Thinkpad W541 Works from the mains and charges the battery only when it is turned off
  • bykanovm
    • Aug 2022
    • 96
    • Украина
    Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
    If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
    If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
    even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
    Also, the laptop does not turn on without a battery, there is a reaction to the button, the fan starts spinning and immediately turns off.
    It turns out that in order to use the laptop, you need to charge the battery in the off state and then work from the battery.
    There are 2 laptops with this problem.
    Maybe someone has encountered a similar problem. Which way should I look?
    I installed new power connectors, it doesn't help.​
  • bykanovm
    • Aug 2022
    • 96
    • Украина
    The problem was in the firmware of the multicontroller. I selected the necessary firmware for the 32Mbit chip, everything worked. I left the original 64Mbit chip.
    • Darren Hibbert
      Lenovo Y50-70 only charges when turned off.
      by Darren Hibbert
      I have a Y50-70 gaming laptop. It has a problem where it charges up fine when the laptop is off, but when it's on, it doesn't.
      I've tried a new 135w charger + new Lenovo battery and a new charging port but it made no difference.
      I've updated all the drivers and still no difference.
      Could it be down to a dodgy chip? I'll see if i can find a schematic and someone on here might be able to direct me where to test
      Many thanks in advance....
      08-09-2025, 11:15 AM
    • HTR-Informatique
      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
      by HTR-Informatique
      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
      I also changed the screen because the PC fell and the screen was broken.
      I changed the battery with a new and original battery.
      I also had corrosion/oxidation on the...
      02-09-2025, 06:51 AM
    • alex26
      Laptop Dell Latitude 5511
      by alex26
      Hello.I have a very strange problem with a Dell Latitude 5511. If I turn it on in the morning it works perfectly, charges the battery and everything is ok. Then I turn it off and it starts again, and then if I turn it off, it doesn't want to start at all. Now it doesn't even charge the battery and if I press the power button the orange light comes on as long as I hold the power button down and then the orange light goes off if I don't hold the power button down. Then if I wait a few minutes the laptop can be turned on and works perfectly and charging the battery. I only see the problem with the...
      10-10-2025, 06:35 AM
    • CapLeaker
      Dell ATX PSU won’t start, but forcing it works fine?
      by CapLeaker
      Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
      Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
      10-28-2024, 06:59 PM
    • the Benninger
      Vostro 3401 strange problem charge
      by the Benninger
      if you start the computer with the charger plugged in it charges without problems and everything works as it should
      once started, if you happen to disconnect the charger and reconnect it, it stops charging and feeding the computer; it only works with the battery's charge.
      This also happens when it is turned off. Do you have any idea where to start looking for this fault? I have already checked the power jack, the cable, and the charger,
      but the problem persists.
      Dell Vostro 3401
      ModelREG P132G
      MoBo:FDI55 LA-J081p Rev 1.0
      05-26-2025, 12:15 PM
