Sony XBR-75X800G - Android start up only and dark blue screen
  • NolesFan
    trying to learn
    • Jul 2024
    • 94
    So I got the board back today and I wont to give the self test another go =since I got the new jumpers in and to be sure I was doing it right.
    Disconnected harness between PS and MB.
    Disconnected harness from MB to Tcon on Tcon side.
    5 7 9 26 all connected.
    Connect PS pin 28 to Tcon fuse.
    Plugged power wire into wall and I heard the "click" went around to front of TV and nothing happened, screen stayed black. LED strips never came on.
    Checked voltage at the 4 connected wires = 3.52
    Checked voltage at fuse = 12.57
    Am I doing something wrong or what does that tell you Diah? Thank you
    • NolesFan
      trying to learn
      • Jul 2024
      • 94
      Here are the phots you requested Diah. I hope they are good enough to see what youre looking for.
      • Diah
        • Feb 2013
        • 6562
        thx. they are in good shape...
        • nomoresonys
          • 12330
          • U.S.
          #84
          Maybe check all the cables, just check for continuity meter probe on each end, like you would check any wire. Post a picture of the whole back of tv as to see all the boards and how they are connected, my "guess" is a powerboard issue IF all the cables check out ok. Did you have a good look at the under side of the powerboard, obvious blown component, bad solder, might suspect a marginal/bad capacitor, electrolytic caps usually fail first.
          • NolesFan
            trying to learn
            • Jul 2024
            • 94
            Nomoresonys, ok Ill give it a try. No I have not looked at the back of the power board. I didnt think it was an issue after getting my readings correct ( finally ). Ill check that today along with looking at the back of the Tcon. But any idea with the above quote? I mean if it sounds how I have it hooked up is correct and Im not getting the screen test with any colors, does that mean the panel is bad and I should give up?
            • nomoresonys
              • 12330
              • U.S.
              #86
              Sorry I'm not exactly sure what it means when that test "fails" I'll defer to Diah for that.
              • nomoresonys
                • 12330
                • U.S.
                #87
                Guess there isnt much left but the tcon, if all cables and powerboard are good.
                • nomoresonys
                  • 12330
                  • U.S.
                  #88
                  And now at this point, I can turn the TV and it will show normal picture, work for a few hours then go dark blue. I can shut off the TV for a little while, turn it back on and its a normal picture again. Leave it on a few hours and itll go back to dark blue.
                  I'm not sure about this particular tv, but does this exact thing happen every time, on 3 hours then shuts off? I"m pretty sure there are some tvs that WILL shut down/off when there is no communication from the user after a while, like no clicks from the remote. Maybe the sleep timer is set?
                  • NolesFan
                    trying to learn
                    • Jul 2024
                    • 94
                    Yes correct. Currently, with functional MB installed, when I turn it on the TV clicks, back lights come on, they run thru their lighting phase as what would show on screen ( mean bright dim bright etc ) but no picture. If I leave it like that, the TV shuts off ( guessing due to no source recognized ).
                    • nomoresonys
                      • 12330
                      • U.S.
                      #90
                      Forgot what was tried but heres a couple things. Restart your TV by pressing the power button on the remote control until a message appears, the TV will restart. Simple reset, unplug tv from power hold power button on tv down for 30 seconds, wait a minute, plug back in and try it. Maybe try a firmware update if it isnt on the latest.
                      • nomoresonys
                        • 12330
                        • U.S.
                        #91
                        Interesting, try the first 2 things in post above.
                        • nomoresonys
                          • 12330
                          • U.S.
                          #92
                          If no joy on those 2, try
                          a force factory data reset, unplug the AC
                          power cord. Press and hold both power and –
                          buttons on the TV, then plug in the AC power
                          cord. Release both buttons when the
                          illumination LED blinks in green
                          • nomoresonys
                            • 12330
                            • U.S.
                            #93
                            I suppose some of those tests might not work if you have no display.
                            • NolesFan
                              trying to learn
                              • Jul 2024
                              • 94
                              Well the screen shows me nothing ( meaning cant see any message appear ) but I did hold down the remote power, tv shut off and rebooted, LED lights cycled, but no display.
                              Tried the unplug and hold manual button down for 30 seconds and plugged back in, and LED lights cycled but no display.
                              Tried a hard reset with the power and down buttons held, green lights faded in and out on little light below the TV, then let go, little light went to white, LED lights cycled, but no display.
                              • NolesFan
                                trying to learn
                                • Jul 2024
                                • 94
                                Oh and Nicks did send me a USB drive bac with my MB but no information with it. When I plugged into my computers and I checked the file name it was " upgrade_loader.pkg " I dont have a program on my computer to open it, but figure its something for the TV. I was going to call them today and ask about it. Bad thing is though, if its some kind of firmware updater or something, without being able to see anything on screen, I wont be able to do anything with it.
                                • nomoresonys
                                  • 12330
                                  • U.S.
                                  #96
                                  Do you have the original remote for this tv?
                                  • nomoresonys
                                    • 12330
                                    • U.S.
                                    #97
                                    • NolesFan
                                      trying to learn
                                      • Jul 2024
                                      • 94
                                      just called Nicks, they said the USB was for pairing the MB back to this TV, so they sent me instructions on how to do and will perform that now.
                                      yes original remote
                                      • nomoresonys
                                        • 12330
                                        • U.S.
                                        #99
                                        I believe thats the firmware update.
                                        • Diah
                                          • Feb 2013
                                          • 6562
                                          remove the speaker and let see the panel buffer boards.. on each side you have at the middle U ribbon... try disconnect one a time and turn on the TV with signal to wake up the Soc GPU
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • Chrissygizmo
                                            Sony KD-55XG9505 lines on screen problem
                                            by Chrissygizmo
                                            Hello again everyone,
                                            This is my latest mission, to try getting this Sony tv back to normal working order…
                                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                            02-19-2025, 11:31 AM
                                          • ulthi
                                            Samsung QE50Q60TAU - Flashes black/blue screen
                                            by ulthi
                                            My tv is not able to turn on. I flashes between black and vague blue screen (see video)
                                            I have tried different resets and have also replaced the main board - but nothin has changed.
                                            Any suggestions?
                                            https://youtu.be/acYQ-ImmhWA
                                            10-14-2025, 01:48 PM
                                          • Adam Russ
                                            Black screen on Sony 65x90ch (65x900h from Costco)
                                            by Adam Russ
                                            Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
                                            09-15-2024, 05:46 PM
