Lenovo Y50-70 only charges when turned off.
This topic has been answered.
  • Darren Hibbert
    • 116
    I have a Y50-70 gaming laptop. It has a problem where it charges up fine when the laptop is off, but when it's on, it doesn't.
    I've tried a new 135w charger + new Lenovo battery and a new charging port but it made no difference.
    I've updated all the drivers and still no difference.
    Could it be down to a dodgy chip? I'll see if i can find a schematic and someone on here might be able to direct me where to test
    Many thanks in advance.
  • Answer selected by Darren Hibbert at 08-10-2025, 09:27 AM.
    Darren Hibbert
    • 116
    I found the problem. Somebody had previously changed the charging port. However on closer inspection and with help from a boardview, the manafacturer of the port had wired it incorrectly. One of the ground wires was wired where a data line should have been and the data line was wired into where the ground should have been. Charging perfectly now
    • mon2
      • 16068
      The Lenovo Y50-70 laptop charging only when turned off indicates a potential issue with the power management settings or a hardware problem. It could be related to the "fast startup" feature, the power management settings within Lenovo Vantage, or a hardware problem with the battery or charging port.
      Here's a breakdown of potential causes and solutions:
      1. Fast Startup:
      • Fast startup can sometimes interfere with charging when the laptop is off.
      • Solution: Disable Fast Startup in Windows power options: Go to Control Panel > Hardware and Sound > Power Options > Choose what the power buttons do > Change settings that are currently unavailable > Uncheck "Turn on fast startup".
      • Darren Hibbert
        • 116
        Turned fast startup off, same problem.
        • mon2
          • 16068
          https://forums.lenovo.com/t5/ThinkPa...ly/m-p/4483670
          • Darren Hibbert
            • 116
            Thanks for that. Unfortunately my laptop is not in airplane mode so the problem continues. I think it's probably a motherboard issue which I'd like to get to the bottom of.
            • mon2
              • 16068
              Enter the BIOS - what are the stats of the mated power adapter?
              3. Locate AC adapter information
              • Within the relevant section, look for entries such as "AC Adapter," "Battery Information," or "Power Management".
              • You may see information about the AC adapter's status (detected, not detected) and possibly its wattage.
              • Darren Hibbert
                • 116
                • mon2
                  • 16068
                  Very nice. Most adapters are intelligent now. The bios often can serve as a confirmation of what the logic sees or does not see. Suspecting that the adapter was assumed to be under rated due to missing adapter ID line.
                  • Supporte
                    Lenovo Legion 5 15ITH6H NM-D711 Rev. 2.0 turned on, but after a few seconds shut down
                    by Supporte
                    Motherboard: NM-D711 Rev. 2.0
                    A Lenovo Legion 5 15ITH6H came in with the following fault: when the power button was pressed, the keyboard backlight turned on, but after a few seconds the laptop shut down completely.
                    During inspection, I found a physically damaged component labelled UR1 (photos will be added below).
                    According to board analysis, UR1 is a 3V/5V switch IC responsible for enabling the main always rails.
                    As a test, I made a temporary bridge, and the laptop immediately powered on and started...
                    01-08-2026, 01:05 PM
                  • BMCappelletti
                    Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                    by BMCappelletti
                    Hi everyone.
                    Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                    Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                    Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                    02-18-2025, 12:22 PM
                  • coasterghost
                    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                    by coasterghost
                    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                    System Hardware:
                    Processor: AMD Ryzen 7 PRO 5850U
                    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                    09-08-2025, 10:46 PM
                  • motormayhem
                    Lenovo T460 Only Charges on One Charger
                    by motormayhem
                    Laptop Question
                    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                    05-12-2023, 01:46 PM
                  • Oply
                    Lenovo G510 20238 BIOS 79CN49WW Product Name INVALID Lenovo SN INVALID
                    by Oply
                    Hello.
                    I have a Lenovo G510 laptop, machine type model 20238.
                    After replacing the motherboard, BIOS shows:
                    Product Name: INVALID
                    Lenovo SN: INVALID
                    BIOS version: 79CN49WW(V3.08)
                    Laptop information from the original bottom sticker:
                    Model: Lenovo G510
                    MTM: 20238
                    Serial Number: CB26271877
                    I need to write correct DMI/SMBIOS information after motherboard replacement.
                    Please help me find the correct Lenovo DMI tool / Golden Key for Lenovo G510.
                    I need a tool for Lenovo G510...
                    05-11-2026, 11:16 AM
