Sony XBR-75X800G - Android start up only and dark blue screen
    • 12274
    • U.S.
    Thanks for direction, I'll check on it, was just a quick question, don't want to get the thread off course, maybe send me a pm or respond on my sony thread, you are the Master, Thanks.
    • NolesFan
      trying to learn
      • Jul 2024
      • 94
      Thanks guys for the info, Ill try to look into it tonight if I can but I have an odd question. I noticed yesterday when trying to do some testing, I was getting odd readings. I checked voltage at power cable where it meets PSB, and it read just 94v and this was on 2 different MMs to be sure. I then checked my outlet ( thinking maybe I had a bad common ) and it tested out at 120. Is that reading of 94 normal at the PSB? Im guessing no, because its just a cord and shouldn't have that sort of voltage drop thru the OEM cord.
      Also this TV is new to me, so I'm only guessing on the Android start up sound. I hadn't realized there were 2 different sounds. Ill try to get a recording tonight if that will help with further diag.
      • NolesFan
        trying to learn
        • Jul 2024
        • 94
        Originally posted by Diah
        its much likely Main Boards... but because you have dark blue picture, you need to testing the screen as standalone, if every things went correct then replacing MB.. you will not able to repair the boards. as its just ONE Soc ,
        to do screen standalone test ..
        disconnect the MB from PSU
        disconnect the LVDS between T-CON & MB from T-con side
        on the socket of the PSU, you need to jumper
        Pin 5 STBY_3.3V to PIN 9 Power_ON & pin 7 BL_ON & pin 26 T-CON_ON check the pins No. you have print chart on the boards... it may my memories went weak
        take 12V from the pin 25 T-CON VCC and put it on the F fuse on the T-con
        put it in wall and check what you will have on the screen..
        Note if you are not sure by pins name or No... use 1KR when you do the jumpers to avoid any damage to PSU in case you did wrong at pins order
        Note 2 you can do hard reset from plug it out from wall . press joystick and push down then plug in wall leave the push only when the front LED change from white to green
        Diah Just so I understand you correctly. Jump Pin 5 to Pin 9 7 26 OR Jump 5 to 9 & 7 to 26 ( if your memory is correct ). Then Jump Pin 25 to the fuse on the T-con.
        • Diah
          • Feb 2013
          • 6435
          yes you are correct... on the power boards you have listed print chart of pins assignment No and name... do it correctly as name i wrote and the pins No as you have on the print chart
          • Diah
            • Feb 2013
            • 6435
            just be careful. on the socket you have 2 lines of pins Odd and even lol
            make video to see how blue dark... you may have BL issue and then the red front LED blinks 5 time
            • NolesFan
              trying to learn
              • Jul 2024
              • 94
              Which is correct though
              Jump Pin 5 to all three Pin 9 7 26
              Jump 5 to 9 & jump 7 to 26
              Ill try to make the video for you. I also have sound clip I just need to load it. The front LED never changes or flashes. When powered on it always stays solid white.​
                • 12274
                • U.S.
                #27
                If you have not, just unhook power cord from powerboard, plug just the cord into outlet and check voltage at end of cable without it hooked up to powerboard.
                • NolesFan
                  trying to learn
                  • Jul 2024
                  • 94
                  116.4 OEM cord by itself plugged in to wall
                  94.7 OEM cord plugged into harness in to the wall
                  • NolesFan
                    trying to learn
                    • Jul 2024
                    • 94
                    Here are 2 videos. One video is start up from being off. White light comes on bright then dims some but stays constant. Other video is slight movement and then from side.
                    Having trouble loading sound clip, file types are not aloud, but you can kind of hear it in video
                    • NolesFan
                      trying to learn
                      • Jul 2024
                      • 94
                      My pin location chart: Click image for larger version
                      • Diah
                        • Feb 2013
                        • 6435
                        connect pins 5 - 7 -9 -26 all together
                        connect one of pins 25-27-28 to T-CON fuse
                        the melody you have first setup screen... . before you do the standalone test do as i wrote at post #14 Note 2
                        measurement wall socket should be in AC not DC
                          • 12274
                          • U.S.
