Philips 42PFL5432D/37
  • retiredcaps
    • Apr 2010
    • 9271
    #101
    Re: Philips 42PFL5432D/37
    Originally posted by PoteauPets
    I am sooooo soooo excited.
    Good job. Don't forget to order a new business sign.
    Poteau Pets/TV repair
    --- begin sig file ---
    --- end sig file ---
      Glad you fixed it! Enjoy your TV.
      Another case of "even if it's not bulged, replace it." Especially applicable to cheap capacitors.
      I wonder if the caps on the main board started bloating because the main PSU caps had gone bad? And this was putting excessive ripple across these caps, causing them to bulge before the main PSU caps.
      • retiredcaps
        • Apr 2010
        • 9271
        #103
        Well, it was only a matter of time before those 3 Capxon went bad. We have already seen multiple pictures of that group of 3 bloated.
        • tbuch
          • Jan 2012
          • 31
          #104
          I am still unable to find the part number for the 1000uf 25v capacitor. If anyone could help with this that would be great. Then hopefully the next time you hear from me it will be my success story
          • bbjunkie
            • Dec 2011
            • 301
            #105
            Thanks again guys, WE DID IT !!!!
            Well technically you did it Congratulations!! It's a great feeling when you screw the back on and the set powers up again.
            Enjoy
            Jim
            • PlainBill
              • Feb 2009
              • 7034
              The Panasonic EEU-FM1E102 should be suitable. They are available from Digi-Key as their stock number P12379-ND.
              PlainBill
              • tbuch
                • Jan 2012
                • 31
                #107
                Thank you everyone for your help.... All the caps are ordered (+ extras..LOL)!!!
                I will update you on my next phase...
                You guys are GREAT
                • PoteauPets
                  • Jan 2012
                  • 65
                  #108
                  THE NIGHTMARE CONTINUES !!!!!!!!
                  The t.v. played all night last night so I put the cover back on this morning, hung it back on the wall, and within an hour, IT WENT OUT AGAIN !!!
                  I turned it off and then back on only to get less than an hour, sometimes only a few minutes, before I lose the picture again.
                  So, when the hubby gets home, he helps me hoist the big stupid heavy thing down off the wall, and lay it flat on the entertainment center. I proceed to take everything off the back once again. I inspect all the caps, new and old, nothing is visibly wrong, polarity is correct, no bloating etc. So, I switch it back on, wait for it to go off again, and it plays for over 3 hrs. What the heck is going on?
                  This time however, there are a few things different, when I lose the picture.
                  1. The green light stays on.
                  2. White lights in the back stay on.
                  3. Sound stays on.
                  Any suggestions ????????????? I'm sooo frustrated with this t.v. but am not about to give up. IT'S WAR
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #109
                    3. Sound stays on.
                    1) That suggests your main/logic board is working.
                    2) That suggests the inverters are getting 24V DC (that is new Panasonic 1500uF 35V caps are working).
                    3) That suggests your main/logic board is working.
                    New ideas.
                    1) Let's get an overall shot of the main/logic board so it looks like this (top down view). Tbuch saw 3 bad caps on her main/logic while I spotted 4. Maybe there is another on the main/logic board that you are missing?
                    We want the picture composition to be like this with resolution as close to 2000x2000 as possible.
                    https://www.badcaps.net/forum/attach...6&d=1310471174
                    2) This is a shot of the same TV by someone else. Circled in red is the t-con card. Take off the metal shielding and post a picture of it with the same picture composition as above.
                    3) Notice that the t-con card has a connector coming in from the bottom. Reseat this connector. There is a very small possibility that the connector when in the vertical position isn't making 100% contact.
                    The connector may be fragile so be gentle/careful with it.
                    4) Notice that the t-con card is the most northern module. When the TV is vertical and mounted on the wall, it is possible that all the heat rises towards this t-con module and it is failing due to heat and no air circulation. With the cover off and the TV in the horizontal position, heat dissipates in a different pattern versus wall mounted/covers on.
