Philips 42PFL5432D/37
  • PoteauPets
    • Jan 2012
    • 65
    Re: Philips 42PFL5432D/37
    1) Yes, when the tv went out, I left it as is and re-tested and got nothing.
    2) The power light is still lit, but not the usual green, it's red or amber color when it
    kicks off.
    3) Will go take a picture of the main board, brb.
    • PoteauPets
      • Jan 2012
      • 65
      We have a WINNER...........or guess that should be LOOOOZER. Here are the pics and even I can see the two bad caps. Both are bulging at the top and have black crusty stuff coming out. The info for them is as follows:
      capXon 1000uF25v
      L2 105
      P724
      Vent
      Measurements are approx. 22mm x 10 mm
      • retiredcaps
        • Apr 2010
        • 9271
        Originally posted by PoteauPets
        capXon 1000uF25v
        L2 105
        P724
        Vent
        Capxon doesn't make very reliable caps. BTW, that is LZ series. LZ is their ultra low ESR series.
        P724 indicates it was made in 2007 week 24. So the caps lasted 4.5 years in a non stressful environment. The caps on the power board undergo more stress.
        For replacements use Panasonic FR caps (91 cents each) at digikey. Shipping from digikey is about $2.75 USD and you get the parts in 48 hours or so.
        http://search.digikey.com/scripts/Dk...25v+fr&stock=1
        The FR cap is 10x20mm so it will fit nicely.
        Now, normally because Capxon has such a poor reputation for reliability, we normally recommend replacing them ALL on sight, but since you are new to soldering, you may cause more damage until you have more experience.
        A couple of soldering tutorials.
        1) The written one here is very good.
        https://www.badcaps.net/forum/showthread.php?t=485
        2) Great soldering video.
        http://www.youtube.com/watch?v=I_NU2ruzyc4
        --- begin sig file ---
        --- end sig file ---
        • PoteauPets
          • Jan 2012
          • 65
          Thanks for all the help. Is there anything else I should order, so as to have everything I need all at once? Should I get an extra cap for just in case? What about soldering supplies ?
          • retiredcaps
            • Apr 2010
            • 9271
            1) If you are new to soldering, maybe you should get one extra cap just in case.
            2) I looked at digikey's soldering irons and their cheapest one is a Weller at $41. It is a quality iron and a fair price, but that is too much money just to fix 2 caps.
            3) If you live close to Radio Shack and/or Frys, you can get the solder iron and 60/40 solder from them for probably under $12, but do NOT get caps at Radio Shack/Frys. They only sell general purpose caps and you require low ESR caps like the Panasonic FR.
            4) Radio Shack 40W iron
            http://www.radioshack.com/product/in...ductId=2062738
            Add solder
            http://www.radioshack.com/product/in...ductId=2062719
            5) Frys 30W iron
            http://www.frys.com/product/2258018
            Add solder
            http://www.frys.com/product/4455316
            6) Ebay is another option for a 40W iron and solder for under $8. See
            http://www.ebay.com/itm/250906741926
            I can't vouch for the seller, but the seller is based in the USA so it won't take long to arrive?
            • PoteauPets
              • Jan 2012
              • 65
              #26
              1) Here is what I have for a Soldering Iron. Is this acceptable or do I need a better one with higher wattage. This one says it's 25 watts.
              I can drive to radio shack, which is about 30 mins. away if I need a better one. I'm so excited that we found the problem and even more excited to fix it.
              I want to get the caps ordered today but am trying to decide if I should add a few of the other ones even though they are not bad (yet)
              2) I also have nearly the same exact tv in my bedroom, but it's 6 months newer and only a 37" Philips. Wonder how I can find out what caps it takes without taking it apart too?
              You have been soo much help, I can't thank you enough. Hopefully, I will have the caps by Friday and the tv up and running this weekend. I watched the soldering tutorial and downloaded the soldering guide. I can't wait to get started !!! I will practice first though.......
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                1) Is this acceptable or do I need a better one with higher wattage. This one says it's 25 watts.
                I have a 30W and 40W "sort by lowest price" ebay soldering iron. I used the 30W initially, but the heating element died. It worked for power boards since most of them are single layer.
                I think most logic/main boards are multilayer so you may have some difficulty. I think your board is also using lead free solder which makes it more tough.
                The tip of your iron looks oxidized. If you can get it shiny clean like in the soldering video, then it might suffice.
                I usually add a bit of 60/40 solder onto the existing joints to help with thermal transfer and then wiggle the caps out. I used to use a desolder pump, but now switched to the stainless steel needle to clear out the holes.
                If your existing iron doesn't work, take it to Radio Shack and see if you can buy a compatible tip. Get a 2mm chisel tip. It will have better thermal transfer.
                Shipping from digikey is reasonable for USA customers at $2.75 with USPS 1st class. We get charged $8 USD to ship to Canada.
                ALL caps eventually fail. Capxon just fails quicker than most good quality brands like Rubycon, Nichicon, Panasonic, and United Chemi-con. The Panasonic FRs are used by many members here and are good quality low ESR caps.
