Faulty Philips PSU (715g5246-p01-000-002s )
  • lolich112
    GTX 1660 Ti: Missing GPU Details & Abnormal Behavior - Possible Faulty IC?
    by lolich112
    I've been encountering some perplexing issues with my ASUS ROG STRIX GTX 1660 Ti Gaming OC and am seeking insights or potential solutions from the community.
    Symptoms:
    Initially experienced a gradient-style black screen from the top.
    Poor performance: ~10 FPS on the lock screen.
    Encountered artifacts followed by black screens.
    After addressing a PSU-related problem, still observed a performance drop (~10 FPS).
    Upon using GPU-Z:
    Memory size shows as 0MB.
    Unknown bus width and bandwidth reported....
    10-27-2023, 06:17 AM
  • tony359
    Faulty CRT AKF12/Philips CM8500: bad flyback?
    by tony359
    I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
    What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
    There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
    Can it be a short somewhere...
    08-22-2023, 04:39 PM
  • ugamazing
    820-02020 PPBUS_AON missing
    by ugamazing
    Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
    Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
    02-05-2025, 04:21 PM
  • jpreza
    Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
    by jpreza
    I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
    Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
    It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
    Looking at the card, it appears to be missing the following:
    1x 1.0uH inductor - orange square
    2x...
    11-01-2024, 10:54 PM
  • Sharpa
    Repair attempt Philips 55OLED804/12
    by Sharpa
    I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
    The symptoms when bought: Philips logo appears then tv turns off
    Things tried so far:
    1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
    2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
    Today, 08:30 AM