                    • tbuch
                      • Jan 2012
                      • 31
                      #110
                      PoteauPets,
                      OH KNOW!!! Not the news I wanted to hear. I hope you all find a simple solution for this next problem. How frustrating!!! By the time this is over and done with, we will know this TV inside and out huh?
                      • PoteauPets
                        • Jan 2012
                        • 65
                        #111
                        Here are the latest pics. Notice the lights are on in the first & last pictures.Thanks sooo much for all your help.........AGAIN !!!!!!
                          Try checking if this connector is fully plugged in. Trace it to the main board and check that side too.
                          • PoteauPets
                            • Jan 2012
                            • 65
                            #113
                            Just checked it and the side that you indicated was okay. I traced it and found where it went to the board. Left side popped off when I gave a little tug, then I lost picture. I snapped it back on, picture came back. Tugged it gently again to make sure it's locked and it is. Think that may have been the problem ?
                            Hubby is on his way home & I was thinking about having him help me prop it up to see what happens.
                            BTW, The stupid thing has been on ALL DAY while laying face down on the entertainment center.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #114
                              That would make sense you probably had to remove the connector to solder the replacement caps.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #115
                                If you have the original stand, you can try running it the TV upright with the cover on. See if it runs for 3 hours or so. You can push it near a wall to simulate wall mounting and air flow circulation.
                                • PoteauPets
                                  • Jan 2012
                                  • 65
                                  #116
                                  Propped it up against the wall, made it about 10 mins. & the picture went out.
                                  Green light stayed on.
                                  Sound stayed on.
                                  I tilted it forward to check that connection again and it was firmly seated.
                                  Turned it off, then back on, has been playing for about 10 mins. now.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #117
                                    If the picture disappears again, for the next test, try pointing a fan at the back part of the TV while it is propped up against the wall. I just want to see if cooling helps.
                                    • PoteauPets
                                      • Jan 2012
                                      • 65
                                      #118
                                      Okay, here's a timeline since I propped it up.
                                      ON 4:31 OFF 4:46 (15 mins)
                                      ON 4:46 OFF 4:54 ( 8 mins)
                                      ON 4:59 OFF 5:15 (15 mins)
                                      ON 5:16 OFF 5:23 ( 7 mins)
                                      Will try the fan next, be back shortly.
                                      • PoteauPets
                                        • Jan 2012
                                        • 65
                                        #119
                                        Okay, I had to run to Wal-Mart & then fix dinner so I turned it off while I was gone. T.V. was off for 2 hrs 23 mins. I've started the next test with t.v. still propped up & fan blowing between it & the wall. Now, I'm just waiting to lose picture. It's been almost an hour & a half.
                                        ON 7:49
                                        • PoteauPets
                                          • Jan 2012
                                          • 65
                                          #120
                                          It's been on with the fan blowing from 7:49 to 1:49, (almost 6 hours straight) without a hitch. I'm going to bed, hopefully it will still be on in the morning. I will let you know.
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • Ifixstuff9
                                            Philips 42PFL5432D/37 power supply issue no 12v
                                            by Ifixstuff9
                                            I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                            After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                            05-02-2021, 09:29 PM
                                          • aidanmo
                                            Philips 43PUS7506/12 - Loud blown out sound
                                            by aidanmo
                                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                                            • Using the internal speakers, it always happens.
                                            • Using the headphone jack, it never happens.
                                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                            02-28-2025, 03:13 PM
                                          • Cornito
                                            Philips 50PUH6400 bad color and gosting / slow motion on one side
                                            by Cornito
                                            Hello Team,
                                            New issue on LCD panel where I need to find out the cause and the potential solution.
                                            This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                            I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                            When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                            I've checked voltages, no issue found comparing right and left side of the panel driver.
                                            VHG VGL CKV... are the sames on...
                                            03-08-2024, 06:41 AM
                                          • spantor
                                            Activate power board Philips 40PFH40009/88 tv
                                            by spantor
                                            Hello partners.
                                            Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                                            The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                                            02-11-2024, 05:07 PM
