Samsung UN40ES6100, Power supply issue
  • crabn
    • Oct 2016
    • 29
    Re: Samsung UN40ES6100, Power supply issue
    Originally posted by budm
    OK, I traced out the function of that diode DQ951 & resistor RQ951 parallel connection, they are for the power supply for the LED driver circuit negative return of the bridge rectifier DIODE DM851~854, so instead of having the negative of the power supply connected directly to the cold side circuit ground, it goes to GND through that diode/resistor parallel connection so the Vdrops on that resistor (it is basically monitoring the current draw in the LED power supply section) is being used to feed pin 5 of the LED driver IC9101.
    So on the old board what resistance (off the board) do you have for that diode?
    What DCV do you have between the two legs of the main filter cap CP814S? It should be around 380~400VDC range and steady. You can run the power supply board by itself to check the Voltages.
    The guy at (https://www.badcaps.net/forum/showthread.php?t=42434) claimed that the flickering backlight is due to bad IC9101. How do I test it?
    • CapLeaker
      Leaking Member
      • 8326
      Originally posted by crabn
      It is stable at 0V if I did not press "Turn on" button on the remote. No click sound yet
      It is between 0-3.2V when I pressed "Turn on" button on the remote. There is click sound now
      Re read my last post, that isn't what I had asked for.
      • crabn
        • Oct 2016
        • 29
        What I did is:
        Case 1: (1) Everything unplugged, (2) Plug in mainboard, (3) Plug in power cord, (4) Measured Voltage = 0
        Case 2: (1) Everything unplugged, (2) Plug in mainboard, (3) Plug in power cord, (4) Turn it on using remote, (5) Measured voltage = 0-3.2V
        Is something wrong?
        • CapLeaker
          Leaking Member
          • 8326
          Yes. I asked you to unplug it all, the main board, back lights, everything. Then plug the PSU into mains and see if the A5V rail (pin12) is stable.
            Right now we need to find out if the A5V is stable or not when running the power supply board by ITSELF (NOTHING connected to the board except the power cord).
            if the A5V is not stable, nothing will be stable either.
            • crabn
              • Oct 2016
              • 29
              A5V is not stable. It is bouncing between 0.002-5.2V. There is clicking sound. All cable unplugged
              • crabn
                • Oct 2016
                • 29
                Budm: Do you have any comment on this?
                  Well, I will have to spend time looking in the 5VSTBY section and trace out the circuits. My be bad startup cap, bad diode in the cold side of the 5VSTBY supply, etc...
                  • crabn
                    • Oct 2016
                    • 29
                    Thank you, Budm. I am looking forward to hearing from you soon.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      #30
                      In meantime you might be looking for bad solder connections. Resolder anything looks suspicious
                      • crabn
                        • Oct 2016
                        • 29
                        Sure. I will do
                        • crabn
                          • Oct 2016
                          • 29
                          Hi Everyone,
                          I got a non-working Samsung TV UN40ES6100. It does not have any power including standby light.
                          There is several with power supply:
                          1) Fuse nearby AC inlet blown
                          2) Diode DQ851 shorted
                          3) One of the MOSFETs (Part No: 13NM60N) cracked
                          Then I got a replacement working power supply. It was working fine for a few hours. I tried to turn it on next day. It won't turn on any more. There is standby light. Here are some measurements:
                          1) Voltage at Fuse: 50 V AC
                          2) Voltage at C9110 and C9111: not stable 191V
                          3) Diode DQ851 got shorted again
                          4) Unplug cable from PSU to mainboard: backlight keeps flashing on and off.
                          My question is what cause the DQ851 being shorted?
                          Any other comments are welcome.
                          Thanks.
                          I checked the board and found no bad soldering.
                          So I went back to the old board and replaced shorted fuse and cracked MOSFET (Part No: 13NM60N). It is working now. Except wifi does not work, hardwire is working.
                          My question is how to test the MOSFET mentioned above? I would want to check if this MOSFET on new board is working or not.
                          Thanks.
                            That MOSFET is for the PFC Voltage booster, common failure mode for that one is shorts and it will cause the main fuse to blow.
                            I just do not have the time to trace out the standby power supply section yet, it is not easy, very time consuming.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4458
                              • Italy - Milan
                              #34
                              "I went back to the old board and replaced shorted fuse and cracked MOSFET (Part No: 13NM60N). It is working now"
                              If you learn to spend a little time searching for faults on boards, you don't have to mess with used boards, remember i read many threads on forums and that there are many situation when the user, not so expert, go to sell boards without be able to test them, and in critical situation, so if you buy from a unknown or a private do many question before buy. I would return the psu back and fuck off further inspections..
                              bye.
                              • Zaman Kay
                                • Dec 2021
                                • 4
                                • Malaysia
                                #35
                                Hi. It is posible to replace DQ851 to diode sr2100? I cant find sr210 in my place.
                                • R_J
                                  • 9588
                                  What is wrong with D851? If it checks shorted in circuit, that is normal, remove one end to check it out of circuit.
                                  Are you sure about the original number? sr210 is a surface mount diode DQ851 is a axil lead diode.
                                  • Zaman Kay
                                    • Dec 2021
                                    • 4
                                    • Malaysia
                                    #37
                                    I check it out of circuit by remove both end. Its shorted. But i've lost it. Drop itsomewhere. Dq851 is label on pcb where the diode locate. And sr210 is written on the diode.
                                    • Cookybaby
                                      Samsung UN60ES6500FXZA Power Supply Issue
                                      by Cookybaby
                                      Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                      I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                      Make: Samsung
                                      Model: UN60ES6500FXZA
                                      Power Supply P/N: BN44-00525A
                                      Symptoms: The TV was...
                                      08-20-2023, 12:26 PM
                                    • lp20th
                                      Samsung Plasma TV Power Supply Issue
                                      by lp20th
                                      I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                      11-28-2023, 10:28 AM
                                    • Kjell
                                      Samsung Series 9 - BIOS issue
                                      by Kjell
                                      After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                      Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                      08-01-2025, 09:15 AM
                                    • captainKKK
                                      Samsung Bn4400612b Power Supply issue on Samsung UN50F6300
                                      by captainKKK
                                      Samsung Bn4400612b Power Supply issue takes out a new 5A fuse on my Samsung UN50F6300, without any the BL or main board cables connected. Please advise if this board has known issues and fixes. There are no evident fried components and the caps look ok. Nothing unusal on the bottom side of the board under magnification. Is the ICM801CS under that heat sink a known issue? SJ (https://www.shopjimmy.com/samsung-bn...-1473373576096) out of stock, so component level repair may be my best shot. Thanks.
                                      02-17-2022, 08:59 PM
                                      09-07-2024, 05:50 AM
