Mouser Shipping Charges...
  • mmartell
    • Oct 2013
    • 3189
    Can someone in the US do me a favour ? Add a small component to your cart and tell me what the cheapest shipping option is ?
  • TVRepairNoobie
    • Feb 2015
    • 158
    Re: Mouser Shipping Charges...
    Hth
    • mmartell
      • Oct 2013
      • 3189
      Damn, I KNEW is was getting boosted ! Here is mine.
      • JeffJ
        • Apr 2012
        • 189
        Order from digikey its 8 bux flat rate in canada last time i ordered and it showed up next day from the western warehouse.
        • R_J
          • 9557
          Yes Digi-key is the best way (next day usually), but if they don't have the part and you need, and you have to use Mouser, choose usps if you can wait about 10 days.
          I ordered some parts on 05 - Dec -2014 and they arrived on 15 - Dec - 2014
          • mmartell
            • Oct 2013
            • 3189
            Except for some geo reason perhaps I don't have the usps option in my shipping options. Essentially that was the reason for my initial post.
            I was told I could specify usps priority by adding it in "Shipping Instructions" for $6.99 but that doesn't explain why I don't have the $4.95 option available for continental us shipping ?!
            And 10 days in preferable when the other option is China.
            • retiredcaps
              • Apr 2010
              • 9271
              Are you using mouser.com (USA) or http://ca.mouser.com/ (Canada)? It might make a difference in shipping options?
              --- begin sig file ---
              --- end sig file ---
              • mmartell
                • Oct 2013
                • 3189
                The us site, I rarely use the Canadian equivalent site for anything.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Just tried mouser.com (USA) and shipping to Canada is $8 USD with USPS Priority for a single PTC. Same price, but 10 day delivery?
                  • mmartell
                    • Oct 2013
                    • 3189
                    Try it for yourself and see if you can get a screenie like in post two or if you get mine in post 3. Btw on .ca mouser my cheapest shipping option for $0.02 resistor is $20 which just poisons me from even looking at Canadian equivalent sites.
                    • mmartell
                      • Oct 2013
                      • 3189
                      The thing is I'm shipping within the us the same as any us resident would I can't understand why the options are different.
                      • CapLeaker
                        Leaking Member
                        • 8220
                        because everything has to be more expensive in Canada.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Solved this Mouser problem by using Digikey - $3.54 to Detroit (under 8oz) in 2-3 days. Now that's more than fair.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            How do you get it from there?
                            No to long ago, it was $2.72.
                            • mmartell
                              • Oct 2013
                              • 3189
                              My wife works in the D but we live just to the south in Canada.
                              Did your rates go up too ? I figured it was calculated based on distance but maybe it's a flat rate.
                              • Darren Hibbert
                                Lenovo Y50-70 only charges when turned off.
                                by Darren Hibbert
                                I have a Y50-70 gaming laptop. It has a problem where it charges up fine when the laptop is off, but when it's on, it doesn't.
                                I've tried a new 135w charger + new Lenovo battery and a new charging port but it made no difference.
                                I've updated all the drivers and still no difference.
                                Could it be down to a dodgy chip? I'll see if i can find a schematic and someone on here might be able to direct me where to test
                                Many thanks in advance....
                                08-09-2025, 11:15 AM
                              • reessi
                                HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
                                by reessi
                                I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
                                It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
                                What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
                                I have checked these lines in diode mode and they seam normal -> 600.
                                I have checked to see if they come on for even a fraction of a second...
                                07-15-2025, 09:14 AM
                              • bykanovm
                                Thinkpad W541 Works from the mains and charges the battery only when it is turned off
                                by bykanovm
                                Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
                                If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
                                If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
                                even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
                                Also, the laptop does not turn on without...
                                04-02-2025, 02:45 AM
                              • Cory Marqusee
                                MacBook Air 820-3209-A Missing (3) AGX 22uF Decoupling Capacitors
                                by Cory Marqusee
                                Hi Everyone,
                                I have a MacBook Air I've repaired, a mid-2012 13-inch 820-3209-A. It works. My only concern is that it is still missing (3) 22uF (0402 4V 20%) VAGX decoupling capacitors. Specifically, capacitors C1730, C1731, and C1732.
                                How necessary are these capacitors? It has (11) 22uF to begin with; missing (3), my board now only has (8).
                                I've been having difficulty sourcing new replacement capacitors without paying too much. Does anybody have any vendors state-side to recommend? Mouser charges parts + $8 shipping + $7 cutting fee (unless I buy an...
                                09-15-2022, 02:03 PM
                              • itsmeapple
                                MacBook Pro Charges When Off, But Not When On (MBP 2014 15 Inch) 820-3662-A
                                by itsmeapple
                                I'm facing an issue with my MacBook Pro.
                                When it's switched off, it charges while the battery is connected. However, when it's powered on, the charging stops after a few seconds.
                                Another strange thing is that when I disconnect the battery and plug in the charger, the MacBook Pro turns on and runs without any issues.
                                I've already tried using a different OEM charger, but no luck. I even swapped the charging port DC-IN, but the problem persists.
                                Has anyone else experienced this issue before?
                                Thank you!...
                                02-21-2025, 02:22 PM
