Namely 60R360P, 60R580QS, 60R360QS, 60R360Q, 70R600P and 80R450P.
        There is a video i came across explaining Mosfet replacements that I will look at tonight.
        Then I will have a look at the datasheets to see if I can substitute one of these for the blown one.
        Wait... These things have fans?
        I didnt even notice it!
        • EazyBone
          • Jun 2023
          • 1360
          • United states
          They sell these on AliExpress. Or old donor boards. I'm pretty sure mine blew with a blue cap also, might want to replace that. It is hidden under all that silicone
          • KYBOSH
            • Oct 2011
            • 581
            • Unknown
            Great Video! Seems like substituting MOSFETs are quite similar to substituting capacitors.
            I found that I have an Infineon 11N80C3 (TO-247) in my bin and I think this might just work for the application....
            Original MagnaChip MOSFET (70R380P) is:
            VDS = 750V
            RDS = 0.38Ω typ. / 0.38 max @ 10V, ID = 3.2A, 25°C
            ID = 11A @25°C
            Infineon is:
            VDS = 750V
            RDS = 0.38Ω typ / 0.45Ω max @ 10V, ID = 7.1A, 25°C
            ID = 11A @25°C
            Only issue (if it is an issue) is the bigger package of the TO-247 but I will have to see.
            And I may have to insulate it from the heatsink but I will have to take a look at the package.
            The MagnaChip 80R450P I have may also work as it well but it has a RDS 0.45Ω I dont know if this is too much but the video says the lower the better). Plus and drain leg might be too short (ripped off during removal).
            Any thoughts?
            • KYBOSH
              • Oct 2011
              • 581
              • Unknown
              Haha! Im re-reading your thread now and we are actually going down the exact same thought process (even asking about substituting 80R450P!) Pretty funny. Thanks for the tip about the blue cap. Would have missed that completely. WIll check it when I get back to the bench.
              • EazyBone
                • Jun 2023
                • 1360
                • United states
                I think it'd be wise to replace it anyways but that's only based on watching nicktv videos and seeing them explode.
                https://a.aliexpress.com/_mL0mlKF
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8340
                  Aah! PSU… I thought is was that damn unobtainable one connect box that’s broken.
                  I used TO247 MOSFETs to replace blown TO220 MOSFETs before. Works fine, you just have to fiddle around with the legs and maybe drill a new hole into the heatsink or put in a different heatsink altogether.
                  • KYBOSH
                    • Oct 2011
                    • 581
                    • Unknown
                    You are right... but...where is the fun in that???
                    I tossed in the 80R450P to see if i can get signs if life but still nothing.
                    My ceramic cap seems to be okay too.
                    I thought of eaarnoudse's post about the blown resistor and dodgy IC.
                    Sure enough the 2R20 cap was gone. Replaced that but still no signs of life so its likely the SSC3S211 which i would not have a spare of ... unless I check some Samsung part boards.
                    If I dont I'll order it from Ali-E along with the proper 70R380P replacement MOSFET.
                    Aah! PSU… I thought is was that damn unobtainable one connect box that's broken.
                    So very tempted! The TO247 is pretty big though and I woud have to tap a new hole in the heatsink to secure it. The 80R450P will do the trick for now.
                    • EazyBone
                      • Jun 2023
                      • 1360
                      • United states
                      I might have an extra ic actually. Where you located? Us?
                      • EazyBone
                        • Jun 2023
                        • 1360
                        • United states
                        What videos you talking about also? Can you show a link
                        • KYBOSH
                          • Oct 2011
                          • 581
                          • Unknown
                          Atlanta GA. I'll PM you. Thanks!
                          • EazyBone
                            • Jun 2023
                            • 1360
                            • United states
                            In the mail, we close so should be like 2-3 day
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8340
                              Here ya go EazyB!
                              https://www.youtube.com/watch?v=HKRJDb2S2_U
                              • KYBOSH
                                • Oct 2011
                                • 581
                                • Unknown
                                Look at what EazyBone sent me today! Click image for larger version
                                • EazyBone
                                  • Jun 2023
                                  • 1360
                                  • United states
                                  Now let's see the hack job and if it works.
