Hello all. Sony XBR-75X800G - Android start up only and dark blue screen. Back lighting works. Music just repeats itself. Remote has limited function. Ive search for model # here but I did not find anything. Thinking its T-con but I dont have what type of numbers Im to have when reading on a MM. Any help would be great. TV is 5 years old. Thanks
Oh thanks nomoresonys appreciate the fast response. I dont see my model number in his video breakdown. Can I assume that a similiar model XBR-75X850F will have the same voltage readings Im looking for?Comment
I believe he said it's from about 2015-2020 models, I think yours is around 2019 so I'm thinking it should be pretty similar, F is probably 2018.Last edited by nomoresonys; 07-07-2024, 11:03 AM.Comment
why are you speaking of tcon? is there an android logo right? So software seems stuck, don't waste time probing around, have you ever resoldered an emmc or ram chip? In this like many others my bet is bad bga chips, ram and/or emmc and eventually subsequent memory data error, i'm not a master in these sit. but without memory dump an attempt could be resoldering emmc then try recovery mode and/or usb update, but ram suspect is been left back so.. to better understand the first move could be freeze all ram chips and fire start tv, if no go freeze emmc and retry.. good luck
PS: have u got thermo camera?Last edited by Davi.p; 07-07-2024, 11:51 AM.Comment
Davi.p yes, after ready much info, the soft music I can only hear is what I believe to be the Android start up sounds. And as it plays for a little while, it comes to an end, then there is a moment of silence, then the jingle repeats itself. That is getting over my head ( follow for bad ram or emmc or data ), because I wouldnt even know where to start to look for said items and Im sure its a cheaper way to fix the tv, but if its easier and less time consuming to replace a board, Id rather go that route.Comment
No bruh, Im not saying you are wrong in any manner. I just dont know if i have the capabilities to be removing bad ram or emmc or data pieces. It would be easier for me to know if it was the main board or T-com itself and just pay the extra and get a good known working board.Comment
Well Nick IS a "Master" if he says probe and check, then definitely probe and check, THAT is how you narrow down to get to the issue, sonys are 1 of the hardest tvs to diagnose, nick has done a thousand, anyone else here done that many? he don't have to guess. Anyone here to "learn" should learn from an expert like Nick and save the guessing.Last edited by nomoresonys; 07-08-2024, 04:54 AM.Comment
its much likely Main Boards... but because you have dark blue picture, you need to testing the screen as standalone, if every things went correct then replacing MB.. you will not able to repair the boards. as its just ONE Soc ,
to do screen standalone test ..
disconnect the MB from PSU
disconnect the LVDS between T-CON & MB from T-con side
on the socket of the PSU, you need to jumper
Pin 5 STBY_3.3V to PIN 9 Power_ON & pin 7 BL_ON & pin 26 T-CON_ON check the pins No. you have print chart on the boards... it may my memories went weak
take 12V from the pin 25 T-CON VCC and put it on the F fuse on the T-con
put it in wall and check what you will have on the screen..
Note if you are not sure by pins name or No... use 1KR when you do the jumpers to avoid any damage to PSU in case you did wrong at pins order
Note 2 you can do hard reset from plug it out from wall . press joystick and push down then plug in wall leave the push only when the front LED change from white to greenComment
Tv is around 5 years old, lots of sony emmc's die around this age, what seems like a pretty straight forward easy test is test voltages of the mlc caps around the emmc, if you have the usual 1.8 and 3.3 volts then more than likely the emmc chip IS bad. Maybe others here that know the procedure can verify.Comment
thats true about eMMC, speically this set which its from SK Hynix..but he had sound and dark blue screen... it mean eMMC data are fine but the GPU of the Soc tBGA or other reason... testing T-CON and screen standalone are the way we do start.in such issue.Tv is around 5 years old, lots of sony emmc's die around this age, what seems like a pretty straight forward easy test is test voltages of the mlc caps around the emmc, if you have the usual 1.8 and 3.3 volts then more than likely the emmc chip IS bad. Maybe others here that know the procedure can verify.Comment
Thanks for clarification Diah, these sonys are tricky.Last edited by nomoresonys; 07-08-2024, 10:54 AM.Comment
Do you know which sound is the determiner, with one of mine that I didn't think was worth the mainboard investment, I had the sony android startup music and was thinking emmc was dead, do you think that was correct?Comment
there are 2 sounds, one start melody which can be turn off from user setting, the second one melody will start after hard reset as i mentioned early.. after choice at first install the language and land will stopComment
It wasn't the familiar little start melody, it was the ocean like sounding of the andriod i believe.Comment
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... -
by ulthiMy tv is not able to turn on. I flashes between black and vague blue screen (see video)
I have tried different resets and have also replaced the main board - but nothin has changed.
Any suggestions?
https://youtu.be/acYQ-ImmhWA
by Adam RussWeird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
- Loading...
