Vizio E500i-B1
  • jhrsmail
    • Jan 2017
    • 36
    Re: Vizio E500i-B1
    Originally posted by Agent24
    That sounds far too low. There must be something wrong for it to be 9 volts less than it should be!
    That's what I think as well.. but, after changing 9301, it's been on for a day. No problems
    • capwizard
      • Jun 2016
      • 1991
      Re: Vizio E500i-B1
      Dear jhrsmail: You woke up early today............Don't forget your promise.......................
      jhrsmail: " Haha..( ) to u if this fixes this stupid tv!!! " ...............post #39
      • Agent24
        I see dead caps
        • Oct 2007
        • 5035
        • New Zealand
        #63
        Re: Vizio E500i-B1
        If the supply voltage to the chip is too low, it may have to work harder to do its job and keep the output voltage up. In this case the IC may fail soon again. In fact, that might be the reason why it failed already.
        You should definitely investigate why the voltage supply is low. It may be a capacitor somewhere in the associated circuitry for that IC which has lost capacity or gone high ESR.
        -David VanHorn
        • capwizard
          • Jun 2016
          • 1991
          Re: Vizio E500i-B1
          "I still have 15.3 on the 24v legs" is that the 16v? Do you have a wrong voltage measurement?
          The STBY PS (5v) uses IC9301 (STR A6069H), the power supply uses IC9101 (LCS703LG) generates 24v to motherboard which bucked to 16v to drive 16 strips, each has 6 LEDs, total 96 LEDs.
          • jhrsmail
            • Jan 2017
            • 36
            Re: Vizio E500i-B1
            As of now it's working. When i get a chance I'll take it apart again...
            • capwizard
              • Jun 2016
              • 1991
              Re: Vizio E500i-B1
              If TV works and picture is good, you do not need to do that it might damage the TV. JUST Enjoy It!
              • jhrsmail
                • Jan 2017
                • 36
                Re: Vizio E500i-B1
                Will do, thx Wizard! Seems IC9301 has fixed it. 2 days, no failure..
                • jhrsmail
                  • Jan 2017
                  • 36
                  Re: Vizio E500i-B1
                  Ok, TV wouldn't power on today. So. Back to troubleshooting. You are saying if I only have 15.3v on 24v leg, it's ic9101 ...again??
                  • capwizard
                    • Jun 2016
                    • 1991
                    Re: Vizio E500i-B1
                    If it has 5v but wouldn't turn on the problem is the Ic9101 If it has 24v but wouldn't turn on the problem is in the screens LEDs.
                    • jhrsmail
                      • Jan 2017
                      • 36
                      Re: Vizio E500i-B1
                      Hey CAPWIZARD.. basically , it's doing what it's always done.. it will power up if unplugged for a while. I think ic9301 fixed it for a while, but finally ic9301 went bad again. I think I need to fix why 24v leg is only at 15.3v.. any ideas?? 😁
                      • CapLeaker
                        Leaking Member
                        • 8325
                        Re: Vizio E500i-B1
                        If the main board is that one that has the LED driver on it, I'd be looking at it. There was a thread around here somewhere on a Vizio having that only 15V on the 24V rail, no back light problem.
                        • capwizard
                          • Jun 2016
                          • 1991
                          Re: Vizio E500i-B1
                          Update; The TV has been working for 2 months so far so good.
                          Actualizar; La televisión ha estado trabajando durante 2 meses hasta ahora tan bueno.
                          • jhrsmail
                            • Jan 2017
                            • 36
                            Re: Vizio E500i-B1
                            What all did u do to it? Just ic9301?
                            • capwizard
                              • Jun 2016
                              • 1991
                              Re: Vizio E500i-B1
                              Sometimes it happens, sometimes it doesn't. Finally, I did fix it by first change IC9301 then IC9101. Estoy muy feliz ahora.......
                              • cascio93
                                • Aug 2017
                                • 5
                                Re: Vizio E500i-B1
                                Hey Looking for a little bit of help. I am working on fixing my PCB. I have identified my problem as the IC 9301, but there are a couple of resistors near this IC on the back of the board that also fried. They are the two resistors that are tied to pin 1 of IC9301. Unfortunately I haven't been able to find a schematic or even a picture of the back of the board that would show me what value of resistor i need to get to repair it. Does Someone have this info?
                                • Gbars
                                  • Mar 2018
                                  Re: Vizio E500i-B1
                                  Hi guys, I also need values of the resistor at pin 1 of ic9301 (R9311) please help.
                                  • travis7s
                                    • Jun 2018
                                    Re: Vizio E500i-B1
                                    Also looking for resistors for R9311 and R9312 on my ADTVD3613XA7 board for Vizio m502i-b1. They measure around 48ohms as is right now. A trace to IC9301 also blew up as you can see.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #78
                                      Re: Vizio E500i-B1
                                      They both look like 1R2 ohms
                                      Courtesy of Shopjimmy
                                        Re: Vizio E500i-B1
                                        Oops, disregard.
                                        • nunoit
                                          • Jul 2011
                                          • 10
                                          • grand old USA
                                          #80
                                          Re: Vizio E500i-B1
                                          does anybody have a full set of schematics for this unit. i have replaced some parts and still no 5v or 24 v
                                          Vizio E500i-B1
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • mecha1166
                                            Anyone here fix a tv and customer cracks panel when they get it home?
                                            by mecha1166
                                            About 2 times a year, a customer will do this. We fix the tv, put it on test play, and customer sees it working. They see me pull power and video wire. Sometimes I pick up tv, right in front of them, and carry it out to their vehicle while they are next to me. I set it in their tv gently, and tell them the tv is very fragile, be careful with it. I let them close the door/trunk. That day, or a few days later, they tell me there is a crack inside the tv. Normally I tell them transportation is their responsibility and normally that is the end of it. Has anyone had a customer that was not buying this...
                                            03-29-2024, 11:27 AM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
