This topic has been answered.
  • TR103
    • Jan 2025
    • 20
    • Netherlands
    - it keeps rebooting
    - without cable between mainboard and lcd panel and with a jumpered mainboard, it does not reboot and I do have 25V VGH. With the cable connected the VGH drops to 0V. But with the lcd panel connected, it keeps rebooting, even without the ribbon cable (without the jumper it does boot without the ribbon cable)
    Does anyone have any ideas? Is there something else I can test? I know this tv is known for its bad panels, but when I tape off all the clock-signals, it still reboots with no picture. I would like to know what is wrong with it, and why only taping off pin1 (the innermost pin) is the only pin that keeps it from rebooting. The signal on pin1 could be FB_2 (I found this somewhere else on this forum). But what is FB_2? I am ok with writing this tv off, but I would like to learn more, what exactly is the problem?​
  • Answer selected by TR103 at 05-24-2026, 02:41 PM.
    EazyBone
    • Jun 2023
    • 1440
    • United states
    • Anything I can do with my hands
    Screen dies. These 50 inchers are crap.
    • EazyBone
      • Jun 2023
      • 1440
      • United states
      • handsworth
        • Oct 2015
        • 175
        Try this tape off. It got me a picture on a 50TU
        • TR103
          • Jan 2025
          • 20
          • Netherlands
          Thanks handsworth! I haven't tried specific that combination, but one of my tries covered more and even then it won't boot. Here are some photos what I tried already. I also tried covering just pin1 (=innermost pin, not on photos), and that is the only way to get it booting, but no picture.
          • EazyBone
            • Jun 2023
            • 1440
            • United states
            Sometimes tape doesn't work and really can't do anything about it. Could be damaged to screen you haven't seen
            • victrix1
              Samsung QE65S95C (QD-OLED 2023) — no picture/sound, power LED blinks twice
              by victrix1
              I picked up a Samsung QE65S95C (65", QD-OLED, 2023 model) for repair. Symptoms: no picture, no sound. When everything is connected (T-CON + panel + LEDs), the power LED blinks exactly twice and then stops.
              Here is what I have checked and ruled out so far:
              One Connect Box (OCB): the relay clicks and operates normally.
              PSU inside OCB: disassembled and tested standalone — outputs a stable 32V with no load. PSU is good.
              T-CON board: fully disconnected during voltage measurements below.
              Panel / LED strips: fully disconnected...
              06-30-2026, 03:47 PM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
            • JohnML1975
              Samsung UA50TU8000W no picture and no sound
              by JohnML1975
              Hello All
              have seen posts on this model in here but my problem sounded different so thought i would create a thread
              TV will not turn on
              There is no standby light
              When I press ON button for remote the red standby light does flash but no picture and no sound
              From the back of the TV I can see the red light on the back of the mother board
              Holding torch to the screen I cannot see a picture
              I removed the back cover
              Observing the boards I cannot see any damage
              I disconnected the main board from the power supply
              the back...
              08-30-2025, 09:40 PM
