MacBook Air 820-3209-A Missing (3) AGX 22uF Decoupling Capacitors
  • Cory Marqusee
    • Sep 2022
    Hi Everyone,
    I have a MacBook Air I've repaired, a mid-2012 13-inch 820-3209-A. It works. My only concern is that it is still missing (3) 22uF (0402 4V 20%) VAGX decoupling capacitors. Specifically, capacitors C1730, C1731, and C1732.
    How necessary are these capacitors? It has (11) 22uF to begin with; missing (3), my board now only has (8).
    I've been having difficulty sourcing new replacement capacitors without paying too much. Does anybody have any vendors state-side to recommend? Mouser charges parts + $8 shipping + $7 cutting fee (unless I buy an entire reel) and I maybe only need 50 - 100.
    Thanks to all in advance!
  • mon2
    • 14685
    Re: MacBook Air 820-3209-A Missing (3) AGX 22uF Decoupling Capacitors
    Hi. We order from Mouser / DK all the time.
    The $7 fee is for a TAPE & REEL fee for SMT machinery. For our SMT line, we have to apply a tape leader and place onto a reel so the equipment can suck up a part to place onto a blank PCB. We can get the same service @ Arrow for free (it is their incentive to win new business).
    For your repair business, you only need CUT TAPE - no extra fees are required. They will just cut up the # of pieces you need and ship you the cut tape off a large reel.
    $8 is a very good deal for shipping but you can also try Digikey. Then there is of course Aliexpress but will take a few weeks.
    On the caps - be sure to order the proper SMD size; same or better voltage rating, etc.
    • Cory Marqusee
      • Sep 2022
      Thank you for your extremely fast response to my post/inquiry and for recommending Arrow as a SMD parts supplier! As you said, they don't charge a cut tape fee, and their shipping charges are only $6. I will use Arrow for now on in lieu of Mouser and Digikey.
      However, Arrow noted they had a possible 5-day lag time in shipping due to high volume so I opted to go with a capacitor bundle from Amazon (almost 3,000 caps for $20 + tax) with delivery tomorrow. I have the options of stacking 2 x 10uF 0402 capacitors together and squeezing in larger 22uF 0603s. I unfortunately could not find any kits with 22uF 0402.
      Thank you again for your help and time!
      • reformatt
        • Feb 2020
        • 1525
        Larger caps are to prevent rail ripple during peak loads. Given it's an Air, not really that critical. I usually get a collection of larger caps for 0402, 0603 and 0805 off Aliexpress, and shove them in a drawer.
        If you don't want to do that, then buy yourself a 820-3437 donor board or two from Aliexpress. For the most part these are complete junk (chips torn off, SMC drilled though etc), but they are handy for passive components and connectors. Most of the caps etc are common between all these boards.
        • Cory Marqusee
          • Sep 2022
          Awesome! Thank you for your reply, as well. I appreciate you taking your time to help me. I'll go check out Aliexpress now.
          • Adogabriel100
            Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
            by Adogabriel100
            Hey! This is a A1278 macbook 2011.
            Problem: Not turning on / No green light
            Im using by3200s charger.
            Voltajes:
            PPBUS_G3H = 12.26v
            SMC_RESET_L = 3.3v
            PP3V42_G3H = 3.42v
            U7000 =
            Pin 1 CHGR_AGATE = 0v
            Pin 2 CHRG_DCIN = 19v
            Pin 3 CHRG_ACIN = 4.6v
            Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
            Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
            Pin 12 PP3V42_G3H = 3.42v
            Pin 13 CHRG_RST_L = 3.3V
            Pin 14 SMC_BC_ACOK = 0.8V
            Pin 19 PP5V1_CHRG_VDD = 5.05V
            Pin 20 PP5V1_CHRG_VDDP = 5.03V...
            04-01-2024, 01:02 PM
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
          • salopian
            Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
            by salopian
            Hello. I would need some advice please.
            My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
            He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
            I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
            I have already replaced the logic board with another...
            02-27-2021, 07:30 AM
          • mferna14
            Apple MacBook A1398 820-00138-A missing 5V
            by mferna14
            HI all, I am working on Apple MacBook A1398 logic board # 820-00138-A. The problem is that it does not turn on & no fan spin. Board is very clean & no sign of liquid spill. Upon checking the initial troubleshooting power rails, I found that its missing 5V (Absolute 0V on the Coil L7720, no pulsing at all, it's just 0V). 3.3V is PERFECT & across all points on the logic board. Checked the IC U7501 pin 4, this pin should have the ENABLE volts to turn on the 5v rail, & P5VS4_EN is missing. This signal generated from U8170 pin 4. PM_SLP_S5_L is also not present & ALL_SYS_PWRGD is...
            01-16-2023, 01:35 PM
          • fajfelek
            Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
            by fajfelek
            Hello, First of all thanks you for reading this topic.
            I need your help with identify missing parts on trackpad logic board (661-18430).
            The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
            Please help me with identity parts from blue and red area .
            06-15-2024, 01:41 PM
