Sony XBR-75X800G - Android start up only and dark blue screen
good you did it... disconnect the U ribbon and check the screen if you could find any white color par or image.... if nothings on both U ribbon disconnected..... try the easy way run firmware..... or hard reset.... or at end replace T-CON
Sorry Diah, I assumed by the statement since I was having trouble getting the plate off ( small things ) and the doubt about the standalone test and then with the final seek help before i cause damage, I figured you were doubting me and wanted to give up. I doubt my skills haha thats why Im here. i was able to figure out how to remove that panel, after the screws removed there were 3 of 4 black things holding it in place that needed to be pushed in so the panel could be lifted and slid back. I could see the panels and all the u shaped ribbons running to the panel itself.Comment
Of course not nomoresonys, dont like giving up, but when its an avenue that I dont travel much and I dont understand things or words. By nature I like to try to fix everything before i throw it away, but my skill level in electronics of this nature is not very high. Ill try to run the updates and all that and see if that helps. I was actually going to try a new Tcon board also just to see. Right now, there is no change in the screen if i unplug the Tcon or leave it plugged in with the ribbon cable coming from the MB.Last edited by nomoresonys; 08-27-2024, 02:44 PM.Comment
For the life of me I cant find anything labeled VGH. Ive tested what ever I can find that has a V and so far so good on the readings though. I keep looking for it though since you said if there is no VGH then its the panel, might as well till I try a new TconComment
So ok, I was able to watch a few other videos and saw where its also called VONE and VOFFE. I have found VONE on my Tcon, but it doesnt read anything ( 0.01v ). I tried the ribbons to see if I get half a screen, and no i dont and the voltage stays at 0.
You checked it with one ribbon cable at a time connected correct? hmm, that might be a good thing, maybe just the tcon is bad and the panel isnt shorted?Last edited by nomoresonys; 08-27-2024, 06:45 PM.Comment
A few other names for vgh are vgon,von,dvdg. 25-30 volts.Last edited by nomoresonys; 08-27-2024, 07:02 PM.Comment
For vgl its voff, veeg, vgoff -7 to -9. Another voltage to check is vdd also known as v logic, dvd 3.3 volts. Another is avdd also known as vdda, vda 12-18 volts.Last edited by nomoresonys; 08-27-2024, 07:06 PM.Comment
I got a good working Tcon and was getting different readings compared to the original, and still no picture
I did try the tape in several places but nothing. Everything is still the same with no pic just sound. I guess the panel went to ghost. I wish I knew more because in those videos you sent, they get very detailed in what to do, I just dont have the knowledge to know what everything is to read, or what it should or not show. Appreciate all the help.
Ok, so with new tcon, try same test as post #126, remember vone IS vgh, see what it is with both ribbons connected, if it isn't optimal check again with one cable at a time connected.Comment
V-by-One HS is an electrical digital signaling standard that can run at faster speeds over inexpensive twisted-pair copper cables than Low-voltage differential signaling, or LVDS.
Here you need a cool oscilloscope to see something.Attached Filesif you find these attachements useful please consider making a small donation to the site
Signal is signal, lotas... o.k. maybe a standard low end oscilloscope doesn't cut it, but the same principal remains. At the end of the day it always boils down to having the right equipment to do the job. Very good observation from your side and shows you paid attention!
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
i tried the hard reset, cmos reset, changing the ram without results.
in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...11-22-2025, 03:54 PM -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... -
by ulthiMy tv is not able to turn on. I flashes between black and vague blue screen (see video)
I have tried different resets and have also replaced the main board - but nothin has changed.
Any suggestions?
https://youtu.be/acYQ-ImmhWA
... - Loading...
