sanyo DP32648 tv will not turn on
  • CR Designs
    • Dec 2012
    • 430
    Re: sanyo DP32648 tv will not turn on
    Originally posted by johnboy1313
    Does the other end of the plug that goes into CN902 on the PSU unplug from the main? If so, with the tv unplugged, unplug the inverter board at the inverter board and the main at the main. Run a 1kohm resitor from the hole in the plug for one of the 5V pins to the hole that runs to PS_ON. Plug the tv in and see if you have voltage at 12V and 24V, if so, see if you have voltage at the VINs in the inverter plug. Maybe this set doesn't have a back light on pin.
    Re did the resister test. I have 5v,12v, and 24v on the PSB and have 24 volts at the inverter connector on PSB
    • selldoor
      Slow Learner
      • 7870
      Good- Switch it off - Plug the inverter board in and do the test again and see if the lamps come on.
      • CR Designs
        • Dec 2012
        • 430
        No lamps
        • CR Designs
          • Dec 2012
          • 430
          Any ideas what's going on with this TV?
          • cashkennedy
            • Aug 2011
            • 668
            On most sets there is a wire going to the inverter that tells it to turn on, If you tell us what panel is in this set we can / or you can find the panel data sheet and read how it detects to turn on the backlight, how an error would be communicated from the err pin, and other useful data.
            The panel comes with the inverter, tcon, light box , bulbs so on. It is usually silver backed, and all the boards sit on a frame behind it. There should be a sticker on the silver back somewhere that says a brand like AUO, or CHUNGWAY, or chimei, LG, or samsung, so on, then a model number, we need to know the model number to hopefully find the data sheet on the panel.
            Hopefully there is a pin we need to run a voltage to to turn the backlights on, if not then it might be experiencing an error which may be indicated by a voltage on the error pin while the set is on (on via the 1k ohm resistor trick).
            Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
            • johnboy1313
              • Nov 2012
              • 1959
              The 24v rails on each plug should be connected. When you plug the inverters in and force the psu on do you still have 24v at the plug to the main? Also, it looks like it took two tries or more to get the psu to force on. Are you sure the psu was on when the inverters were plugged in and the lamps didn't come on?
              • CR Designs
                • Dec 2012
                • 430
                Yes have 24v at plug to main and have 24v at plug to inverter
                • CR Designs
                  • Dec 2012
                  • 430
                  Here's panel number Sharp LK325T3LA12
                    Follow up, saw the picture of the inverter connector, the STB PIN IS THE INVERTER ON/OFF pin. But right now I believe you have the problem in the main board which is not sending the PS_ON signal to turn on the power supply. You will have to do in depth main board troubleshooting.
                    please read my basic LCD TV troubleshooting guide.
                    Last edited by budm; 02-15-2013, 10:07 AM. Reason: Found the picture of the Inverter connector.
                    • CR Designs
                      • Dec 2012
                      • 430
                      I will read it thanks budm
                      • CR Designs
                        • Dec 2012
                        • 430
                        Read it bud , with the jumper On PSB plug have 5v,12v, and 24v. where should i start looking on main board
                        • CR Designs
                          • Dec 2012
                          • 430
                          Here's a picture of the Main board
                          • CR Designs
                            • Dec 2012
                            • 430
                            What's next?
                            • cashkennedy
                              • Aug 2011
                              • 668
                              Thats a incredibly complex / proprietary looking board, even the regulators arent basic 3 pin models... Without a really detailed step by step in the service manual (sanyo service manuals are fairly basic) it would be quite hard to diagnose that board.
                              Id recomend checking any fuses on the board / they are usually tiny white rectangular parts with metal on each end, and are usually designated with a F begging the component number printed on the board. You could also probe around carefully for 12v reaching the board near where the connector from the power supply comes in, usually a fuse will be the first stop for the 12v power after coming from the connector .
                              • CR Designs
                                • Dec 2012
                                • 430
                                has me confused
                                • CR Designs
                                  • Dec 2012
                                  • 430
                                  I looked around the board and also where the PSb connects I don't see any fuses. Also how do you check this type of regulator
                                  • cashkennedy
                                    • Aug 2011
                                    • 668
                                    Can you post a better picture of the whole main board, i cant tell if the power is comming from the top right of your current pic, or from the small board in the bottom left that is partially cut off in the picture. A picture of the whole back of the set with all the boards in place might help too if you have one / dont already have all the boards spread out.
                                    I dont know how to test 4-5 pin regulators , if thats even what those parts are, im refering to the ones marked ic6050, and ic6051 in the center. With the part number from them i could probably find a data sheet and figure out whats gate source drain so on and figure out how to test it, but perhaps someone here will know if those are even worth testing on this board.
                                    • CR Designs
                                      • Dec 2012
                                      • 430
                                      Check this picture circled items one has 5v and the other has 1f on it. could that be a fuse? I will get more pictures of boards
                                      • CR Designs
                                        • Dec 2012
                                        • 430
                                        try loading the picture again
                                        • CR Designs
                                          • Dec 2012
                                          • 430
                                          More pictures
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • u666sa
                                            HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                            by u666sa
                                            Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                            Platform: ipa32 la-m024p rev 1b
                                            Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                            I found a short on the other side:
                                            10-04-2025, 05:03 PM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
                                          • masoksian
                                            Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                            by masoksian
                                            I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                            The system does not turn on, there is no post.
                                            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                            The problem continues in the same way.
                                            I tried to turn on the Fn key, nothing came to the screen....
                                            02-15-2025, 12:08 PM
