Faulty Philips PSU (715g5246-p01-000-002s )
  • Mr_K
    • 111
    #41
    Re: Faulty Philips PSU (715g5246-p01-000-002s )
    Ok, lets start all over again.
    Here are the readings:
    On/Off 0V
    DIM 0,01V
    +12v 0V
    +12v
    Gnd
    Gnd
    Gnd
    24v 0V
    24v
    PS-on 0V
    5.2v 0V
    5.2v
    So yeah, basicly no output at all.
      Can I get good focused pictures of these area so I can clearly see the traces and the designators?
      • Mr_K
        • 111
        #43
        Sure, hope these are good enough. If you need anything else, pls let me know.
          Thanks. Can you get the part number of that 7-pin DIP IC for that standby power supply section? Also pictures of the same section on the top side of the board.
            OK, this is the best I can do by looking at the pictures.
            Please check and see if you do have B+1 voltage.
            Check the fusible resistors R9329, R9301 (I am not sure the exact values on these two resistors, cannot read the numbers on the body).
            Check ZD9302 for low resistance reading on both direction. I am surprised that the two MOV's did not blow up, or the main fuse.
            • Mr_K
              • 111
              #46
              Wow, thank you very much!!!!!
              7-Pin IC is: A6069H SK1N1
              R9301 is 3,4Ohms (should be 3,3Ohms, so its fine)
              R9329 is 0,2Ohms (should be 0,1Ohms, so its fine)
              ZD9302: 3.5MOhms in one direction. Other direction is much higher
              B+1: 308V
                OK, next thing we need is the resistance reading on all 7 pins of that IC and the Primary ground. Since there is not much in that circuits beside the two star up caps (9336, 9337) and the IC. You may want to replace those two caps and the IC if they are cheap.
                I will have to look up the spec of the IC next.
                By the way, now you understand why I always ask for good clear focused pictures.
                • Mr_K
                  • 111
                  #48
                  Restistance according to "your" pinout. Actualy your pin 4 is pin 1. But i´ll stick to your counting....
                  1: 17MOhms
                  2: 0 Ohms
                  3: 228 Ohms
                  4: 3,3 Ohms
                  5+6: Starting at around 16M, going town to 1,4M and rapidly rising to a few K
                  8: Starting at around 8MOhms slowly dropping to 1,46M
                  I´ll have to order the IC first. But i´m afraight i wont get it in germany
                  Datasheet
                    OK, here is the spec of the IC.
                    OK, I need to up date the pin out of the IC. I see two dot on the bottom side of the board by each end of the IC pin, so not sure which pin is pin1, now with the spec sheet now I see. I will update the drawing.
                    Please take the reading per spec sheet so I do not get confused, thanks.
                    • Mr_K
                      • 111
                      #50
                      UPDATE:
                      1: 3,3Ohms
                      2: 228 KOhms
                      3: 0 Ohms / prim. Ground
                      4: 17MOhms
                      5: Starting at around 8MOhms slowly dropping to 1,46M
                      7+8: Starting at around 16M, going town to 1,4M and rapidly rising to a few K
                        That pin two looks bad, it has resistor R9320 (20K) to ground and MLCC (C9333) in parallel. So it eother has internla short in side the IC or shorted MLCC C9333. Can you lift pin 2 off the board to see the reading on that pad 2 still showing 228 Ohms?
                        • Mr_K
                          • 111
                          #52
                          It has 228KOhms. Missed the point.....
                          The pin reads 12,4MOhms. The pad still reads 228K
                            228kohm is bad though, with 20kohm in parallel, MAXIMUM reading is 20kohm.
                              Yes, please check the number as printed on the body of that resistor, from the picture it looks like 203.
                                Corrected my previous post, maximum is 20kohm, not minimum.
                                • Mr_K
                                  • 111
                                  #56
                                  R9320 is labled 2403 - so 240k
                                    by the way: "B+1: 308V" that seems low, what country are you in, it should be Line voltage x 1.414 = Voltage on the main filter cap.
                                    There is not much in the circuit, I would try replacing the IC, but should find out why you only have 308vdc instead of 330V or so.
                                    • Mr_K
                                      • 111
                                      #58
                                      I´ll try replacing the IC as soon as i can get it....might be more than a week or so.
                                      AC in ist 225vac; DC is 308vdc 10V less than expected. Is this still a problem?
                                      • Mr_K
                                        • 111
                                        #59
                                        Update and A happy new Year everyone!
                                        Took some time to get my hands on the IC to replace the old one. After replacing, my readings are:
                                        On/Off 0V
                                        DIM 0,01V
                                        +12v 0V
                                        +12v
                                        Gnd
                                        Gnd
                                        Gnd
                                        24v 0V
                                        24v
                                        PS-on 3.3V
                                        5.2v 3.3V
                                        5.2v 3.1V
                                        On standby, the front LED blinks three times followed by a longer break. I think this is related to missing 12V ?????
                                        • Mr_K
                                          • 111
                                          #60
                                          Update Resistance from every Pin to ground with a new IC A6069H SK1N1
                                          PINOUT according to datasheet!!
                                          1: 4 Ohms
                                          2: 198 KOhms
                                          4: 16,7 MOhms
                                          5: around 1M
                                          7+8: NOT steady
                                          • lolich112
                                            GTX 1660 Ti: Missing GPU Details & Abnormal Behavior - Possible Faulty IC?
                                            by lolich112
                                            I've been encountering some perplexing issues with my ASUS ROG STRIX GTX 1660 Ti Gaming OC and am seeking insights or potential solutions from the community.
                                            Symptoms:
                                            Initially experienced a gradient-style black screen from the top.
                                            Poor performance: ~10 FPS on the lock screen.
                                            Encountered artifacts followed by black screens.
                                            After addressing a PSU-related problem, still observed a performance drop (~10 FPS).
                                            Upon using GPU-Z:
                                            Memory size shows as 0MB.
                                            Unknown bus width and bandwidth reported....
                                            10-27-2023, 06:17 AM
                                          • tony359
                                            Faulty CRT AKF12/Philips CM8500: bad flyback?
                                            by tony359
                                            I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                                            What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                                            There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                                            Can it be a short somewhere...
                                            08-22-2023, 04:39 PM
                                          • ugamazing
                                            820-02020 PPBUS_AON missing
                                            by ugamazing
                                            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                            02-05-2025, 04:21 PM
                                          • jpreza
                                            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                            by jpreza
                                            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                            Looking at the card, it appears to be missing the following:
                                            1x 1.0uH inductor - orange square
                                            2x...
                                            11-01-2024, 10:54 PM
                                          • BYTEHAT248
                                            Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
                                            by BYTEHAT248
                                            Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
                                            11-14-2025, 04:48 PM
