sanyo DP32648 tv will not turn on
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    #61
    Re: sanyo DP32648 tv will not turn on
    Originally posted by CR Designs
    Selldoor I checked out the youtube video Have no freeze stray Have you ruled out a inverter problem see post 9 of picture of inverter. I couldn't find any fuses.
    I have been checking around main board, but so many components. Is the PSB ruled out ? Selldoor thank you for the help
    I have had another look - there is afuse un the inverter board - its a black
    rectangular one F7500.
    Also johnboy1313 said to jumper the 5v to pson AND to the BLon.
    The 5v to pson worked (so far) yes? but I dont think after Budm advised that
    the BLon was called STB ( On the inverter board )that you tried a jumper
    to that (where does the lead from that connector go)
    • CR Designs
      • Dec 2012
      • 430
      Fuse read oo1. The 5v to pson worked. got 5v,12v and 24v Have not did jumper to BLon. Not sure how to go about it?
      • CR Designs
        • Dec 2012
        • 430
        lead from connector on inverter goes to PSB
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #64
          Sorry - not following this - it has 14 pin designation on the inverter board
          which socket does it go to - cant see one with 14 pins?
          "Fuse read oo1."
          Is that the same as holding your meter probes together or apart?
          • CR Designs
            • Dec 2012
            • 430
            "Fuse read oo1."
            together
            • CR Designs
              • Dec 2012
              • 430
              "Fuse read oo1."
              There are 2 plugs coming off the inverter board one with 10 pins goes to upper left corner of PSB and the other 4 pin plug goes to the main board
              • cashkennedy
                • Aug 2011
                • 668
                In order to start the power supply and test the inverter you need 2 wires. first wire goes from 5v standby + 1000ohm resistor to pson, then you run a 2nd wire and 1000 ohm resistor from 5v on power supply to stb pin on the inverter. Wire that all up with the main board disconected, and the inverter should turn on and youll see the screen glow (but still be black).
                Also you run the 12v bulb between the 12v pin and a ground pin in the same socket (generally using the case as ground would work too, but ive always done it to the ground pin)
                Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  #68
                  So which pin (what does the label say) on the psb corresponds with the STB pin on the inverter board.
                  • CR Designs
                    • Dec 2012
                    • 430
                    Did the jump power on and blon the lights are on
                    • cashkennedy
                      • Aug 2011
                      • 668
                      Selldoor: this set does not route the blon through the psu, there is a small 4 pin connector that goes straight from the motherboard to inverter to control stb, brightness, error. Its a Y cable basicaly, 14 pins (13 wires) at inverter, then 10 of them go to PSU, and 4(3 wires) go to motherboard.
                      Good, so we basicaly know the backlights are fine, you may want to measure the error pin, and see what voltage it has, so we know its not sending a error state to the mainboard, but there is like 0 chance that that is related to your tv not starting at all.
                      • CR Designs
                        • Dec 2012
                        • 430
                        Cn903
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #72
                          Yes but which PIN - this is hard work.
                          • CR Designs
                            • Dec 2012
                            • 430
                            where is the error pin and how do you measure it. Thanks for the help
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              #74
                              Sorry - missed that - working on a small screen so only saw your post and I was looking only at the stbpin on the long connector.
                              • CR Designs
                                • Dec 2012
                                • 430
                                The STB pin is in a 4 pin plug that goes to K8L on the main board
                                • cashkennedy
                                  • Aug 2011
                                  • 668
                                  the error pin is labeled err on the inverter, you just measure dc voltage in the 20v range on your meter between the err pin and a chassis screw. Do this while the set and inverter are on / backlights are lit up.
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #77
                                    finally got it - I have been looking for a separate 4 pin connector
                                    • CR Designs
                                      • Dec 2012
                                      • 430
                                      Got reading of 0.48 to 0.52
                                      • CR Designs
                                        • Dec 2012
                                        • 430
                                        Pictures of back of main board
                                        • CR Designs
                                          • Dec 2012
                                          • 430
                                          are you soldering wires to bulb to connect Need more detail
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
                                          • masoksian
                                            Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                            by masoksian
                                            I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                            The system does not turn on, there is no post.
                                            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                            The problem continues in the same way.
                                            I tried to turn on the Fn key, nothing came to the screen....
                                            02-15-2025, 12:08 PM
                                          • dqtech
                                            lenovo x240 nm-a091 wont turn on
                                            by dqtech
                                            i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                                            board number VIUX1 NM-A091 REV:1.0...
                                            02-07-2024, 01:57 AM
