Sony LED 65X9005A shuts down after few seconds - looking for help
  • Diah
    • Feb 2013
    • 6499
    so now you have 4 parts only fly out
    • tec3000
      • Mar 2024
      • 119
      Originally posted by Diah
      no its not worse,, the empty trace at COF ribbon cable are normal... only the parts you found keep them spectated as photos location to bring them back by soldering
      Thank you Diah. OK I'm relieved. I thought they were traces of burning or something...
      Now, what happens if I solder them and it doesn't solve my problem? I tried to google the buffer boards for my model but can't find anything! And I'm not sure if I really have all lost parts. They are super tiny...
      • tec3000
        • Mar 2024
        • 119
        maybe more. I will need to inspect further. It's tiny and there is also a lot of dirt inbetween. I can't be sure right now.
        • Diah
          • Feb 2013
          • 6499
          don't hurry... i think lotas eyes better than my as he discovered... so let wait on lotas advice of the location then you can start soldering them back
          • tec3000
            • Mar 2024
            • 119
            Ok thank you, I have also no experience in soldering and no device here. But I will do it of course if that solves the problem.
            • Diah
              • Feb 2013
              • 6499
              it will be good idea to post photo on each 4 caps you found to see them clearly
              • lotas
                • Jan 2016
                • 4809
                • Russia
                #247
                Everything I saw, the most important thing is not the capacitors, here you need to solder a zero resistor or put a jumper on the chip.
                • lotas
                  • Jan 2016
                  • 4809
                  • Russia
                  #248
                  It's hard to see on this bar...
                  • tec3000
                    • Mar 2024
                    • 119
                    Thank you lotas I appreciate you took time to inspect the bars and marked them.
                    So, just to check... You say "solder a zero resistor or put a jumper on the chip". Does that mean I DO NOT need to solder back the parts that fell off?? Instead I have to buy some resistors and solder them on each bar? And you say OR jumper? So is that an option I have? I have zero experience with these things...
                    I retook pics of the second board. I can also retake better pics of the other board if you like.
                    • Diah
                      • Feb 2013
                      • 6499
                      you mean R007.. i don't think its in use,.... OP you need to shoot very clear photo on the area close to the IC
                      • tec3000
                        • Mar 2024
                        • 119
                        OK, I think it's best to shoot during daylight. It's extremely hard to get good pics right now. I will do ASAP.
                        • Diah
                          • Feb 2013
                          • 6499
                          don't use the mobile camera in flash light mode... just use external light like ( torch ) on the area
                          • tec3000
                            • Mar 2024
                            • 119
                            Ok, will do! Thank you for the suggestion.
                            • lotas
                              • Jan 2016
                              • 4809
                              • Russia
                              #254
                              R007 is torn off and hanging on one side, if it is alive (has a short circuit), then just solder it on both sides.
                              • lotas
                                • Jan 2016
                                • 4809
                                • Russia
                                #255
                                Check R2, it should also show a short circuit (0 Ohm).
                                • lotas
                                  • Jan 2016
                                  • 4809
                                  • Russia
                                  #256
                                  And then check RH4, it’s hard to see.
                                  • Diah
                                    • Feb 2013
                                    • 6499
                                    yours photo , here could be parts falling down too
                                    • tec3000
                                      • Mar 2024
                                      • 119
                                      Ah! I forgot to tell you about it. I was able to identify the mysterious "L" on the left bottom of the TV. Luckily I didn't even have to disassemble anything. One problem less!
                                      • tec3000
                                        • Mar 2024
                                        • 119
                                        I have retaken the pictures. I will upload them now.
                                        • tec3000
                                          • Mar 2024
                                          • 119
                                          this is board 1:
                                          • riko 656
                                            Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                            by riko 656
                                            I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                            Laptop Model:
                                            • Model: Lenovo Legion Slim 5 16APH8
                                            • GPU: NVIDIA GeForce RTX 4070
                                            • Main BIOS chip size: 32MB
                                            • VBIOS chip size: 16MB
                                            Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                            What I Have Tried So Far:
                                            1. I
                                            11-04-2025, 05:14 AM
                                          • mauda
                                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                            by mauda
                                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                            05-21-2023, 11:56 PM
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • riki_22
                                            ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                                            by riki_22
                                            I’m working on an ASUS B5402CEA notebook.
                                            B5402CEA_MB_R2.2
                                            HA4YT LA-L861P
                                            REV:1B
                                            The board powers on, fan spins for a few seconds, then it shuts down by itself.
                                            I suspect the BIOS might be corrupted.
                                            Could someone please check and clean (repair) the attached BIOS dump?
                                            I’ve also attached a few photos of the motherboard for reference.
                                            Thanks in advance for your help!
                                            11-03-2025, 04:38 AM
                                          • APOPAP
                                            Panasonic National NV-M3 VHS Camera shuts down after some seconds
                                            by APOPAP
                                            Hello everybody,
                                            First post here. I have been reading posts here for some time now, but today I made my first account and post.
                                            The same question is also posted on another site, here it is:
                                            Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                                            I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                                            08-25-2025, 10:12 AM
