Westinghouse SK-32H240S Continued problems
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Westinghouse SK-32H240S Continued problems
    Originally posted by Mike95inNJ
    I followed PlainBill's advice by
    testing the CCFL's by unplugging all but one connector and powering it up in a dark room. I did this for all six connectors and had a flash for each one.
    So I assume all six lamps are working.
    PlainBill's test above is only valid if the ccfl is completely broken. If the ccfl is completely physically broken, then it won't light. A ccfl can still light up and be bad because it is drawing too much current (i.e. it is near its useful life) or the return wiring is frayed internally.
    A inverter PWM IC operates as an "all or nothing". Either all the ccfls work or none at all.
    2 seconds to black can be
    a) bad caps
    b) bad ccfls
    c) bad ccfl wiring (especially the return wiring)
    d) bad secondary windings on the inverter transformer
    More details starting with post #19 at
    https://www.badcaps.net/forum/showthread.php?t=10419
    Also, see budm's Inverter tester using old CFL
    https://www.badcaps.net/forum/showthread.php?t=19987
    --- begin sig file ---
    --- end sig file ---
    • Mike95inNJ
      • Feb 2011
      • 18
      Originally posted by Dgtech
      For this reason, I will replace all three but then again, there's no guarantee.
      Hello. Did you get around to replacing all three of the transformers on your board?
      If so, did it correct the problem? Please let me know when you get a chance.
      Thanks, Mike
      • lilmonk3
        • Apr 2012
        • 259
        Same problem.. Replaced the bad transformer, but still have the shuts off after 2 sec.
        Has anyone found that all three need replaced to cure this?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Hi Lilmonk3- did you give up on the Samsung.
          It could be one of the other transformers is bad - did you test them all originally- or was one just burnt out? - It could be a number of other things - see retiredcaps post above.
          Can you see the lamps - to see if one does not flash on.
          • lilmonk3
            • Apr 2012
            • 259
            Yes I have put the samsung to the side for now.. Yes one transformer was burnt. I can see all lamps flash.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #26
              OK. Test all three transformers - here is the link from retiredcaps guide
              http://lcdparts.net/TransformerDetai...ProductID=2724
              shows you where to test. Set meter on 2000 ohms test as link and post results .
              T1 S1-S2 =XXX S3-S4 =XXX
              T2 etc etc
              • kevinm34232
                • May 2012
                • 1884
                I just picked up this same model TV for $20, it appears to have 2 different issues. The one is a garbled screen with random veritcal lines that appears to be a LCD/or connection issue. Secondly, the backlight comes on there goes off after about 10 seconds.
                I suspect one of the transformers as it tests differently then the others, but Im not sure actually what pins to test. I recently got a blue ring tester aswell but do I have to pull the transformer off to see what's what??
                The only #'s I can see on the side of the transformer are:
                42-M41411P08
                LITEON 0739 MC REV A 6
                • kevinm34232
                  • May 2012
                  • 1884
                  Ok I took one off just to see how it's layed out.
                  I tested each primary winding with ring tester and full green LEDS, also resistance was 2.2 - 2.3ohms on each transformer.
                  Not sure if I measured secondary correctly, seems to be 2 windings with a common pin in the center. Here's results for each one with meter set to 2k, measuring with probe on center to each side of windings.
                  T303 - .539, .536
                  T302 - .539, .541
                  T301 - .538, .541
                  T203 - .525, .526
                  T202 - .521, .525
                  T201 - .541, .541
                  Did I do this correctly? Also, putting ring tester on same pins lights 1 yellow LED.
                  • kevinm34232
                    • May 2012
                    • 1884
                    1 thing I just noticed aswell as when backlight goes off TV is still on, but by hitting any of the buttons on the side (volume, etc,) backlight comes right on for about and will stay on if buttons are pressed. This makes me think everything is working but maybe backlight is shutting off for lack of video signal??
                      Is there a BL_ON signal going from main to PSU?
                      • kevinm34232
                        • May 2012
                        • 1884
                        There is 4.3v at BLON, until backlight shutsoff after 10-15 secs, it goes to 0v. But, by hitting one of the volume or channel buttons on side of tv, backlight instantly lights up and 4.3v returns to BLON.
                        Does 4.3v sound a little strange? And jumping from 5v standby to BLON, keeps backlight on.
                          Sounds fine for a BL_ON signal; I'd look at the main board.
                          • kevinm34232
                            • May 2012
                            • 1884
                            I just hooked up HDMI source, and went thru the inputs until I got sound. Backlight will stay on with the HDMI source I guess it's supposed to shut off BL with no signal.
                              Makes sense, so you've fixed it?
                              • kevinm34232
                                • May 2012
                                • 1884
                                Nope back to original garbled Westinghouse logo on startup, and then random vertical colored lines. On 3 or 4 other tv's I've tried a new t-con board and it turned out not to be the problem, so Im recluctant with this one.
                                • Dgtech
                                  E. Technician
                                  • Apr 2009
                                  • 1462
                                  • Steeler
                                  #36
                                  This may seem like a cheesy fix but... it worked on a Westinghouse SK-32H240S.
                                  See here:
                                  http://www.avsforum.com/t/1143881/we...lems-anyone/30
                                  Look at post 34. That's not me but I had one of these sets with the same exact problem and fix. It was one of the cheapest fixes yet.
