Sanyo DP42849 - No Power At All
  • NihonNoir
    • Jan 2014
    • 231
    • US
    #341
    Re: Sanyo DP42849 - No Power At All
    The results on the IC602, right?
    If you could explain to me in detail how to do the test again, I'll redo it, just in case I did do it incorrectly.
    Thanks!
      You should use diode mode on the secondary/cold side (board unplugged) and see about 1V one way and infinity the other way - though if it is in circuit it might not work.
      You can also check the voltage across each side and be sure that the multimeter probes are touching each pin - verify with continuity check.
      • NihonNoir
        • Jan 2014
        • 231
        • US
        #343
        For IC602, the two legs on the secondary side, diode mode:
        "1" one way
        1253 the other.
        IC 902:
        "1"
        1340
        IC 201:
        "1"
        "1"
        IC903:
        "1"
        1196 (but leads are reversed in comparison to the other ICs)
          IC201 does not look right to me. What part # is printed on it?
          • NihonNoir
            • Jan 2014
            • 231
            • US
            #345
            I'll get that in a second. I redid the voltage test on all of them as well:
            IC902: 0.87 --> 1.93
            IC201: 0 --> 0
            IC602: 0 --> 0
            IC903: 16.57 --> 19.86
            • NihonNoir
              • Jan 2014
              • 231
              • US
              #346
              All 4 ICs have same part number:
                IC201 should test as around 1200~1400 on your meter. So I think it is bad.
                SHARP PC123 optocoupler.
                • NihonNoir
                  • Jan 2014
                  • 231
                  • US
                  #348
                  Let me test one more time to make sure.
                  So those are the optocouplers? LOL I thought it was that shiny yellow thing above them.
                    Shiny yellow thing is probably a transformer.
                    • lookimback
                      • Aug 2013
                      • 1489
                      I have the exact TV with that power supply on my work bench right now. I have to replace an AS15 on the Tcon. I could probably help you with some comparison readings. I won't be home from work until about 9:00 p.m. EST though.
                      ------------signature starts here------------
                      • NihonNoir
                        • Jan 2014
                        • 231
                        • US
                        #351
                        Sweet, thanks!
                        • NihonNoir
                          • Jan 2014
                          • 231
                          • US
                          #352
                          So IC902 and IC903 are oriented the same way in the board, but I have to reverse the leads when doing diode check on them to get comparable readings. Is that normal?
                          • lookimback
                            • Aug 2013
                            • 1489
                            Just post the pins you need readings from and I'll post what I get from them.
                            Not sure What you have for a meter but I have a Fluke model 115. There will probably be slight variations between our readings but they will probably be close enough. I'm sure with Tom's help and my readings we can figure this out.
                              Compared to IC602?
                              • lookimback
                                • Aug 2013
                                • 1489
                                You have to remember that electricity follows the path of least resistance. You probably aren't getting a reading through the component but rather, through the rest of the circuit. Sometimes you have to remove the component to test it.
                                • NihonNoir
                                  • Jan 2014
                                  • 231
                                  • US
                                  #356
                                  I see what the problem was with IC201's reading. It's the only IC whose orientation is reversed. When I test it on the other side - red lead on pin1 - I get 1367.
                                  IC903, 602, and 902 are all situated in the board the same way - here's how I get my diode readings:
                                  IC903: Black on pin 1 - 1196
                                  IC602: Red on pin 1 - 1253
                                  IC201 (reversed in board): Red on pin 1 on PRIMARY side - 1367
                                  IC902: Red on pin 1 - 1340
                                    Electric current does not follow the path of least resistance. Current takes each path with a magnitude inversely proportionally to its resistance.
                                    (Electrical arcs are the only type of current which follows this least resistance idea - i.e. lightning - but that's a different phenomenon to pure electric current.)
                                    • NihonNoir
                                      • Jan 2014
                                      • 231
                                      • US
                                      #358
                                      So IC201 is good, right?
                                      Why is IC903 different?
                                        I wouldn't know why IC903 is different, that is really odd.
                                        • lookimback
                                          • Aug 2013
                                          • 1489
                                          I stand corrected. Thank you for explaining that.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
