Black screen on Sony 65x90ch (65x900h from Costco)
  • Adam Russ
    • Sep 2024
    • 39
    Originally posted by EazyBone
    I have a 850e Sony that has a board for a 850f. The TV turns on still and once it gets to YouTube to play or something it crashes. The original owner said he replaced the board and it worked for a while and the same thing happened again. I also had this exact thing with a different TV, and I ordered the correct board to fix it. So you might have a wrong board in there.
    BUT like we learn here, I also have a 65 Samsung that when I lookup the board it's listed as a 55 inch tv and ONLY for the 55 also.
    Hopefully the version you need is cheaper.
    They arent too bad. about 60 bucks on average. Hoping that'll resolve the issues. I'm halfway through checking these backlights on the 4 blink tv but so far the top half all checknout as working. can tell they made the zones smaller on this one (2 leds per zone instead of 3 on the H model). Im.hoping this one is easier to diagnose but I might need to double check it's boards are correct too. Thanks for the help before.
    • EazyBone
      • Jun 2023
      • 1361
      • United states
      #42
      Don't forget that potentially it means the LED circuit. Bad power board can cause it also. So yes do the due diligence on testing the LEDs and the rest. I've never actually had a Sony with bad backlights yet.
      • Adam Russ
        • Sep 2024
        • 39
        Well I got it working again. Took it all apart. tested the led with a backlight tester, all were good with proper voltage and brightness. Put it all back together. Upon first turning it on, just a black screen. Unplugged left side lvds cable, still a black screen. switched to the right unplugged and got the display color test. Hooked both up and all black. Did a factory reset and it started right up. I'm wondering if somehow one of the backlights was loose or making a bad connection triggering the 4 blinks. I has previously swapped every board with a working one from a good tv and no change so I figured it had to be backlight related with the 4 blinks and no board fixing anything. But since backlight tested okay maybe there was a bad connection somewhere. Anyway, glad it's working and I can get this one out of here. Thanks again. I'll be ordering the correct. board on the other tv and hopefully they'll be out of my room finally.
        • Adam Russ
          • Sep 2024
          • 39
          Just an update on that first tv that had the wrong main board. I got the new main board in and did the firmware update. Still a black screen. Not sure if it really worth investing much more time into it. Last thing would be buying a new t con even though when i swapped them in the past it didnt fix it. That could be due to the wrong board being installed though.
          • Adam Russ
            • Sep 2024
            • 39
            Second update. Tried to see if a factory reset would change anything. I left it on for about 5 mins to do it's thing and it suddenly shut off. Now the power supply is dead. Have you guy seen a new main board cause a power supply to go bad before?
            • Diah
              • Feb 2013
              • 6498
              in which test you get switched to the right unplugged and got the display color test​ ?
              • Adam Russ
                • Sep 2024
                • 39
                That test was on the other tv. That tv is working again. My last message was the forst tv where I found out the tv had the wrong main board in it. However when i swapped out the board and then did a firmware update to pair it, it still didn't show anything but a black screen. Then I tried to factory reset it and it didn't the turn of and turn on typical procedure. A few minutes layer it just completely turned off. The power board which was working fine up to that and had proper voltages is now dead. I'm curious if anyone has had experience where a main board has caused the power supply to suddenly fail after installing it.
                • Diah
                  • Feb 2013
                  • 6498
                  show yours power boards socket and it print chart on it to know the pins name... also take it out and just plug it alone in wall socket measure any voltage you have on the socket which it before go to main boards.( this measurement should black probe on cold area chassis/GND and the red one on pins
                  • Adam Russ
                    Black screen on Sony 65x900h
                    by Adam Russ
                    I'm stuck on this tv. It has sound, and has backlight glow, but no picture. I've tried new power board, and new main board, but no change. Tried a new t con but still no change. I've updated the firmware after new parts with no change. Is it likely the panel is just dead of would it be lvds cables. I did take some shorter ones I had on hand and connected those between the main and t con just to see if I'd get a picture but no luck. I'm not sure what else there is to blame. Do screens just go out completely but remain with a backlight glow? The screen has been removed and used a backlight...
                    02-01-2025, 04:02 PM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • Chrissygizmo
                    Panasonic TX-48CX350B backlights but white screen , blank screen
                    by Chrissygizmo
                    Hi all, I’ve got a problem I hope someone can help me fixi.
                    I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                    01-11-2025, 03:18 PM
                  • dicky96
                    HP Elitebook Screen blank - backlights but no image
                    by dicky96
                    Hi guys
                    I'm trying to fix this laptop screen
                    Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                    OK so I have the original screen which works but has lines across the bottom quarter of the screen
                    I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                    04-28-2021, 07:30 AM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
