HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
  • reessi
    • Jan 2016
    • 337
    • uk
    I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
    It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
    What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
    I have checked these lines in diode mode and they seam normal -> 600.
    I have checked to see if they come on for even a fraction of a second on power on but nothing.
    Can anyone explain the sequence on the board for the ITC chip to send these out?
    1.8v, 3.3v & 5.5v come up when turned on with the power button.
    And there is power on the BIOS.. What I also want to know is, is there communication between the ITC and BIOS before the CPU is up? And if so can a corrupt bios cause this?
    I have the schematics and board view from this forum.. I can attach again if required and also photos if required.
    There is no power on the RAM or CPU as they require the MAINON and SUSON.
    Another query I have is, does it make a difference to which power rails come up if there is no RAM in the slot.. Does it detect for the presence? Just wondered.. I have RAM.
    I cannot find any shorts on the missing power rails..
    Also what voltage will MAINON & SUSON be when they come up and are both required to turn on the power supplies?
    Also what would happen if I inject these voltages on these signals? Presumably the power rails will come up but I guess there is another problem anyway as to why the ITC won't send them out?
    Many thanks.
  • reessi
    • Jan 2016
    • 337
    • uk
    UPDATE:
    After reading online about the power sequences of various motherboards I found that after the power button (NBSWON1# into ITC) is pressed then ITC relays that signal to the PCH (DNBSWON#).
    These signals happen as expected but then PCH is supposed to send SUSC# back to the ITC which in turn should turn on everything else with SYSON. But it does not send this signal!
    SUSC# is not shorted (800 diode mode). So either the PCH is faulty or there is something the PCH is expecting first.
    I experimented by injecting 1.8v on to SYSON and MAINON and DRVON and sure enough the power supplies come up but no post from the motherboard, presumably the ITC halts until it is receiving SUSC# and the PCH is obviously not running properly anyway!
    I will continue to read up on it. Any advice appreciated...
    • reessi
      • Jan 2016
      • 337
      • uk
      Can anybody help please? I do not know where to go from here?
      Many thanks.
      • eryo
        HP Pavillon Laptop 14-ce3031nf Bios Help
        by eryo
        Hello Everyone,
        Hoping someone can help me.
        Product: 1F7H0EA#ABF
        Serial: 5CD022HQJD
        Model : G7AL-2G DAG7ALMB8C0 rev: C
        Before flashing the bios. Laptop has power and turns on but no display , No CAPS lock but fans spin for 1-2 seconds. with a consumption of 0.8A. All the tension was present.
        Since the flash the laptop only consumes 0.05A and I no longer have SUSON and MAINON has 3.3v output from the ITE chip.
        Original dump.
        Thank you in advance for your help.​...
        12-06-2023, 08:06 AM
      • BrennoMaturino1
        HP Pavilion G4 (DA0R13MB6E0) Doesn't power on, MAINON oscillating
        by BrennoMaturino1
        I got this motherboard from HP that wouldn't turn on, after testing it, turns out that the more accurate description would be that the power LED is flickering and it won't display anything, i got some backstory from this board, it wouldn't output video and another technician tried to reseat the LVDS cable with the laptop on hoping it would work, all it did was fry both the display and motherboard, magic smoke was released from the screen and cable, i thought the PCH was probably killed and went full shorted, i tested the PWM and it outputs a power good signal and no fault, but it quickly falls,...
        12-02-2024, 11:44 AM
      • gurj1979
        KBC SIO Dump needed Quanta G7AL DAG7ALMB8C0
        by gurj1979
        Hi. Am I in the right place to ask for KBC / SIO dump ?
        IT5570-128 CXA
        I have a board with bad SIO and I can't Read the chip. Error Reading Block #xx...
        07-18-2024, 04:56 AM
      • tadifero
        hi i need a bios dag7almb8c0 rev c
        by tadifero
        s/n 5CD051à8LBV
        PRod SPN50EA#ABZ
        Model 14-ce3034nl
        please I get only black screen blinking 5 times...
        11-15-2023, 03:52 AM
      • Swell61
        HP Pavilion 14-ce3514sa G7AL-2G DAG7ALMB8C0 REV: C diagnostics
        by Swell61
        Hiya
        I found a faulty HP Pavillion 14-ce3514sa am having a stab at repairing it.
        Motherboard is G7AL-2G DAG7ALMB8C0 REV: C
        The board doesn't boot when the power button is pressed. The charger LED comes on when it is plugged in and when the power button is pressed, the main voltages are present on the board, the fan spins and the power LED comes on, but there's nothing on the screen (neither the built in one nor the HDMI out) and the keyboard doesn't light up.
        The first and possibly only thing concerning now is VCCIN for the CPU. After...
        10-13-2023, 02:00 AM
