Can someone in the US do me a favour ? Add a small component to your cart and tell me what the cheapest shipping option is ?
Mouser Shipping Charges...
Re: Mouser Shipping Charges...
Yes Digi-key is the best way (next day usually), but if they don't have the part and you need, and you have to use Mouser, choose usps if you can wait about 10 days.
I ordered some parts on 05 - Dec -2014 and they arrived on 15 - Dec - 2014Last edited by R_J; 04-24-2015, 05:34 PM.Comment
Except for some geo reason perhaps I don't have the usps option in my shipping options. Essentially that was the reason for my initial post.
I was told I could specify usps priority by adding it in "Shipping Instructions" for $6.99 but that doesn't explain why I don't have the $4.95 option available for continental us shipping ?!
And 10 days in preferable when the other option is China.Comment
--- begin sig file ---
--- end sig file ---Comment
Try it for yourself and see if you can get a screenie like in post two or if you get mine in post 3. Btw on .ca mouser my cheapest shipping option for $0.02 resistor is $20 which just poisons me from even looking at Canadian equivalent sites.Comment
by harounHDGreetings everyone got an hp 17 ab laptop does not turn on with charger , but turns on with battery plugged in and charges only when the laptop is off mb DAG37DMBAD0 REV D...
I have a Y50-70 gaming laptop. It has a problem where it charges up fine when the laptop is off, but when it's on, it doesn't.
I've tried a new 135w charger + new Lenovo battery and a new charging port but it made no difference.
I've updated all the drivers and still no difference.
Could it be down to a dodgy chip? I'll see if i can find a schematic and someone on here might be able to direct me where to test
Many thanks in advance.... -
by reessiHello,
I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
I have checked these lines in diode mode and they seam normal -> 600.
I have checked to see if they come on for even a fraction of a second... -
by bykanovmLenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
Also, the laptop does not turn on without... -
by itsmeappleHello everyone,
I'm facing an issue with my MacBook Pro.
When it's switched off, it charges while the battery is connected. However, when it's powered on, the charging stops after a few seconds.
Another strange thing is that when I disconnect the battery and plug in the charger, the MacBook Pro turns on and runs without any issues.
I've already tried using a different OEM charger, but no luck. I even swapped the charging port DC-IN, but the problem persists.
Has anyone else experienced this issue before?
Thank you!... - Loading...
