Sony XBR-75X800G - Android start up only and dark blue screen
    • 12330
    • U.S.
    #121
    Originally posted by NolesFan
    Of course not nomoresonys, dont like giving up, but when its an avenue that I dont travel much and I dont understand things or words. By nature I like to try to fix everything before i throw it away, but my skill level in electronics of this nature is not very high. Ill try to run the updates and all that and see if that helps. I was actually going to try a new Tcon board also just to see. Right now, there is no change in the screen if i unplug the Tcon or leave it plugged in with the ribbon cable coming from the MB.
    In the video I linked, he has no picture so this is possibly your issue, its easy enuf to test just as he does, if the vgh is missing it IS panel problem, a new tcon will not fix that issue.
    • Diah
      • Feb 2013
      • 6568
      Sorry Diah, I assumed by the statement since I was having trouble getting the plate off ( small things ) and the doubt about the standalone test and then with the final seek help before i cause damage, I figured you were doubting me and wanted to give up. I doubt my skills haha thats why Im here. i was able to figure out how to remove that panel, after the screws removed there were 3 of 4 black things holding it in place that needed to be pushed in so the panel could be lifted and slid back. I could see the panels and all the u shaped ribbons running to the panel itself.
      good you did it... disconnect the U ribbon and check the screen if you could find any white color par or image.... if nothings on both U ribbon disconnected..... try the easy way run firmware..... or hard reset.... or at end replace T-CON
        • 12330
        • U.S.
        #123
          • 12330
          • U.S.
          #124
          Yeah, what the hell just try a new tcon.
          • NolesFan
            trying to learn
            • Jul 2024
            • 94
            For the life of me I cant find anything labeled VGH. Ive tested what ever I can find that has a V and so far so good on the readings though. I keep looking for it though since you said if there is no VGH then its the panel, might as well till I try a new Tcon
            • NolesFan
              trying to learn
              • Jul 2024
              • 94
              So ok, I was able to watch a few other videos and saw where its also called VONE and VOFFE. I have found VONE on my Tcon, but it doesnt read anything ( 0.01v ). I tried the ribbons to see if I get half a screen, and no i dont and the voltage stays at 0.
                • 12330
                • U.S.
                #127
                You checked it with one ribbon cable at a time connected correct? hmm, that might be a good thing, maybe just the tcon is bad and the panel isnt shorted?
                  • 12330
                  • U.S.
                  #128
                  I guess you could try the taping in the video, just for fun and curiosity.
                    • 12330
                    • U.S.
                    #129
                    A few other names for vgh are vgon,von,dvdg. 25-30 volts.
                      • 12330
                      • U.S.
                      #130
                      For vgl its voff, veeg, vgoff -7 to -9. Another voltage to check is vdd also known as v logic, dvd 3.3 volts. Another is avdd also known as vdda, vda 12-18 volts.
                      • NolesFan
                        trying to learn
                        • Jul 2024
                        • 94
                        Yes that is correct.
                        • NolesFan
                          trying to learn
                          • Jul 2024
                          • 94
                          I thought for this you needed to have at least one of the reading in the mid 20v ? If not, yes I will def try it, cant hurt at this point.
                          • NolesFan
                            trying to learn
                            • Jul 2024
                            • 94
                            Thanks for all the abbrevs to look for. I took several photos so I could zoom in and what the hell everything is saying. Ill see what I can find. Hopefully get some answers.
                            • NolesFan
                              trying to learn
                              • Jul 2024
                              • 94
                              I got a good working Tcon and was getting different readings compared to the original, and still no picture I did try the tape in several places but nothing. Everything is still the same with no pic just sound. I guess the panel went to ghost. I wish I knew more because in those videos you sent, they get very detailed in what to do, I just dont have the knowledge to know what everything is to read, or what it should or not show. Appreciate all the help.
                                • 12330
                                • U.S.
                                #135
                                Can you show a detailed picture of both tcons?
                                • NolesFan
                                  trying to learn
                                  • Jul 2024
                                  • 94
                                  Let me know if not good enough.
ID:	3462749 Click image for larger version
                                    • 12330
                                    • U.S.
                                    #137
                                    Ok, so with new tcon, try same test as post #126, remember vone IS vgh, see what it is with both ribbons connected, if it isn't optimal check again with one cable at a time connected.
                                    • CapLeaker
                                      Leaking Member
                                      • 8352
                                      what you need to do first is to check the LVDS with an oscilloscope and flick around the menus while watching each pair when it blue screens. If the LVDS pairs aren't changing while flicking around, the problem is the main board.
                                      • lotas
                                        • Jan 2016
                                        • 4863
                                        • Russia
                                        #139
                                        V-by-One HS is an electrical digital signaling standard that can run at faster speeds over inexpensive twisted-pair copper cables than Low-voltage differential signaling, or LVDS.​
                                        Here you need a cool oscilloscope to see something.
                                        • CapLeaker
                                          Leaking Member
                                          • 8352
                                          Signal is signal, lotas... o.k. maybe a standard low end oscilloscope doesn't cut it, but the same principal remains. At the end of the day it always boils down to having the right equipment to do the job. Very good observation from your side and shows you paid attention!
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • Chrissygizmo
                                            Sony KD-55XG9505 lines on screen problem
                                            by Chrissygizmo
                                            Hello again everyone,
                                            This is my latest mission, to try getting this Sony tv back to normal working order…
                                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                            02-19-2025, 11:31 AM
                                          • ulthi
                                            Samsung QE50Q60TAU - Flashes black/blue screen
                                            by ulthi
                                            My tv is not able to turn on. I flashes between black and vague blue screen (see video)
                                            I have tried different resets and have also replaced the main board - but nothin has changed.
                                            Any suggestions?
                                            https://youtu.be/acYQ-ImmhWA
                                            10-14-2025, 01:48 PM
                                          • Adam Russ
                                            Black screen on Sony 65x90ch (65x900h from Costco)
                                            by Adam Russ
                                            Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
                                            09-15-2024, 05:46 PM