                                  Also my tariff is at 400%
                                  • KYBOSH
                                    • Oct 2011
                                    • 581
                                    • Unknown
                                    It powered on with no issues!
                                    i plugged it up without the One Connect cable/TV attached and it drew 2.0w for a second, then 1.0w for a second, then 0.5w for a second, then it went to 0w and stayed there. I then connected the cabel/TV and it came alive. Drawing 57w in low power picture frame mode and 177w in full TV mode.
                                    The 3S211, 70R380P and 2.2ohm resistor did the trick.
                                    PRO TIP! The 3S211 seems to be held on with 2 dabs of adhesive which makes it hard(er) to remove under hot air. If you are not careful you run the risk of scorching the board around/under it bcos you are still heating it up waiting for the IC to come off. Luckily i tinned the legs which made things 10x easier and used a tweaser to pull the IC off. I imagine this thing gets hot and they didnt want it to move if the solder started flow little by little over time. It is hanging upside down after all.
                                    Also it dawned on my later that CapLeaker's comment about a fan was a joke (there is no fan in these units) but it inspired me so i ordered a couple 25mm 12v brushless cooling fans from Ali-E. I will put one in the OCB to blow directly on this area where the MOSFET is. But i will tap into a 5v rail (usb?) so the fan will run quiter at half speed. This along with a generous amount of thermal paste/pads should keep this thing nice and cool.
                                    • EazyBone
                                      • Jun 2023
                                      • 1360
                                      • United states
                                      Haha very nice. Yes tin on each leg is always a must before heat gun. Hell tin on everything before heat gun is almost a must, they use lead free solder and we all know that just isn't good
                                      Still surprises me that these expensive ass frame tvs are edgelit.
                                      Did you throw in that mosfet too?
                                      • KYBOSH
                                        • Oct 2011
                                        • 581
                                        • Unknown
                                        yes i absolutely did. Didnt want to be inconsiderate to your kindness by using an out of spec component wheb there was no need. Maybe one day if i have a burner OCB i will experiment with that alternative.
                                        i think edge-lit is the only way you can get these TVs this slim unless you go OLED but then im not familiar with those or if you can have all the electronics in a remote OCB like you can with these.
                                        anyway im pretty happy to have learned a thing or two with this nice little fix!
                                        I owe you one Sir.
                                        thanks again!
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • EazyBone
                                          Samsung The Frame TV no power indicator issues diagnosing the one connect box
                                          by EazyBone
                                          I got a qn65ls03ta from someone who stated shows no power at all. They said they bought a fully new tv (same one) and tested the one connect box from the old one onto the new one and said it worked.
                                          I have no reason not to believe them, so I crack open the TV and test for voltages on the main board. There are none. I can't get any voltage at all. (Power comes from one connect to Main board then sends power to additional power board for backlights I believe)
                                          While doing some digging I found the connection to the one connect cable ON the main board seems to be missing small...
                                          07-28-2024, 04:46 PM
                                        • KYBOSH
                                          Trying to Save - Samsung UN40MU6300 - No Signs of Life
                                          by KYBOSH
                                          Picked this one up today.
                                          No signs of life whatsoever. No red led light from the IR module.
                                          Disconnected the mainboard to see if PSU was working and it was (LED backlights lit up).
                                          Checked the power button for continuity when buttons were pressed and I got readings.
                                          Disconnected various components (speaker, wifi module) with no difference.
                                          Checked mainboard's fuses (found 3) and they were all good.
                                          I looked on shopjimmy to see what components I may have been missing and I saw that they were selling EEPROMs.
                                          Then it dawned...
                                          10-12-2024, 11:20 PM
                                        • Kemer
                                          Graphics Card mounting frame
                                          by Kemer
                                          Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                                          As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                                          I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                                          What worries me right now is the possibility that...
                                          09-14-2024, 08:57 AM
                                        • araxnido
                                          Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                                          by araxnido
                                          Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                                          When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                                          06-10-2025, 09:26 PM
