Faulty Philips PSU (715g5246-p01-000-002s )
  • Mr_K
    • 111
    #101
    Re: Faulty Philips PSU (715g5246-p01-000-002s )
    In case i have not its a Philips 42PFL4007H/12
      I cannot find any schematic.
      Dodgy Chinese seller has it for £32: http://item.taobao.com/item.htm?id=15108857560 (maybe?)
      • Mr_K
        • 111
        #103
        Me neither....
        This board has different (more) components on it. Like i mentioned at the beginning of this thread.
        And i don´t like to order this from china.....
        • Mr_K
          • 111
          #104
          Originally posted by selldoor
          Did you mean the samsung or the Phillips. I was thinking of the phillips one. Tom and Bud were probably your best bet skimming through checking all the remaining big components
          would seem to be all that is left. You tetsted some of the the fusible resistors but did you check them all?
          Will check them again. It´s been a long time since i had a look at it. Mostly because i (or the PSU) fried the little IC again and i had to order new ones. Maybe that is a hint?
          What do you think about the SMD stuff on the bottom side. Thats a lot! to check....
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            #105
            Yes- that why I said large components. Unless they have changed colour considerably
            its a matter of testing every one for short than removing and re-testing - needle in a haystack job.
            • Mr_K
              • 111
              #106
              Yeah. But i´ll have to fix it since there is absolutely no suitable replacement PSU to find....
              Will have a look at it now and report back asap....
              • Mr_K
                • 111
                #107
                So far i´ve checked every fusible resistors and diodes on the front side. I´ve also tried to power the board with external 5.2V. 5.2V->100R->PS-On With no success. Does this mean the fault is definetly in the 12V/24V section?
                • Mr_K
                  • 111
                  #108
                  Hey its me again with another approach ;-)
                  I have finally found some scematics of the PSU. This one is from a benq with different names/numbers on the parts and even some different parts but the cirquit is pretty much the same. Especially in the standby section....
                  Anyway, this makes me belive that i need to have 5v standby instead of 3v(like its in my case)
                  HV input is present. There are no 5v between pin 2 and 4 on coil T2.....even with those pins lifted up. Maybe one of you experts can have a look at the scematics and give me a hint where to look?
                  Wille post more pics if requested.
                  Thanks in advance
                  • Mr_K
                    • 111
                    #109
                    Ok, i have found the correct schematics!!!!
                      Great!
                      If you only get 3V instead of 5.2V, places to check are:
                      - caps C9340, C9341
                      - inductor L9304 (should be short circuit)
                      - IC AZ432
                      - Optocouplers
                      However, I do notice, there is a Q9301, which when turned on, will reduce the output voltage. This is controlled by a pin, DV5. High on here indicates lower output voltage.
                        Do you get the link to work to get the sch? I could not.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #112
                          @budm, attached (as per post #109)
                          --- begin sig file ---
                          --- end sig file ---
                            Thanks retiredcaps, I will study it.
                            I get this message when I click on the link:
                            "Oops! Internet Explorer could not connect to www.iernut.bugs3.com"
                              Have you tried using Firefox or Chrome?
                              I can upload it to tgohome.com. Los Angeles server should be fast for you .
                                The SCH shows Q9301, R9339, R9341, R9340 as NC (NOT CONNECTED/NOT USED).
                                Check ZD9303, OPTO IC9303, REF DIODE IC9304 as Tom suggested.
                                The more PIN4 (FB) switng toward ground (less voltage), the less output voltage you will get. Check voltage between pin2 and 3 of ref diode IC9304.
                                When the output voltage tries to go up, the Opto will turn on more to keep the FB pin low.
                                • Mr_K
                                  • 111
                                  #116
                                  Originally posted by tom66
                                  Great!
                                  - caps C9340, C9341
                                  - IC AZ432
                                  - Optocouplers
                                  The caps and the inductor are fine. We checked IC AZ432 before (Post #93).
                                  Is there a way to check the optocoplers?
                                    Just because it's not connected on that model doesn't mean this board doesn't use it...
                                    Opto test requires two meters with diode test. One meter on one side measuring opto diode drop and providing test current. Other device to measure output current.
                                      He needs to see if those parts are installed on the board or not then to help reduce confusion.
                                      • Mr_K
                                        • 111
                                        #119
                                        They are not populated......
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #120
                                          Though I rarely use IE 8 now, it works fine for me.
                                          I used Opera 12.15 to download and re-upload pdf.
                                          • lolich112
                                            GTX 1660 Ti: Missing GPU Details & Abnormal Behavior - Possible Faulty IC?
                                            by lolich112
                                            I've been encountering some perplexing issues with my ASUS ROG STRIX GTX 1660 Ti Gaming OC and am seeking insights or potential solutions from the community.
                                            Symptoms:
                                            Initially experienced a gradient-style black screen from the top.
                                            Poor performance: ~10 FPS on the lock screen.
                                            Encountered artifacts followed by black screens.
                                            After addressing a PSU-related problem, still observed a performance drop (~10 FPS).
                                            Upon using GPU-Z:
                                            Memory size shows as 0MB.
                                            Unknown bus width and bandwidth reported....
                                            10-27-2023, 06:17 AM
                                          • tony359
                                            Faulty CRT AKF12/Philips CM8500: bad flyback?
                                            by tony359
                                            I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                                            What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                                            There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                                            Can it be a short somewhere...
                                            08-22-2023, 04:39 PM
                                          • ugamazing
                                            820-02020 PPBUS_AON missing
                                            by ugamazing
                                            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                            02-05-2025, 04:21 PM
                                          • jpreza
                                            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                            by jpreza
                                            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                            Looking at the card, it appears to be missing the following:
                                            1x 1.0uH inductor - orange square
                                            2x...
                                            11-01-2024, 10:54 PM
                                          • Sharpa
                                            Repair attempt Philips 55OLED804/12
                                            by Sharpa
                                            I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                            The symptoms when bought: Philips logo appears then tv turns off
                                            Things tried so far:
                                            1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                            2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                            11-22-2025, 08:30 AM
