Sharp Aquos LC46XL2E LCD (2 flashing lights)
+ More Options
Posts
  • Schorsch87
    • Feb 2013
    • 55
    Re: Sharp Aquos LC46XL2E LCD (2 flashing lights)
    I have the service manual and it includes the partslists of all boards. Can neither find the cap C4707 nor the IC4701.
      I cannot find that service manual, can you post a link to it?
      • Schorsch87
        • Feb 2013
        • 55
        https://www.dropbox.com/s/10zorpxnj1dxnnt/lc46x20e.zip
        • Schorsch87
          • Feb 2013
          • 55
          Any ideas? After switching it on i can hear a kind of tickering near the inductors at the bottom right edge. There is IC9601 which should provide the 3.3V, but it doesn't.
          Regards
            Sorry -- totally missed your post.
            What do you get across C9634?
            • Schorsch87
              • Feb 2013
              • 55
              Can't measure exactly because when the set ist turned off because of failure the voltage will be switched off. But after pressing power button the voltage jumps up. On standby the voltage is 0V.
                As far as I know a Sharp LCD will just freeze the startup process should a fault occur, so the 3.3V, if it works, should come up and stay at the right value, or a wrong value...
                • Schorsch87
                  • Feb 2013
                  • 55
                  So in this case there must be the wrong value. Is there a difference between Digital and analog 3.3V? And where could I measure these voltages?
                    Digital 3.3V and analog 3.3V may be separate.
                    Check pin SS (#6), or across C9602 (near the IC), should measure 3.7V when working.
                    • electronicsurplus
                      • 210
                      Originally posted by Canuck_33
                      I am having a problem similar but not the same and it is my hope someone here can help. I have a 50" Sharp Aquos and I am absolutely sure that only one green light is on the front of the tv when it is on normally...but today there are two lights and I swear the picture seems darker?? Anyone have any thoughts?
                      You must have OPC enabled
                      Go to Menu and disable it you should be OK
                      This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                      Help keep these from the landfills
                      • Mikeyboy2007
                        • Mar 2013
                        • 745
                        • Scotland
                        #31
                        Hi guys I have same tv (Sharp LC40X20E) and I get 2 power blinks and 4 OPC blinks. Anyone know what this error means.
                        • Mikeyboy2007
                          • Mar 2013
                          • 745
                          • Scotland
                          #32
                          sorry I meant 2 power blicks and 3 OPC blinks
                            Here are the codes.
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              #34
                              Originally posted by budm
                              Here are the codes.
                              Thanks budm. Mine says power on 10v failure. How do i repair this fault ?
                                You can start by downloading the service manual from elektrotanya, it is about 65MB so I cannot upload to BC.
                                • Mikeyboy2007
                                  • Mar 2013
                                  • 745
                                  • Scotland
                                  #36
                                  Im unsure what im looking for. Im not even 100% sure its the right manual i found.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #37
                                    this should be the one as budm says it too large for us to upload so if you download it maybe budm can advise you what you need to check
                                    • berrmich
                                      Sharp LC-C4655U Flashing OPC and Power lights.
                                      by berrmich
                                      I have the above TV. Black screen. Power blinks 2 times. OPC blinks once. Plug in with channeldown/volup. Powers up with solid green power but no light. I removed, cleaned and tightened the screwed on the inverters. I tested plug coming from the power supply to the inverter board when unplugged. INV12V shows 7.4 V DC. INV60V shows 0.1 or something like that. After plugging in the cable I don't get meaningful voltage from either one. (I measured after booting the TV with channeldown/volup.)
                                      Is this a bad power supply? Or am I measuring something wrong.
                                      -Mike
                                      08-19-2023, 11:32 AM
                                    • TVAddict
                                      Sharp LC-32D44U - Power and OPC lights flashing
                                      by TVAddict
                                      Hello everyone, so the problem is the tv would seem to power up when i hit the power button as i would hear a relay click, sometimes it may give me a good picture for about 5 secs or so, sometimes i get a black screen, then shortly after it will click back off and i get power and opc lights flashing together twice followed by one flash of the opc light then it repeats.
                                      Please correct me if i'm wrong but i understand the flash sequence indicates a possible power supply problem, can anyone say if this is accurate information? So going on that i went ahead and tried a factory reset, checked...
                                      02-09-2022, 06:36 PM
                                    • scubacamper
                                      Sharp Aquos LC-70C6400U Half Screen Dark
                                      by scubacamper
                                      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                      05-03-2025, 12:19 PM
                                    • SONY_E-WASTER
                                      Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                      by SONY_E-WASTER
                                      Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                      The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                      then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                      does...
                                      12-26-2021, 05:46 PM
                                    • Egidio85
                                      SHARP LC-40LE814E does not turn on 2 flashes
                                      by Egidio85
                                      hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                                      the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                                      reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                                      now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                                      to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                                      07-21-2023, 11:49 AM
