Sony LED 65X9005A shuts down after few seconds - looking for help
  • lotas
    • Jan 2016
    • 4708
    • Russia
    #161
    It shouldn’t be like this, you have the maximum current flowing to this strip (the driver may not be fixed or the mosfet on this channel is broken) and these LEDs will not last long.
    • Diah
      • Feb 2013
      • 6412
      Man, the TV with out signal..... ( MO SIGNAL ) sign will show on the top left of the screen.,, this strip are lighting more... this is the local dimming process.. after he put the screen in place and fed it with signal then yours theory will be checked if there issue with lighting.
      • lotas
        • Jan 2016
        • 4708
        • Russia
        #163
        And when the "SONY" screensaver lights up, should this corner also light up?
        • Diah
          • Feb 2013
          • 6412
          no screen saver.. only option at setting to turn off if no signal... who knows if it set on.. we wait and we will see the screen how it look with signal
          • lotas
            • Jan 2016
            • 4708
            • Russia
            #165
            Let him press the MENU button with the remote control and see if the local backlight changes or not!
            • tec3000
              • Mar 2024
              • 119
              Originally posted by Diah
              dont bother of more light or less... you don't have the screen in place and no signal the dimming process will be different.., put every things bask as it should.
              ok perfect. I'll try to it today. Will give an update when I'm done.
              • tec3000
                • Mar 2024
                • 119
                Right now it's impossible to test. I should do it when I have everything back in place, right???
                • Diah
                  • Feb 2013
                  • 6412
                  we saw from early photo of his LED driver boards not in good shape... many over load mark had on the boards.... still this is not important now... he got rid off the issue turning off... later if screen in place will be clear to judge and another repair steps take in place if there issue with lighting.. right now put every things back
                  • tec3000
                    • Mar 2024
                    • 119
                    Ok, I was able to put everything back together. TV doesn't shut off anymore! And I was surprised to see that light output was even. It wasn't blown out on one corner!
                    But I have new problems....
                    Picture had weird artefacts AND two green thick vertical lines. I was able to get rid of one line when I played around with one LVDS cable. (Pic 1 and Pic 2)
                    So silly me thought it was a good idea to keep the TV on while disconnecting and reconnecting the LVDS cables. I think something must have happened there because since then whatever I do I only get a washed out white image (Pic 3).
                    And in Pic 4 you see the cables. I circled a few spots. Do you think it's just the cables that I need to replace or do I need a new T-Con board? ://
                    I know I somehow messed it up again
                    • Diah
                      • Feb 2013
                      • 6412
                      good work for you as it first time to be encourage to take TV in parts and yon have less info on parts..
                      the end result of line or green line now more noticeable to you.... try to clean LVDS and ribbon cables with out damage them..... other wise you can live with it.
                      • lotas
                        • Jan 2016
                        • 4708
                        • Russia
                        #171
                        There is no need to clean it, but it needs to be changed, 1.2 pins do not have contact with the connector.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4421
                          • Italy - Milan
                          #172
                          them are hard to find parts maybe, a restoration could be made, but needs expert hands / tools..
                          this is not a tv for homemade repairs i think, generally i see not a good job (halo areas and etc..)
                          • tec3000
                            • Mar 2024
                            • 119
                            so this is how my tv now looks
                            • lotas
                              • Jan 2016
                              • 4708
                              • Russia
                              #174
                              Click image for larger version  Name:	1713909612508.jpg Views:	0 Size:	1.64 MB ID:	3259172
                              I wrote above that now we need to change the cables, what kind of defect is there on the panel, a crack?
                              • tec3000
                                • Mar 2024
                                • 119
                                Yeah, I didn't even mention that yesterday because of the bigger problem. Luckily it's not a crack. I'm not sure what it is. It happened after I put everything back. Something on one of the sheets maybe? Like a piece of tape? I'm not sure. But it's definitely not a crack.
                                About the cables: Can you guys help me find the correct ones? I don't know what to search for. You have some eBay/Amazon link? That would really help. Don't wanna buy something wrong.
                                And it's also possible I need a new t-con board cause it started smelling. I think I did a short circuit, but I'm not sure.
                                Maybe buy new cables first and see how it goes?
                                • lotas
                                  • Jan 2016
                                  • 4708
                                  • Russia
                                  #176
                                  First, inspect all four connectors under a magnifying glass to see if there are any traces of conductors left inside them from the cables (they can short-circuit the contacts).
                                  • tec3000
                                    • Mar 2024
                                    • 119
                                    Alright, I will do it shortly.
                                    • lotas
                                      • Jan 2016
                                      • 4708
                                      • Russia
                                      #178
                                      https://www.ebay.com/p/1437635637
                                      • tec3000
                                        • Mar 2024
                                        • 119
                                        Thank you. But that's with a t-con board. I first wanna replace the cables first.
                                        • lotas
                                          • Jan 2016
                                          • 4708
                                          • Russia
                                          #180
                                          But if the T-con board stinks, then it may have suffered too, but here is a complete set and just for your “65” panel, well, it’s up to you to decide.
                                          • mauda
                                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                            by mauda
                                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                            05-21-2023, 11:56 PM
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • APOPAP
                                            Panasonic National NV-M3 VHS Camera shuts down after some seconds
                                            by APOPAP
                                            Hello everybody,
                                            First post here. I have been reading posts here for some time now, but today I made my first account and post.
                                            The same question is also posted on another site, here it is:
                                            Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                                            I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                                            08-25-2025, 10:12 AM
                                          • solveit68
                                            Lenovo L580 20LW-0010GE shuts down after a few seconds
                                            by solveit68
                                            Hello together,
                                            I am hoping for some tips here to repair a notebook.
                                            The notebook has following issue:
                                            After starting the notebook it shut down after a few seconds.
                                            Sometimes it is possible to enter the bios but then after, another few seconds it shuts down also.
                                            The time until shutdown varies slightly.
                                            What I've tried so far:
                                            - cmos cleared
                                            - removed all components that are not essential for motherboard testing including keyboard and touchpad
                                            - ram exchanged
                                            - same behaviour with power supply or battery...
                                            07-21-2023, 01:04 PM
                                          • doejohn11
                                            Lenovo Legion 5 17ach6h shuts off after 70 seconds.
                                            by doejohn11
                                            Hello guys. I have a legion 5 17ach6h with Ryzen 7 5600h and RTX3060.
                                            It was working perfectly fine but the cpu was overheating so i decided to replace thermal paste. I bought one from local hardware store and replcaed. it looked fine then the fan started to spin at the full speed after about 1 minute and then immediately shut off after 10 seconds. Then I though if i have done something wrong, so i cleaned up everything with IPA and put new thermal paste. but the issue was still there. After that, I came across this article where he had similar issue and he was able to solve it by replacing...
                                            04-19-2025, 07:38 AM
