MacBook Pro Charges When Off, But Not When On (MBP 2014 15 Inch) 820-3662-A
  • itsmeapple
    • Feb 2025
    • 6
    • PH
    I'm facing an issue with my MacBook Pro.
    When it's switched off, it charges while the battery is connected. However, when it's powered on, the charging stops after a few seconds.
    Another strange thing is that when I disconnect the battery and plug in the charger, the MacBook Pro turns on and runs without any issues.
    I've already tried using a different OEM charger, but no luck. I even swapped the charging port DC-IN, but the problem persists.
    Has anyone else experienced this issue before?
    Thank you!
    https://youtube.com/shorts/PYsPnCea2..._AVrsJdi2ueUWP
  • mon2
    • Dec 2019
    • 14512
    What is the power rating of the charger? Are you sure the charger is an original and not 3rd party or a fake?
    When you lose even the green led onboard, you have lost the 3v42 voltage rail. Do you have a multimeter for some testing?
    • itsmeapple
      • Feb 2025
      • 6
      • PH
      Hi thank you for your reply. I am using original 85W Magsafe 2 charger and it is in good condition. I used coconut battery to check and this is what i saw.
      When battery is at around 77.2% Charger not connected (Image 1)
      After 3min charging on (Image 2)
      After 10min charging on (Image 3)
      After 11min charging stopped (Image 4, Image 5)
      ​Battery removed and charger connected system running. (Image 6)
      • mon2
        • Dec 2019
        • 14512
        See attached. Review D7005 = dual, common cathode diode.
        Remove all power. Disconnect the battery. Disconnect the power adapter.
        Meter in DIODE mode.
        Place the red meter lead onto pin #1 of this diode (anode); black meter lead onto pin #3. Meter should conduct.
        Reverse the meter leads and the meter should now block (OL).
        Repeat with pins #2 and #3. Post each measurement.
        Click image for larger version  Name:	d7005.png Views:	0 Size:	103.1 KB ID:	3578150
        • itsmeapple
          • Feb 2025
          • 6
          • PH
          Thanks mon2 will follow the steps once i get home and post all the measurements.
          • piernov
            • Jan 2016
            • 4437
            • France
            If PP3V42_G3H was lost, the machine wouldn't run anymore.
            • itsmeapple
              • Feb 2025
              • 6
              • PH
              I haven't got time to check the board, but I will post the results in the coming days. Thanks.
              • itsmeapple
                • Feb 2025
                • 6
                • PH
                mon2 Hi, finally i got time to work on this board. just to be clear i'm still learning things and i'm not a pro in here. can you please tell me which chip i have to test. Thank youClick image for larger version
                THank you
                • ritalo
                  MacBook Air 13 2014 - Remove EFI password
                  by ritalo
                  I have a MacBook Air 13 inches 2014.
                  I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                  I know how to remove the password with a usb programmer.
                  I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                  Then I have to find this value in the file : $SVS because it indicate where is the password.
                  But I can't find the value.
                  I have attached the file​
                  Thank...
                  05-14-2024, 12:10 PM
                • envym
                  MacBook Pro 2018 with Activation Lock
                  by envym
                  Hi everyone!
                  I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                  I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                  06-27-2025, 08:54 AM
                  Apple MacBook Pro 13'' Early 2014 820-2530 820-2530-A 820-2530-B Boardview
                  Apple MacBook Pro 13'' Early 2014 820-2530 820-2530-A 820-2530-B Boardview...
                  10-22-2024, 03:26 AM
                • ritalo
                  MacBook Air 11 2014 - EFI corrupted
                  by ritalo
                  I have a MacBook Air 11 inches 2014 and its EFI is corrupted.
                  I use it with a card connected to the motherboard that replace the EFI.
                  I know how to flash the EFI with a usb programmer but I don't know where to find a good EFI file.
                  Thank you if you can help me
                  I have attached the corrupted EFI...
                  05-16-2024, 06:39 AM
                • donnos
                  macbook pro 820-3462 charges very slowly
                  by donnos
                  Received a macbook pro which in notification shows 7 or 10 hours until full during charging.
                  have replaced ISL6259 and Q7055 and still getting same results. current sensing resistors measured fine @ 0 and 2ohms. what else could be the issue?
                  without battery i get 12.58V. i have physically shorted Q7055 drain to source to rule out issue with the mosfet and can confirm its still the same. any suggestions?
                  when i shutdown it charges at only 16.5v 0.5A. during boot PSU draws 2.5-3A suggesting it momentarily charges but drops to 1.5A power draw after boot.
                  06-03-2023, 02:25 PM
