sony KDL-46S4100 proper voltage
    • 12083
    • U.S.
    #41
    Re: sony KDL-46S4100 proper voltage
    [QUOTE=splitcrete;512384]My KDL-46xbr has a green light while on, and no red standby. Same with my KDL-46w4100[/QUOTE Thanks Splitcrete, it looks like this model doesn't have it.
    • splitcrete
      • Dec 2012
      • 387
      • usa
      #42
      I am working on a KDL-46S4100 also, new main board only gives me a test screen loop. This thing is going to the land fill if it doesn't behave.lol No red light on this one .
        • 12083
        • U.S.
        #43
        holy crap thats exactly what I got test loop, what is up with this dam testloop?
          • 12083
          • U.S.
          #44
          got a different a board, now test loop is gone, just get solid blue but only when lvds is unplugged from the a board, when lvds unplugged from tcon side, nothing no backlight nothin, was thinking it might be the lvds cable, did you try a different one?
            • 12083
            • U.S.
            #45
            wondered if your main board is brand new?, I bought 1 form shop jimmy and 1 from ebay, still not sure if ether 1 is good.
              • 12083
              • U.S.
              #46
              having a hard time believing it's a bad panel, when it gives that test loop, makes me think it must be something besides the panel.
              • splitcrete
                • Dec 2012
                • 387
                • usa
                #47
                I tried two boards both from flea bay. I am going to try to boot it up with KDL-46w4100 software. I have never had a problem like this. I have been watching CL for a kdl-46s4100 with a broken screen. I am going to keep watching for another week. If I don't find one its software time. Will post if I have any luck.
                  • 12083
                  • U.S.
                  #48
                  theres some software for it, let me take a look.
                    • 12083
                    • U.S.
                    #49
                    Splitcrete, couldnt figure out how to post it here, so I sent it to you in a pm.
                    • splitcrete
                      • Dec 2012
                      • 387
                      • usa
                      #50
                        • 12083
                        • U.S.
                        #51
                        I tried it but I might have done the procedure wrong, not sure but it seemed to act the same.
                          • 12083
                          • U.S.
                          #52
                          Splitcrete, did you try a different lvds cable on it?, wondering if my lvds is bad.
                          • splitcrete
                            • Dec 2012
                            • 387
                            • usa
                            #53
                            I checked the cable contact for contact its good. Going to try the software you sent me tomorrow. My wife wants to go last minute shopping fun time NOT...Thanks again.
                            • R_J
                              • 9515
                              The latest version I believe is KDL_S4100_V1.115
                                • 12083
                                • U.S.
                                #55
                                anyone know how many heat sink pads there should be, the ones that stick to the metal shield of the tcon board, I have 2 pads, but had the shield out for quite a while a pad or 2 may have fallen off and gotten lost, Thanks.
                                  • 12083
                                  • U.S.
                                  #56
                                  Thanks R_J
                                  • splitcrete
                                    • Dec 2012
                                    • 387
                                    • usa
                                    #57
                                    Success My KDL-46S4100 is working again.
                                    Thank you so much nomoresonys the firmware worked.
                                    The best part there are no tab bond problems.
                                    One happy camper here..
                                      So where did you download the firmware from? SONY site does not have it.
                                      • capkid
                                        • Oct 2010
                                        • 1339
                                        I posted it here:
                                        http://www.mediafire.com/?vltcldjt96zn7jr
                                        LG Plasma Mal-Discharge Correction Service
                                          Thanks capkid. I will save the file for future repair. How did you manage to find it?
                                            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                            by sam_sam_sam
                                            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                            Now...
                                            06-09-2024, 10:57 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                            ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                                            3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                                            Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                                            core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                                            configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                                            serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                                            Based on Intersil's Robust Ripple Regulator...
                                            11-05-2024, 03:24 PM
                                          • ruletero
                                            Acer a515-43 low battery charge voltage
                                            by ruletero
                                            Hi
                                            Acer A515-43
                                            LA-H801P
                                            Fail: Does not charge battery, has low voltaje on connector.
                                            Laptop didn't want to turn on, only charge led blinked.
                                            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                            10-24-2022, 02:31 PM
                                            Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                                            by sam_sam_sam
                                            I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                                            https://www.ebay.com/itm/116497313155?var=416785404161
                                            Here are some of the description from the eBay seller
                                            The main parameters:
                                            1. Product name: High-power non-isolated DC boost module power supply.
                                            2. Product model: 100A2000W.
                                            3. Input voltage: DC12V-60V.
                                            4. Input current: 100A (maximum)....
                                            05-18-2025, 09:45 AM
