Philips 42PFL7603D/10 image problems
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    Hi guys I have the above TV and all of a sudden the picture has gone what appears to be a negative image
    I get the same issue no matter what input I select
    And also get it on a normal black screen it shows as very bright white
    Could it be a fualty t-con board as all was fine until yesterday
    Any help is appreciated
    I will post pictures if need be as well
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    Re: Philips 42PFL7603D/10 image problems
    Here is an image of the problem guys
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
    • jasonr2000
      Advance Tech
      • Nov 2013
      • 209
      One more update guys the as15-f chip on the lvds / tcon board gets way too hot to the touch if u touch it when the panel is on it burns u it has got heat pads on there does that mean its a bad tcon ??
      Samsung UE46D6530
      Samsung BD-F7500
      Samsung HT-ES6200
      • jasonr2000
        Advance Tech
        • Nov 2013
        • 209
        Anybody have any advice ??
        Samsung UE46D6530
        Samsung BD-F7500
        Samsung HT-ES6200
        • habanerocat
          • Nov 2014
          • 96
          • Ireland
          Try some freezer spray on the hot chip and see what happens. It might just verify the faulty board.
            Yes, bad AS15.
            • jasonr2000
              Advance Tech
              • Nov 2013
              • 209
              Thanks guys will source a replacement tcon and update with my findings
              One more thing could the faulty chip be replaced if it comes as easier to source ?
              Samsung UE46D6530
              Samsung BD-F7500
              Samsung HT-ES6200
              • zomi
                • Nov 2011
                • 510
                If you are able to solder.
                Replace just the chip they are £3- £5 off ebay
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Aye--AS-15 chip--Yet Another casualty!
                  Such a common fault can give all sorts of brightness/neg image/colour distortions and used on a wide range of LCD/LED T-Con boards.....
                  Ive started buying the things in bulk!
                  TELEFIX
                  • jasonr2000
                    Advance Tech
                    • Nov 2013
                    • 209
                    Hi thanks for the reply I have no issues soldering
                    So I'll get the chip and see how I go
                    But will also source a replacement tcon just in case it goes wrong
                    Thanks guys
                    Samsung UE46D6530
                    Samsung BD-F7500
                    Samsung HT-ES6200
                    • jasonr2000
                      Advance Tech
                      • Nov 2013
                      • 209
                      Is there anyway I can prevent this from happening again ?
                      Samsung UE46D6530
                      Samsung BD-F7500
                      Samsung HT-ES6200
                        Nothing that we know of, it is one of the reason I do not get used board since we do not know when the IC (if it is not already replaced) will last.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Well--Not really, Its just a fairly hard driven part and has a finite lifespan.
                          You can try applying a silicone heat-pad (Dead-Toad) to conduct the heat from the chip to the steel T-Con tinwork cover, but I suspect its not actually a dissipation effect, more a cycling effect breaking down the (Lead-Free RoHS Crap) solder between the chip die and the package case, leading to local on-chip overheats on a microscopic level and failures....
                          --Its probably a few years old currently,--so if it gives you another 2-3 years, summit else will die and kill the set anyway!
                          TELEFIX
                          • jasonr2000
                            Advance Tech
                            • Nov 2013
                            • 209
                            Thanks both for the replies it already had some heatpad on there and it connects to the chassis as the TV is old now if I can get 2 years out of it then that's OK I'll replace the TV before then
                            The board I've been able to find is a refurbed board from emos
                            So will try that as a backup if my solder skills don't save the current board
                            Samsung UE46D6530
                            Samsung BD-F7500
                            Samsung HT-ES6200
                            • jasonr2000
                              Advance Tech
                              • Nov 2013
                              • 209
                              An update for u guys new tcon came today resolved the problem almost but the picture is darker than normal
                              Any ideas how I solve this ?
                              Samsung UE46D6530
                              Samsung BD-F7500
                              Samsung HT-ES6200
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                Well---
                                Its Probably the replacement T-Con's AS-15! I had a Philips 40" not so long ago that had a darkish but otherwise fine picture--AS-15 was the problem!
                                Worth checking the 20 odd ref voltages marked, Vgama1 to 20 odd.
                                They should form a slowly climbing value, each one a bit more than the last....
                                If you around Swansea--I have a spare AS-15.....
                                TELEFIX
                                • Arfi
                                  • Mar 2015
                                  • United kingdom
                                  1- is the T con from exact panel type T420**** rev *** including rev number? ?
                                  2- Is the LVDS lead inserted correctly in t
                                  3-have you updated the firmware to the latest?
                                  (you can check by pressing 123654 on your remote control and confirm version)
                                  4-have you done factory reset into the factory mode ?
                                  if you done all this 4 d look at possible faulty T con again if your tv was working fine prior to T con going faulty
                                  • jasonr2000
                                    Advance Tech
                                    • Nov 2013
                                    • 209
                                    Thanks both for the reply
                                    I'll contact emos TV repairs as the replacement tcon is from them
                                    I've got my original tcon still and an as15-f chip that I purchased new
                                    But when I saw how small the pins was I decided soldering it on wasn't for me way beyond my skill
                                    Ive gone in to service mode and based on what the service manual states my option code is also wrong
                                    But I don't see my option codes on the TV anywhere so should I leave them alone ? And get emos to issue another tcon ?
                                    Samsung UE46D6530
                                    Samsung BD-F7500
                                    Samsung HT-ES6200
                                    • jasonr2000
                                      Advance Tech
                                      • Nov 2013
                                      • 209
                                      And yeah tcon was identical in all ways part number and so forth
                                      Did a software update and factory reset
                                      Samsung UE46D6530
                                      Samsung BD-F7500
                                      Samsung HT-ES6200
                                      • jasonr2000
                                        Advance Tech
                                        • Nov 2013
                                        • 209
                                        Here are some pics of how the image looks guys
                                        I've also noticed there is some image retention also
                                        But it does go away
                                        And I'm near aberdare so not as close to swansea
                                        Samsung UE46D6530
                                        Samsung BD-F7500
                                        Samsung HT-ES6200
                                        • alro7779
                                          Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
                                          by alro7779
                                          Hello there!
                                          Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
                                          08-07-2025, 11:53 AM
                                        • tuner2000i
                                          Philips 65PUS8518/12 distorted image after main board replacement
                                          by tuner2000i
                                          hello everyone,
                                          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                          07-15-2025, 01:15 PM
                                        • malekservis
                                          Philips 58PUS8536/12 Backlight ok, no image
                                          by malekservis
                                          the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                                          Any information would be appreciated....
                                          08-07-2024, 07:48 AM
                                        • jason123
                                          Hisense 65R6E3 double-image / horizontal strips - TCON?
                                          by jason123
                                          Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                                          07-19-2025, 08:07 AM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