                          #32
                          Seems like theres something wrong with the power cord, it should be very close to 120 both unhooked and hooked to powerboard.
                          • NolesFan
                            trying to learn
                            • Jul 2024
                            • 94
                            Well not sure how to explain it, but its working. I started checking over the PB to MB harness, because I wasnt getting any reading on the STB or the ON voltage. So I unclipped the harness to make sure I was getting my probe in there to touch metal to get a reading and when I plugged the clip back in, I noticed the lights were changing, so I checked the screen and sure enough the TV started up, and was like it was just purchased, asked me to register and choose language and blah blah blah. Just want to thank the guys who put in effort to respond to me, it is much appreciated.
                              • 12274
                              • U.S.
                              #34
                              Glad to hear it, must have been a bad connection, sometimes it just takes cleaning or unpulg and replug a few times to get it working, curious if the voltage at powercord was still less than 120.
                              • NolesFan
                                trying to learn
                                • Jul 2024
                                • 94
                                Ill check tonight when home from work. Once it was working, I left it on overnight thru today to see if it would stay on. If it is, I suppose Ill invest in at least a new cord. Weird how that works, wonder how many people just toss tvs thinking its not worth fixing. This one I picked up for 50$
                                • Diah
                                  • Feb 2013
                                  • 6435
                                  i mentioned yours eMMC Data in tact and yours melody first install... if the user don't know like David. keep silent other wise all TV will be in rubbish
                                    • 12274
                                    • U.S.
                                    #37
                                    You are correct sir, I would rather be the last one with the solution than be the first one to jump in with pure guess and speculation. Why drag someone down the wrong path when simple testing can determine the issue.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4458
                                      • Italy - Milan
                                      #38
                                      Don't think you have solved, i never seen so a stupid "repair" (well, it repaired itself), so the fault will come back.. also power kcord discourse is out of reason, with 26v at many amps you would have hot melting cable (200+W dissipating..)
                                      • NolesFan
                                        trying to learn
                                        • Jul 2024
                                        • 94
                                        Well tv has run 24 hours so far. Just shut it down, Ill see tomorrow if it powers on. The voltage though was scary, at the connector and fuse, with a Fluke and a Klein 66.8 and 66.7volts. Curious if the lessening of the voltage as time goes on was a reason for shut down? Physically there is nothing wrong with cord, Id like to think buying a new cord would change, but ? Suppose I could always make a new test cord and try that first.
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4458
                                          • Italy - Milan
                                          #40
                                          You have a Fluke and you are not able to use it? Strange.. the power cord has surely no loss, but a test of it with ohm mode cannot let loose huge time.. don't waste time/money with a new cable, this is ridicolous.. a simple check is enough... "IF"" it's ok.. no.. scince it is ok the.main suspect is a bad wiring of wall plug, have you transferred the monster tv to another place and checked it? I suppose no since the size of it..
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • Chrissygizmo
                                            Sony KD-55XG9505 lines on screen problem
                                            by Chrissygizmo
                                            Hello again everyone,
                                            This is my latest mission, to try getting this Sony tv back to normal working order…
                                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                            02-19-2025, 11:31 AM
                                          • Adam Russ
                                            Black screen on Sony 65x90ch (65x900h from Costco)
                                            by Adam Russ
                                            Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
                                            09-15-2024, 05:46 PM
                                          • Ihandyrepair
                                            sony 55X850D black screen no front white or red led light.
                                            by Ihandyrepair
                                            Hi guys
                                            strange one
                                            I have a dead Sony 55X850D
                                            when plug in, black screen, no front white or red LED, no back light no screen
                                            Voltages I get
                                            3.3v LD/power and main board
                                            reg 12V
                                            reg 19V
                                            3.3v on power on pin
                                            no Tcon on
                                            no tcon 12v
                                            no BL_on
                                            I do get BL_ERR 2.0v
                                            I tried to bypass it by ground it but still get same symptom
                                            I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                                            or is possible the chip next to...
                                            08-07-2024, 04:58 AM
