Sony XBR-75X800G - Android start up only and dark blue screen
  • nomoresonys
    • 12330
    • U.S.
    #141
    Signal is signal, lotas... o.k. maybe a standard low end oscilloscope doesn't cut it, but the same principal remains. At the end of the day it always boils down to having the right equipment to do the job. Very good observation from your side and shows you paid attention!
    Indeed CapLeaker you said it all, an oscilloscope would make it SO much easier.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      you guys were doing pretty good here. Maybe sometimes it's not quite fair for me to chime in, because I have some gear to my disposal that most others don't have.
      • nomoresonys
        • 12330
        • U.S.
        #143
        Well that's our fault not yours. Been meaning to get some more gear just been too lazy lately.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          Ha! Maybe I should come down and help you out in that situation... lol. Carry on, I'll shut up now already!
          • nomoresonys
            • 12330
            • U.S.
            #145
            Those little oscillos are getting so economical to buy, thinking that anyone wanting to try fixing their tv should prolly have one. I can make room on the bench for one of those small ones.
            • NolesFan
              trying to learn
              • Jul 2024
              • 94
              what you need to do first is to check the LVDS with an oscilloscope and flick around the menus while watching each pair when it blue screens. If the LVDS pairs aren't changing while flicking around, the problem is the main board.
              Hi CapLeaker, I had the main board tested by a repair shop and they stated it tested fine. Do you still think it could be the main board?
              • NolesFan
                trying to learn
                • Jul 2024
                • 94
                Ok, so with new tcon, try same test as post #126, remember vone IS vgh, see what it is with both ribbons connected, if it isn't optimal check again with one cable at a time connected.
                nomoresonys, sorry I just saw the emails about what you want me to try again. I will test it the next chance I can and let you know the results.
                • NolesFan
                  trying to learn
                  • Jul 2024
                  • 94
                  So since the TV has been sitting, before I was going to sign off, I decided to just turn it on. It went from powered off, to backlight screen with sound, to a cycling white red green blue screen and starts all over again. Hopefully video shows so you can see what I mean.
                  https://streamable.com/x0xsuc
                  • lotas
                    • Jan 2016
                    • 4861
                    • Russia
                    #149
                    Check the LVDS cable (contact pads), replace with a new one...
                    • nomoresonys
                      • 12330
                      • U.S.
                      #150
                      Remember simple first, make sure your flat cable ends are clean and not damaged and connected straight and secure, if nothing else try plug and unplug the connector on mainboard and powerboard a couple times to try to make sure the pins are getting good contact, same with cable from mainboard to tcon or panel.
                      • nomoresonys
                        • 12330
                        • U.S.
                        #151
                        Can clean the flat cable contacts with isopropyl alc. some use pencil eraser, not too roughly, can go over the connectors where they hook up lightly with a toothbrush, remember its making sure things are clean and getting good connection, don't want to be too rough and break something but you do want to make sure things are clean and getting good contact, I've suspected poor connections all along on this one. Could also be a bad or intermittent cable as suggested previously.
                        • nomoresonys
                          • 12330
                          • U.S.
                          #152
                          So if all that checks out can try some other stuff, one that works sometimes is hold power button on tv down while plugging in power cord keep holding til a display comes up, might take 3 or 4 minutes in some cases. Just be careful if display does come up, it might be the service menu so don't change anything, if display comes up let it come up fully then let go of button let it sit a minute, turn it off wait 5 minutes then restart as normal.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8352
                            Without seeing signals on the oscilloscope, how do you make sure that something is coming out of the main board first place? Other than that you just take out the parts canon and see what sticks. Not a proper diag. You gotta start somewhere and be sure the part works.
                            • NolesFan
                              trying to learn
                              • Jul 2024
                              • 94
                              I did all that you asked of me nomoresonys and nothing changed.
                              CapLeaker unfortunately I dont own an oscilloscope only multimeters
                              lotas I found one that is all the wires for this set. Ill get it an try.
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8352
                                lotas I found one that is all the wires for this set. I’ll definitely get it a hattry.
                                That definitely is limiting options.
                                • NolesFan
                                  trying to learn
                                  • Jul 2024
                                  • 94
                                  So i tried all the cleaning tips and nothing. Found on Ebay a full set of wires. I changed out the LVDS and the one between the PS and MB. Thanks for all the help guys, I appreciate it. nomoresonys I have another set Ill be trying soon, so hope you continue to comment. You didnt let me give up so Im looking forward to hearing what you have to say on my next set.
                                  • Ryan.man
                                    by Ryan.man
                                    02-04-2025, 12:23 PM
                                  • reformatt
                                    by reformatt
                                    07-31-2025, 08:37 PM
                                  • Chrissygizmo
                                    Sony KD-55XG9505 lines on screen problem
                                    by Chrissygizmo
                                    Hello again everyone,
                                    This is my latest mission, to try getting this Sony tv back to normal working order…
                                    I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                    02-19-2025, 11:31 AM
                                  • ulthi
                                    Samsung QE50Q60TAU - Flashes black/blue screen
                                    by ulthi
                                    My tv is not able to turn on. I flashes between black and vague blue screen (see video)
                                    I have tried different resets and have also replaced the main board - but nothin has changed.
                                    Any suggestions?
                                    https://youtu.be/acYQ-ImmhWA
                                    10-14-2025, 01:48 PM
                                  • Adam Russ
                                    Black screen on Sony 65x90ch (65x900h from Costco)
                                    by Adam Russ
                                    Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
                                    09-15-2024, 05:46 PM
