samsung 58 inch plasma
    Re: samsung 58 inch plasma
    Well, the control board appears to be functioning. So, it must be something more fundamental. Have you got 15V going to each of the X- and Y-main boards?
    • adamp91gvm
      • Jan 2014
      • 706
      • uk
      #182
      No4
      • adamp91gvm
        • Jan 2014
        • 706
        • uk
        #183
        Vcc i have 15.30 to the x main and y main 15.30 v
        • adamp91gvm
          • Jan 2014
          • 706
          • uk
          #184
          The fuses where the wire comes into the power board I get 0v ether end of both of them is that right ?
            That's bad. Can you test the same fuse on the Y-main?
            • adamp91gvm
              • Jan 2014
              • 706
              • uk
              #186
              Yer changed them they get 202 in the y main
                I'm referring to the small little green fuse with leads each end, soldered into the board.
                • adamp91gvm
                  • Jan 2014
                  • 706
                  • uk
                  #188
                  I'm on about the 2 proper like plug fuses
                    Yes can you check both types, maybe highlight voltages on a diagram.
                    • adamp91gvm
                      • Jan 2014
                      • 706
                      • uk
                      #190
                      But on the top green one 15.4v and on the bottom 0.02v
                        That's bad.
                        • adamp91gvm
                          • Jan 2014
                          • 706
                          • uk
                          #192
                          :s
                          • adamp91gvm
                            • Jan 2014
                            • 706
                            • uk
                            #193
                            Where I go from there the bin ha ha
                              Bad, I mean, the fuse is bad. Not that it's a bad thing. Finding blown fuses is good. Try replacing the fuse.
                              • adamp91gvm
                                • Jan 2014
                                • 706
                                • uk
                                #195
                                Ok ill try now
                                • adamp91gvm
                                  • Jan 2014
                                  • 706
                                  • uk
                                  #196
                                  Do they have to be like for like or can I upgrade
                                    Ideally like for like.
                                    • adamp91gvm
                                      • Jan 2014
                                      • 706
                                      • uk
                                      #198
                                      I have a 1al 125v but the one in it is a 500mal 125v ? Can I temp try this
                                        That should be OK but be prepared to quickly pull power. Is a similar fuse on Y-main blown?
                                        • adamp91gvm
                                          • Jan 2014
                                          • 706
                                          • uk
                                          #200
                                          It's on the y main lower fuse on the ymain
                                          • KYBOSH
                                            Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                            by KYBOSH
                                            Saved this beast from the landfill this weekend.
                                            Manfactured July 2013 in Mexico.
                                            I love working on plasma TVs.
                                            Its been a while but I was lucky enough to find 2 this week.
                                            The TV powers on and stays on but no picture. Havent checked for sound yet.
                                            No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                            Will start troubleshooting tonight.
                                            10-17-2024, 01:17 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • joel warren
                                            Looking for some help please. Samsung UN75RU800DFXZA rebooting, no picture, clicks
                                            by joel warren
                                            TV was working fine and then just shutdown one day. It will not turn back on. I get a backlight for a little while, then it just clicks and won't fully boot.
                                            I took off the back panel and did the basic troubleshooting and it seems like it's a panel issue.
                                            The backlight will stay on if I disconnect either of the ribbon cables going to the panel. I've watched this video (https://www.youtube.com/watch?v=77tymvTJDxo) and am wondering if this could be the issue, just a bad cap on the panel.
                                            Any assistance is appreciated.
                                            01-27-2025, 06:31 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
