Sharp Aquos LC46XL2E LCD (2 flashing lights)
    Re: Sharp Aquos LC46XL2E LCD (2 flashing lights)
    I have the service manual and it includes the partslists of all boards. Can neither find the cap C4707 nor the IC4701.
      I cannot find that service manual, can you post a link to it?
        https://www.dropbox.com/s/10zorpxnj1dxnnt/lc46x20e.zip
          Any ideas? After switching it on i can hear a kind of tickering near the inductors at the bottom right edge. There is IC9601 which should provide the 3.3V, but it doesn't.
          Regards
            Sorry -- totally missed your post.
            What do you get across C9634?
              Can't measure exactly because when the set ist turned off because of failure the voltage will be switched off. But after pressing power button the voltage jumps up. On standby the voltage is 0V.
                As far as I know a Sharp LCD will just freeze the startup process should a fault occur, so the 3.3V, if it works, should come up and stay at the right value, or a wrong value...
                  So in this case there must be the wrong value. Is there a difference between Digital and analog 3.3V? And where could I measure these voltages?
                    Digital 3.3V and analog 3.3V may be separate.
                    Check pin SS (#6), or across C9602 (near the IC), should measure 3.7V when working.
                      Originally posted by Canuck_33 View Post
                      I am having a problem similar but not the same and it is my hope someone here can help. I have a 50" Sharp Aquos and I am absolutely sure that only one green light is on the front of the tv when it is on normally...but today there are two lights and I swear the picture seems darker?? Anyone have any thoughts?
                      You must have OPC enabled
                      Go to Menu and disable it you should be OK
                      This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                      Help keep these from the landfills
                        Hi guys I have same tv (Sharp LC40X20E) and I get 2 power blinks and 4 OPC blinks. Anyone know what this error means.
                          sorry I meant 2 power blicks and 3 OPC blinks
                            Here are the codes.
                              Here are the codes.
                              Thanks budm. Mine says power on 10v failure. How do i repair this fault ?
                                You can start by downloading the service manual from elektrotanya, it is about 65MB so I cannot upload to BC.
                                  Im unsure what im looking for. Im not even 100% sure its the right manual i found.
                                    this should be the one as budm says it too large for us to upload so if you download it maybe budm can advise you what you need to check
