Sony XBR-75X800G - Android start up only and dark blue screen
  • NolesFan
    trying to learn
    • Jul 2024
    • 94
    Hello all. Sony XBR-75X800G - Android start up only and dark blue screen. Back lighting works. Music just repeats itself. Remote has limited function. Ive search for model # here but I did not find anything. Thinking its T-con but I dont have what type of numbers Im to have when reading on a MM. Any help would be great. TV is 5 years old. Thanks
    • 12276
    • U.S.
    https://www.youtube.com/watch?v=Enf8AEjeMbs
    • NolesFan
      trying to learn
      • Jul 2024
      • 94
      Oh thanks nomoresonys appreciate the fast response. I dont see my model number in his video breakdown. Can I assume that a similiar model XBR-75X850F will have the same voltage readings Im looking for?
        • 12276
        • U.S.
        I believe he said it's from about 2015-2020 models, I think yours is around 2019 so I'm thinking it should be pretty similar, F is probably 2018.
        • NolesFan
          trying to learn
          • Jul 2024
          • 94
          Great, thank you. Ill give it listen and try things out. Ill return if I need more help ( which will be highly likely ).
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4459
            • Italy - Milan
            why are you speaking of tcon? is there an android logo right? So software seems stuck, don't waste time probing around, have you ever resoldered an emmc or ram chip? In this like many others my bet is bad bga chips, ram and/or emmc and eventually subsequent memory data error, i'm not a master in these sit. but without memory dump an attempt could be resoldering emmc then try recovery mode and/or usb update, but ram suspect is been left back so.. to better understand the first move could be freeze all ram chips and fire start tv, if no go freeze emmc and retry.. good luck
            PS: have u got thermo camera?
            • NolesFan
              trying to learn
              • Jul 2024
              • 94
              Davi.p no logo at all, just complete dark blue screen with soft music playing. No thermo camera on hand. Have access to one thru the week though.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4459
                • Italy - Milan
                what you mean: "android startup only..."? With Music repeat you mean startup jingle i guess, so the discourse does not change, have to follow for bad ram or emmc or data
                • NolesFan
                  trying to learn
                  • Jul 2024
                  • 94
                  Davi.p yes, after ready much info, the soft music I can only hear is what I believe to be the Android start up sounds. And as it plays for a little while, it comes to an end, then there is a moment of silence, then the jingle repeats itself. That is getting over my head ( follow for bad ram or emmc or data ), because I wouldnt even know where to start to look for said items and Im sure its a cheaper way to fix the tv, but if its easier and less time consuming to replace a board, Id rather go that route.
                  • NolesFan
                    trying to learn
                    • Jul 2024
                    • 94
                    Also, if this helps in any way, when I turn on the TV, the optical port light comes on and all 3 of the USB ports have power.
                    EDIT: Also the fuse on the T-com has continuity.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4459
                      • Italy - Milan
                      This i want you to explain... if you are sure that my advices are wrong tell me at least why, i'm here only to learn..
                      • NolesFan
                        trying to learn
                        • Jul 2024
                        • 94
                        No bruh, Im not saying you are wrong in any manner. I just dont know if i have the capabilities to be removing bad ram or emmc or data pieces. It would be easier for me to know if it was the main board or T-com itself and just pay the extra and get a good known working board.
                          • 12276
                          • U.S.
                          Well Nick IS a "Master" if he says probe and check, then definitely probe and check, THAT is how you narrow down to get to the issue, sonys are 1 of the hardest tvs to diagnose, nick has done a thousand, anyone else here done that many? he don't have to guess. Anyone here to "learn" should learn from an expert like Nick and save the guessing.
                          • Diah
                            • Feb 2013
                            • 6435
                            its much likely Main Boards... but because you have dark blue picture, you need to testing the screen as standalone, if every things went correct then replacing MB.. you will not able to repair the boards. as its just ONE Soc ,
                            to do screen standalone test ..
                            disconnect the MB from PSU
                            disconnect the LVDS between T-CON & MB from T-con side
                            on the socket of the PSU, you need to jumper
                            Pin 5 STBY_3.3V to PIN 9 Power_ON & pin 7 BL_ON & pin 26 T-CON_ON check the pins No. you have print chart on the boards... it may my memories went weak
                            take 12V from the pin 25 T-CON VCC and put it on the F fuse on the T-con
                            put it in wall and check what you will have on the screen..
                            Note if you are not sure by pins name or No... use 1KR when you do the jumpers to avoid any damage to PSU in case you did wrong at pins order
                            Note 2 you can do hard reset from plug it out from wall . press joystick and push down then plug in wall leave the push only when the front LED change from white to green
                              • 12276
                              • U.S.
                              Tv is around 5 years old, lots of sony emmc's die around this age, what seems like a pretty straight forward easy test is test voltages of the mlc caps around the emmc, if you have the usual 1.8 and 3.3 volts then more than likely the emmc chip IS bad. Maybe others here that know the procedure can verify.
                              • Diah
                                • Feb 2013
                                • 6435
                                thats true about eMMC, speically this set which its from SK Hynix..but he had sound and dark blue screen... it mean eMMC data are fine but the GPU of the Soc tBGA or other reason... testing T-CON and screen standalone are the way we do start.in such issue.
                                  • 12276
                                  • U.S.
                                  Thanks for clarification Diah, these sonys are tricky.
                                    • 12276
                                    • U.S.
                                    Do you know which sound is the determiner, with one of mine that I didn't think was worth the mainboard investment, I had the sony android startup music and was thinking emmc was dead, do you think that was correct?
                                    • Diah
                                      • Feb 2013
                                      • 6435
                                      there are 2 sounds, one start melody which can be turn off from user setting, the second one melody will start after hard reset as i mentioned early.. after choice at first install the language and land will stop
                                        • 12276
                                        • U.S.
                                        It wasn't the familiar little start melody, it was the ocean like sounding of the andriod i believe.
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • Adam Russ
                                          Black screen on Sony 65x90ch (65x900h from Costco)
                                          by Adam Russ
                                          Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
                                          09-15-2024, 05:46 PM
                                        • Ihandyrepair
                                          sony 55X850D black screen no front white or red led light.
                                          by Ihandyrepair
                                          Hi guys
                                          strange one
                                          I have a dead Sony 55X850D
                                          when plug in, black screen, no front white or red LED, no back light no screen
                                          Voltages I get
                                          3.3v LD/power and main board
                                          reg 12V
                                          reg 19V
                                          3.3v on power on pin
                                          no Tcon on
                                          no tcon 12v
                                          no BL_on
                                          I do get BL_ERR 2.0v
                                          I tried to bypass it by ground it but still get same symptom
                                          I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                                          or is possible the chip next to...
                                          08-07-2024, 04:58 AM
