Vizio E500i-B1
  • nunoit
    • Jul 2011
    • 10
    • grand old USA
    #81
    Re: Vizio E500i-B1
    update 5 v stand by returned 12/24 v goes to 10v then drops no back lights yet
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      Re: Vizio E500i-B1
      How much voltage are you getting on the main filter cap? Be careful... There are very high voltages there.
      • nunoit
        • Jul 2011
        • 10
        • grand old USA
        #83
        Re: Vizio E500i-B1
        thanks for the reply i have been reading the forums. this is what i have found so far.
        off primary caps (68 uf), add power rises to 398 then drops to 171.6. power with remote jumps to 398 rock steady. power down by remote drops slowly to 171.6.
        history; tv would randomly shut down. i have replaced a few parts already.
        IC's 9101, 9301, 9303,9801
        replaced R's 9111,9112,9103.
        IC 9103 tested like transistor.
        ZD9101 tests like regular diode.
        tested D9802 Q9801 all smd diodes and transitors. all test good also have removed and tested several caps all good.
        terminals
        5v | 5v
        na | na
        1.3|1.3
        1.2|1.2
        GN|GN
        GN|GN
        2.9|na
        1.6|3.2
        i was looking at the 12v loop back circuit and ic 9103 ,and 9102 play an important roll.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          Re: Vizio E500i-B1
          Usually no 24v means the PFC isn’t working. But you measured 400v so that isn’t it. If your 24v only does 10v, there must be something wrong somewhere.
          • nunoit
            • Jul 2011
            • 10
            • grand old USA
            #85
            Re: Vizio E500i-B1
            yesterday i was checking the 12/24v circuit turn on comes from pin #7 through R9301 to Q9102 then through (opto) IC9104 to Q9101 a couple of jumpers to (J9301,9302) to pin 1 of IC9101 (LC703LG) thats as far as i got.
            now i see that ZD9101works with Q9101 i need to find what value that diode isto test under load. but i see that IC9101 trys to turn on (10v) then stops it could be the feed back loop that keeps it running at fault.
            parts for feed back loop are opto and IC 9103
            • nunoit
              • Jul 2011
              • 10
              • grand old USA
              #86
              Re: Vizio E500i-B1
              ok checked voltage to IC9101, feeds are correct, i did not check power to transformer it would only be relevent if it was working correctly.
              pin 1 13v dc
              pin 16 398 dc
              opto load side both pins 1.2 and 1.3 v odd shouldent one side be grounded its the led side.
              i think i found the issue. on IC9103 between R and A leads theres a 10k resistor (R9122) that only measures only 8k on board and that has direct control of the GND of IC 9102 opto.
              • nunoit
                • Jul 2011
                • 10
                • grand old USA
                #87
                Re: Vizio E500i-B1
                well i have tested just about every component in the 12/24 v circuit and i still dont find the problem the only device i havent changed is the adjustable zener IC IC9103 that resistor R9122 is ok (99990)
                i changed the opto IC 9102, i pulled and tested all 4 dobble dodes. all diodes test good
                still scratching my coconut on this one.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8352
                  Re: Vizio E500i-B1
                  Faulty resistors go 99.9% higher in resistance or open. However there is a 0.1% chance it shorts out. So the 8 k you measured was something else. If you take the resistor out, it will be 10k all right.
                  • nunoit
                    • Jul 2011
                    • 10
                    • grand old USA
                    #89
                    Re: Vizio E500i-B1
                    i did check and it read 9999 ohms i am going to replace the IC 9103 if that fails then its might be a chip cap i hope not to test need to pull but first need schematic of the circuit to know what goes where.
                    • nunoit
                      • Jul 2011
                      • 10
                      • grand old USA
                      #90
                      Re: Vizio E500i-B1
                      i ordered new ones yesterday i should get them i a few days then ill bench test again and see from there how it goes.
                      i'm still concerned with original problem which was would randomly shut down and some times not at at all.
                      • nunoit
                        • Jul 2011
                        • 10
                        • grand old USA
                        #91
                        Re: Vizio E500i-B1
                        replaced IC 9103 still same thing testing smd resistors in the circuit.
                        for some strange reason ic 9101 trys to start up then goes into shut down mode its got to be in the r/c network.
                        i already suspect r9111 (154) reads 69.1k all others so far read good.
                        going to see if i have another lying around and just change it.
                        • nunoit
                          • Jul 2011
                          • 10
                          • grand old USA
                          #92
                          Re: Vizio E500i-B1
                          well i found the problem it seems the IC9101 (LCS703LG) one i purchased was bad i replaced it with the old one and now tv is back to working again. now i am testing to make sure the the orignal problem is gone which was tv would randomly shut down.
                          up date went in to check tv and it was off. with remote i powered back up an checked menu found auto off was set to 10 minutes, i reset to 0 min. testing again.
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • SS454
                            vizio e650i-a2 backlight flashes then turns off
                            by SS454
                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                            panel: au optronics T650HVN05.4
                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                            08-20-2020, 03:57 PM
                          • mrtek
                            Vizio M65-C1
                            by mrtek
                            Hi.
                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                            07-14-2025, 07:28 PM
                          • mecha1166
                            Anyone here fix a tv and customer cracks panel when they get it home?
                            by mecha1166
                            About 2 times a year, a customer will do this. We fix the tv, put it on test play, and customer sees it working. They see me pull power and video wire. Sometimes I pick up tv, right in front of them, and carry it out to their vehicle while they are next to me. I set it in their tv gently, and tell them the tv is very fragile, be careful with it. I let them close the door/trunk. That day, or a few days later, they tell me there is a crack inside the tv. Normally I tell them transportation is their responsibility and normally that is the end of it. Has anyone had a customer that was not buying this...
                            03-29-2024, 11:27 AM
                          • howardc64
                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                            by howardc64
                            Failure Symptom
                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                            Where is the short?
                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                            05-27-2025, 02:56 PM
