Sony LED 65X9005A shuts down after few seconds - looking for help
  • Diah
    • Feb 2013
    • 6502
    Originally posted by tec3000
    (I wrote it above. It was just a reflection!)
    Thank you for the detailed description. I will do this now but before I need to know something: what and where is the U ribbon cable??
    • tec3000
      • Mar 2024
      • 119
      Originally posted by Diah
      I was hoping you'd say that! Because I have just discovered something! One of the U ribbon cables is ripped. That's good news right? Likely the cause for my issue??
      • Diah
        • Feb 2013
        • 6502
        yes it is.... but still could be there another issue,, caused by smell and smoke lol
        • tec3000
          • Mar 2024
          • 119
          Should I order the U ribbon cable right away or should I go ahead with the testing you described earlier?
          • lotas
            • Jan 2016
            • 4813
            • Russia
            #225
            + Missing components.
            • Diah
              • Feb 2013
              • 6502
              first inspect as mentioned bu lotas.. then need the u ribbon
              • Diah
                • Feb 2013
                • 6502
                U ribbon cable should with long and pins amount calculated
                • lotas
                  • Jan 2016
                  • 4813
                  • Russia
                  #228
                  Why such complexity, we just type the number 69.65T10.T01 into a search engine and see a bunch of offers.
                  • Diah
                    • Feb 2013
                    • 6502
                    remove this defect U ribbon.. and put yours original t_CON and the new 4 ribbon in place.... you should have 3/4 screen display clear image
                    • tec3000
                      • Mar 2024
                      • 119
                      Not sure if something is missing? I have the TV in this room and there is also nothing that fell off...
                      I have attached two pics. Please take a look.
                      • tec3000
                        • Mar 2024
                        • 119
                        I removed the defect one and changed places with the working one. Unfortunately I don't have a clear image.
                        With MY t-con board I got only weird lines on the right. (Pic1)
                        With the t-con board from China it looks a tiny bit better Pic2.
                        It's baffling. So it's not just the U ribbon cable unfortunately Maybe it's the LVDS cable?
                        And before I ordered the t-con board and the 4 ribbon cables I DID plug and unplug the 4 ribbon cables WHILE the TV was running. That's why I'm in this mess now...
                        • lotas
                          • Jan 2016
                          • 4813
                          • Russia
                          #232
                          Well, isn’t there something you can’t see already? Take a magnifying glass and inspect all the planks for any broken components.
                          • Diah
                            • Feb 2013
                            • 6502
                            not good at all.... what you did man...
                            take out the screen.. be careful don't add more damage.. so we will have access to whole panel buffer boards to compare the other side with this damage and to know what kind of Cap installed.. and don't use your original t-con too
                            • tec3000
                              • Mar 2024
                              • 119
                              Guys, as always you are correct. Pieces fell off. Almost on all of the buffer boards. Not only that... FCK....
                              I am trying to capture it on camera now. It's a challenge but I'm almost done. Pictures will follow shortly.
                              • tec3000
                                • Mar 2024
                                • 119
                                ok, I will do 4 posts with pics of each board. Worst board is 3. But first here pics of buffer board 1:
                                • tec3000
                                  • Mar 2024
                                  • 119
                                  this is board 2:
                                  • Diah
                                    • Feb 2013
                                    • 6502
                                    you are lucky boy you find the missing 2 parts hold them don't lost it but keep them separated as the photos name to know loxation
                                    • tec3000
                                      • Mar 2024
                                      • 119
                                      the worst board. Board 3. Look at the vertical white stripes:
                                      • tec3000
                                        • Mar 2024
                                        • 119
                                        and board 4:
                                        • Diah
                                          • Feb 2013
                                          • 6502
                                          no its not worse,, the empty trace at COF ribbon cable are normal... only the parts you found keep them spectated as photos location to bring them back by soldering
                                          • riko 656
                                            Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                            by riko 656
                                            I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                            Laptop Model:
                                            • Model: Lenovo Legion Slim 5 16APH8
                                            • GPU: NVIDIA GeForce RTX 4070
                                            • Main BIOS chip size: 32MB
                                            • VBIOS chip size: 16MB
                                            Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                            What I Have Tried So Far:
                                            1. I
                                            11-04-2025, 05:14 AM
                                          • mauda
                                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                            by mauda
                                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                            05-21-2023, 11:56 PM
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • riki_22
                                            ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                                            by riki_22
                                            I’m working on an ASUS B5402CEA notebook.
                                            B5402CEA_MB_R2.2
                                            HA4YT LA-L861P
                                            REV:1B
                                            The board powers on, fan spins for a few seconds, then it shuts down by itself.
                                            I suspect the BIOS might be corrupted.
                                            Could someone please check and clean (repair) the attached BIOS dump?
                                            I’ve also attached a few photos of the motherboard for reference.
                                            Thanks in advance for your help!
                                            11-03-2025, 04:38 AM
                                          • APOPAP
                                            Panasonic National NV-M3 VHS Camera shuts down after some seconds
                                            by APOPAP
                                            Hello everybody,
                                            First post here. I have been reading posts here for some time now, but today I made my first account and post.
                                            The same question is also posted on another site, here it is:
                                            Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                                            I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                                            08-25-2025, 10:12 AM