                You can try searching here for the same model number. Some people may have posted a caps list.
                Good idea.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Pretty soon you will be looking at craigslist ads for non working TVs and spending all your free time here!
                  • bbjunkie
                    • Dec 2011
                    • 301
                    #29
                    I second that, i've fallen into the trap already
                    • PoteauPets
                      • Jan 2012
                      • 65
                      #30
                      Hehehehehhehe...........
                      I think I'm gonna drive over to Radio Shack tomorrow and get the iron that you suggested along with the correct solder since I don't even know what kind of solder I have.
                      BTW, I am a true entreprenuer. I started a Pet Store nearly 16 yrs ago, and it's still going strong. Although, since my back surgery, my husband takes care of the daily operations while I stay home and learn a new trade from you guys.........rofl
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        1) You likely have 60/40 solder since you are in the USA. I don't know for sure, but I think in some countries you can't buy 60/40 solder (illegal).
                        2) You might has well get the solder since you are making the trip to Radio Shack. Phone ahead and ask them to set it aside for you. I hate making a 1 hour round trip only to find out it is out of stock.
                        Do not buy the lead free solder. Yes I care about the enviroment, but there are many problems with lead free solder and reliability over the long term.
                        • PoteauPets
                          • Jan 2012
                          • 65
                          #32
                          I already called and checked availability and had him set them aside for me. They are open till 9:00 so I am thinking about going over there this evening.
                          It just kills me to think of all the electronics that we have thrown out over the years with the same problems.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            Part of the reason for the above I think are:
                            1) Electronics gets cheaper and cheaper every year making repairing a less economically viable option.
                            2) People are brainwashed into thinking newer is better (see iphone/ipad/ipod generation).
                            3) Some, not all, TV "repair" shops simply swap entire boards and don't even do component level repair. For that, they buy an OEM board which costs $$$ and charge you $100/hour for the service. Quite often, I have seen people here say that the repair costs exceeds the price of a new TV.
                            4) Some electronics are impossible to DIY repair. Try soldering in a 200 pin IC at home. Try working on cell phone boards where you need 30x magnification just to see the component.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #34
                              Check the part numbers carefully before purchasing. Radio Shack sells more than one iron and solder.
                              • PoteauPets
                                • Jan 2012
                                • 65
                                #35
                                Went to Radio Shack and got the iron and the solder that you had linked to me. Checked to be sure they were the right part number(s) also. They didn't have any extra tips though. He said they have to be ordered from their online store. So, now I wait anxiously for my caps to arrive.............lol
                                Yes, electronics do get cheaper each year but some things are still a little too high to just run out and replace. I think my cut-off point is just about at a 42" flat screen price...heheheh
                                Funny thing is......Right before I found this site and learned about "bad caps" I had searched online for prices for new flat screens (above 50") and then compared that to the estimated cost to fix my tv's unknown problem. I thought, if I'm gonna have to pay $200.00 or up to fix it, I might as well get a new "larger" one instead.
                                So, if all goes well, when my caps arrive, I will replace the 3 capXon LZ's and my tv will be rocking again for under $20.00......woo-hoo
                                • backoi
                                  • Jan 2012
                                  • 6
                                  #36
                                  Hi, I am new to this forum. I have the same model TV. Recently, it had no picture and no sound. I checked the power to both inverters, measured 24V DC. Visually, I didn't see any sign of caps burned or deformed. When power on, the blue light in front stays on for 1 minute, then goes off. What else should I check? Thanks for help!
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    Post clear focused top down pictures of YOUR boards using manage attachments and NOT inline. See my sig file in this thread for exact instructions and size guidelines.
                                    • PoteauPets
                                      • Jan 2012
                                      • 65
                                      #38
                                      Hi, I would start by going up to the beginning (the 1st page) of my posts and see how Retiredcaps has walked me thru everything step by step. It will help you to see what to check and what to look for until you find the problem.
                                      • backoi
                                        • Jan 2012
                                        • 6
                                        #39
                                        Hi, I attach the pictures of power board, main board and inverter boards. Please let me know if any picture needs to be retaken for clarity. Thanks!
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          1) Do you have a source hooked up like a DVD player to see if there is a picture and sound?
                                          2) Does the power always go off after 1 minute?
                                          a) If you turn off the TV and turn it back on, does it stay on 1 minute and go off again?
                                          3) Can we get a picture of the entire TV backside so all the boards are in view? We want to see the relationship and cabling between boards.
                                          4) PS. Sharp eyed readers and future people will notice this is why we always INSIST on photos on your own TV. The boards are completely different even though backoi says the models are the same in post #36.
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • Ifixstuff9
                                            Philips 42PFL5432D/37 power supply issue no 12v
                                            by Ifixstuff9
                                            I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                            After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                            05-02-2021, 09:29 PM
                                          • double_DD
                                            Philips curling iron - is this a common AC cable?
                                            by double_DD
                                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                            08-18-2025, 10:04 AM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
