samsung 58 inch plasma
  • adamp91gvm
    • Jan 2014
    • 699
    hi i have a plasma samsung there is no picture at all sound is there but the screen does not even flicker in the dark the logic board on it just flashes 1 green led it does not flash on the front just like its on but with no picture any ideas u guys thanks
  • freakaftr8
    • Oct 2012
    • 3743
    Re: samsung 58 inch plasma
    First we need model numbers and clear pictures of the boards inside.the tv.
    Time to start checking voltages. you need a voltmeter and test voltages from the power supply outputs to the y and z main boards. There are some plug in connectors on the power supply that go to these y and z main boards that are located on each side of the tv. First unplug tv. Take back cover off.
    There is quite a bit of dc voltage in these TVs so be careful with what you are doing. Once you are there you need to locate the output pins for VS and VA. Set your meter on DC voltage auto range. Black lead anywhere like a screw lug on the chassis and red lead VS then VA when powered up.
    Let us know what you find.
    • adamp91gvm
      • Jan 2014
      • 699
      Right it's started clicking and not powering up so im changing all the caps on the power board first it clicks then clicks and then clicks over and over but no sound
      • anotherdude
        • Feb 2013
        • 488
        3 threads all on the same tv yet still no model number
          saying "58 inch Samsung plasma clicking" is about as good as saying "my car won't start, it's a blue Ford."
          • adamp91gvm
            • Jan 2014
            • 699
            It's a pn58b680 t6w
            • adamp91gvm
              • Jan 2014
              • 699
              Any ideas when I turn it on it does not play the start up sound it clicks over and over
                Could be main board, Y-main, X-main, panel.... how about some pictures?
                • hienton2
                  • Sep 2009
                  • 183
                  main board problem . Hard to find this board.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    I would start by disconnecting power lines going to Y and Z sustain boards, with tv unplugged. Then power on and see if it still clicks on and off.
                    • adamp91gvm
                      • Jan 2014
                      • 699
                      • adamp91gvm
                        • Jan 2014
                        • 699
                        • adamp91gvm
                          • Jan 2014
                          • 699
                          • adamp91gvm
                            • Jan 2014
                            • 699
                            • adamp91gvm
                              • Jan 2014
                              • 699
                              • adamp91gvm
                                • Jan 2014
                                • 699
                                on this one im getting a clicking sound on the power board im getting 202 from the vs then the power drops when the second click so it would be . CLICK 202V ........CLICK 201 200 199 198 and so forth
                                • adamp91gvm
                                  • Jan 2014
                                  • 699
                                  i have narrowed it down to being the av board
                                  • adamp91gvm
                                    • Jan 2014
                                    • 699
                                    tom66 any places i could have a look on there to check voltage ?thanks
                                      How did you narrow it down to main board? Did you do the test pattern jumper?
                                      • adamp91gvm
                                        • Jan 2014
                                        • 699
                                        Well I have changed all the caps and I'm getting the right voltage to the main board and I think I may of caught a compasitor on the av board when I was checking it because it did power up just with no pic
                                        • KYBOSH
                                          Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                          by KYBOSH
                                          Saved this beast from the landfill this weekend.
                                          Manfactured July 2013 in Mexico.
                                          I love working on plasma TVs.
                                          Its been a while but I was lucky enough to find 2 this week.
                                          The TV powers on and stays on but no picture. Havent checked for sound yet.
                                          No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                          Will start troubleshooting tonight.
                                          10-17-2024, 01:17 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • joel warren
                                          Looking for some help please. Samsung UN75RU800DFXZA rebooting, no picture, clicks
                                          by joel warren
                                          TV was working fine and then just shutdown one day. It will not turn back on. I get a backlight for a little while, then it just clicks and won't fully boot.
                                          I took off the back panel and did the basic troubleshooting and it seems like it's a panel issue.
                                          The backlight will stay on if I disconnect either of the ribbon cables going to the panel. I've watched this video (https://www.youtube.com/watch?v=77tymvTJDxo) and am wondering if this could be the issue, just a bad cap on the panel.
                                          Any assistance is appreciated.
                                          01-27-2025, 06:31 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
