Hisense 65R6E3 double-image / horizontal strips - TCON?
I had an LG 50" TV with similar issue a few years ago. Top 25% was perfect, and lower 75% had intermittent perfect image with horizontal tearing every second or so.
I disconnected the LHS and RHS lower panel buffer boards independently from the TCON during testing but cannot recall the result. I was ready to toss the TV due to a panel problem when I discovered the scotch tape fix which works by masking some of the clock lines on the ribbon cables between the TCON board and the panel buffer boards.
My TV was fixed. with clear scotch tape. It had very similar display problem to yours with some of it being perfect/unaffected, and other areas of the screen having lines, or loss of resolution, or flickering.
I can't say it will help your TV since you say the lines are same whether LHS or RHS is disconnected from TCON, but my TV with similar problem had a panel issue. I would not spend money on a new TCON since I don't think it is your issue.Comment
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by KingfreddieOk.. this is the story:
Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
This is kinda how it looked, just that mine were at the bottom of the screen:
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
