Samsung Series 9 - BIOS issue
  • Kjell
    • Jul 2025
    • Netherlands
    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically disconnecting the CMOS battery and using "SFlash64 /cvar /patch".
    Since none of those things solved it, i wanted to try updating/reflashing the BIOS. However, since the laptop is already running the latest BIOS version, the "Samsung BIOS Update" tool simply exits. And when trying to flash the BIOS using SFlash64 i got the following message:
    Code:
    Samsung-Phoenix SCT Flash for Windows V1.3.25.13-1.2, Build 120901
    Copyright (c) 2011-2012 Phoenix Technologies Ltd.
    SecureFlash BIOS detected.
    Read BIOS image from file.
    Initialize Flash module.
    Read current BIOS.
    WARNING:
    Rollback flash is disabled in BIOS, build date time check was not skipped.
    ERROR 182 - BIOS image is equal or older than ROM!
    Any help in solving this issue would be much appreciated!
  • ProSis
    Monster Huma H5 V3.1 - No Display / No Boot Issue After Bios Flash
    by ProSis
    I am having a "no display" (black screen) issue with my Monster Huma H5 V3.1 laptop.
    The device does not start or boot at all using the BIOS file provided by the official service. I have already backed up my original BIOS dump and also have the service file on hand. I tried to flash and fix it myself but was not successful.
    Could anyone help me patch, clean the ME region, or fix this BIOS issue to get the device working again? I have attached both my original backup (dump) and the official service BIOS file.
    Thank you in advance!
    Model...
    10-15-2026, 03:55 AM
  • abhorsen
    Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
    by abhorsen
    Hey guys,
    Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
    Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
    Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
    07-06-2023, 10:22 AM
  • bad0menz
    HP Omen 16-wdxxxx Bricked After Successful(?) BIOS Flash
    by bad0menz
    I wanted to remove the BIOS password on my Omen 16, so I used a ch314a to flash a modified BIOS file. Based on readings, the chip seems to have been programmed correctly, however the computer won't POST or boot—no fan, and either the power button blinks 1 long 1 short, or the capslock blinks once before shutting off.
    There shouldn't be any shorts or physical damage from what I can tell
    This Omen probably has HP SureStart Gen4, a firmware-level security feature embedded in the BIOS, however I've been told that "just by flashing to the dedicated flash there should...
    04-26-2026, 01:02 PM
  • cr4zychriss
    by cr4zychriss
    • Rebrand: PC Specialist
    11-14-2025, 04:04 PM
  • JayZee
    Samsung Odyssey G9 C49G95TSSR / BN94-17725A – full SPI flash dump needed (M-T9549GGAA / T9549)
    by JayZee
    I am trying to repair a Samsung Odyssey G9 49" monitor and I suspect corrupted firmware / NVM data or a bad SPI flash.
    Monitor details:
    Model: Samsung Odyssey G9
    Model: C49G95TSSR
    Model code: LC49G95TSSRXEN
    Type No.: C49G95TSS
    Version No.: CA02
    Mainboard: BN94-17725A
    PCB: BN41-02843B
    Firmware/platform marking: M-T9549GGAA-1017.0
    Official Samsung USB update available: M-T9549GGAA-1020.0
    Scaler/platform: Novatek NT68500 / T9549
    SPI flash: Winbond 25Q40CLSIP (if it is the right chip)...
    05-15-2026, 04:16 AM
