Westinghouse SK-32H240S Continued problems
  • Solution4u
    • Oct 2016
    Re: Westinghouse SK-32H240S Continued problems
    Here's my first question, and I saw it asked earlier... I have 2 Westinghouse 32H240S tvs... one with a bad inverter board, the other a destroyed LCD... the good inverter board has 6 transformers instead of 3, but all the same connectors...'is it safe to say I can out the 6 transformer board in the other tv and it will be compatible?
    • darckreign1984
      lenovo y530 dead ite replaced - problems
      by darckreign1984
      shorted pin-id with vcc
      initial-ite------
      IT8226e-128
      1839-BXS
      S167RA
      L002
      i test with this type (3 chips,same results)
      IT8226E-128
      1649-BXS
      -laptop show for a short time lenovo logo without light
      i test the ite from a lenovo y540 - laptop start, i can work on windows - all good, only problem battery cant be charged, and when i connect the laptop turn off in few seconds
      IT8226E-192
      1847-BXA
      03-22-2023, 11:06 AM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
    • jean luc ferre
      laptop hp g72 b52sf screen problems
      by jean luc ferre
      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
      i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
      06-07-2025, 03:27 PM
    • Hondaman
      USB problems?
      by Hondaman
      Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
      (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
      I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
      08-12-2024, 03:26 PM
    • MicroSMD Lab
      MSI MS-16W1 no power, EC replaced by other.
      by MicroSMD Lab
      Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
      03-27-2025, 07:35 AM