                                  • MajesticMike
                                    • May 2012
                                    • 31
                                    • US
                                    #37
                                    I have a Westinghouse SK-32H240S with the same problem as Xavier Renowned and Mike95inNJ (which is β€œ2 seconds to black” But its 2 flashes of the back light. 1 flash shows the β€˜W’ logo then another flashes the TV input then backlight stays off. You can see the picture if you hold a flash light up to the screen, and I do get sound.)
                                    I had a burnt transformer and puffed up caps. I replaced the 1 bad of the 3 transformers, and a few bad caps. I've checked most of the caps with ESR meter and the rest seem okay. I checked the transformers resistance on the primary and secondary and there isn’t much difference. I've tested the ccfls with PlainBills method and another of my own. I used an old LCD pc monitor inverter board to light up one ccfl on this tv at a time (and 3 on my old monitor to balance it), and made sure I could get each ccfl on this TV to stay on as long as I wanted, using this method for all 6 ccfls. (Of course I had to feed the monitor a signal from my pc through the VGA port to make it work tho.) I also tried the opposite, lighting different ccfls with this tv inverter board. I hooked 2 of the ccfls on my old LCD monitor to 2 of the connections on each transformer on this TV’s inverter board. And it lit up but still did same thing the tv always did, lit up and went out.
                                    I checked the BL_ON pin and it’s getting 5 volts
                                    I’m not really sure where to go from here… any advice? Am I on the right track? Do you think my way of testing the ccfls was an accurate measure? Is there any other diagnostics I could perform?
                                    Mike
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #38
                                      1) Thanks for doing some homework and trying the suggestions laid out in the previous posts. You would be surprised at how many people come here and say "help me", but never bother to read and/or try the suggestions already presented.
                                      2) I prefer to test for bad ccfl's using the method laid out in step #5
                                      https://www.badcaps.net/forum/showpo...6&postcount=20
                                      That is, namely using a good ccfl to narrow down the problem.
                                      3) Please report all your secondary windings. Some people incorrectly report their interpretation of the raw data. I'm not suggesting you have done so, but once every 2 weeks, we are led to believe something works when in reality it doesn't.
                                      4) You have 12 blue caps in the inverter section. With power off, measure the resistance between the legs of each one. They should all read open circuit on your multimeter. Report your findings.
                                      5) Was the inverter transfomer replacement an exact match? What was the original part number and what is the replacement part number?
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        BTW, did you test the caps out of circuit with the ESR meter? In circuit readings are not reliable because capacitors could be parallel.
                                        I don't have an ESR, but if I see 2 or 3 bulged caps, all the other caps especially if they are the same brand or a known bad brand like Capxon are replaced (cockroach theory).
                                        • MajesticMike
                                          • May 2012
                                          • 31
                                          • US
                                          #40
                                          retiredcaps, thanks for your quick reply and help! I had a bit of homework to do in order to get back with you on this matter.
                                          as for the secondary windings:
                                          i'm not sure which is primary and which is secondary when looking at them, but i measured the resistance of the transformers connections from top to bottom and this is what i got. (in circuit)
                                          1. 1765, 1760
                                          2. 1807, 1805 (the new replacement)
                                          3. 1733, 1728
                                          as for the 12 blue caps in the inverter section: Yes they do all read as open circuit with the resistance test. (in circuit)
                                          Was the inverter transformer replacement an exact match?
                                          I think so. Here's the numbers on top:
                                          4301H 746082(GP)__
                                          4301H 922120<GP>- (The Replacement)
                                          4301H 746086(GP)_
                                          Did you test the caps out of circuit with the ESR meter?
                                          Originally, some were in circuit and some were out, so now i went back to all the caps i haven't replaced and pulled them out of circuit to check them.
                                          Unfortunately, the remaining caps are of the CapXon brand. They are all small caps and i have tested each one with capacitance and ESR meters. (out of circuit)
                                          I have 4 caps that are 47uf 50v, 2 caps that are 10uf 50v, and 1 that's 2.2uf 50v
                                          Capacitance, ESR
                                          48.0uf, 0.23
                                          45.4uf, 0.21
                                          45.7uf, 0.24
                                          48.6uf, 0.23
                                          10.3uf, 1.00
                                          10.3uf, 0.82
                                          2.15uf, 2.00
                                          • darckreign1984
                                            lenovo y530 dead ite replaced - problems
                                            by darckreign1984
                                            shorted pin-id with vcc
                                            initial-ite------
                                            IT8226e-128
                                            1839-BXS
                                            S167RA
                                            L002
                                            i test with this type (3 chips,same results)
                                            IT8226E-128
                                            1649-BXS
                                            -laptop show for a short time lenovo logo without light
                                            i test the ite from a lenovo y540 - laptop start, i can work on windows - all good, only problem battery cant be charged, and when i connect the laptop turn off in few seconds
                                            IT8226E-192
                                            1847-BXA
                                            03-22-2023, 11:06 AM
                                          • dragon3x
                                            by dragon3x
                                            power on.
                                            Here are some examples :
                                            switching supply area).
                                            than 6.3 V.)
                                            03-21-2025, 02:46 PM
                                          • jean luc ferre
                                            laptop hp g72 b52sf screen problems
                                            by jean luc ferre
                                            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                            i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                            06-07-2025, 03:27 PM
                                          • Hondaman
                                            USB problems?
                                            by Hondaman
                                            Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                            (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                            I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                            08-12-2024, 03:26 PM
                                          • MicroSMD Lab
                                            MSI MS-16W1 no power, EC replaced by other.
                                            by MicroSMD Lab
                                            Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
                                            03-27-2025, 07:35 AM
