Sharp LC-C4655U Flashing OPC and Power lights.
  • berrmich
    • Aug 2023
    • 30
    Re: Sharp LC-C4655U Flashing OPC and Power lights.
    Removing D9701 does result in 3v at PS_ON. The diode tests 0.60 one way and 0 the other.
    • R_J
      • 9607
      did the power supply turn on as well? If it did, check if there were any voltages on LB plug. If there are no voltages, try supplying 5v to stb on the inverter, you can use a 470~1k resistor if you like.
      • berrmich
        • Aug 2023
        • 30
        Yes. When I hit the power button it did. Lots of clicking when I first plugged it in. After hitting the power button I had 12v and 60 but nothing at the LB plug.
        I did not have to start with the chan/vol
        • berrmich
          • Aug 2023
          • 30
          I don't have a resistor. What's the best way to do this?
          • berrmich
            • Aug 2023
            • 30
            With STB 5v. Lights turn on but they turn off and back on every 10 secs or so. LB on inverter:
            Pin1 - 0
            Pin2 - 5v
            Pin5 - 3v
            Pin8 - 3v
            • R_J
              • 9607
              Pin 5 is the error pin so I suspect there is a problem on the inverter, if the LB is still connected to the main board it is likely telling the main board to shut down
              • berrmich
                • Aug 2023
                • 30
                Originally posted by R_J
                You can try connecting the PS_ON 3.3 direct to the stb on the inverter and see if it turns on the inverter, if that doesn't work I would try 5v direct to the stb
                Sorry see above. I just jumpered 5 v to it.
                • R_J
                  • 9607
                  I saw that so I changed my post.
                  • berrmich
                    • Aug 2023
                    • 30
                    Ah. Hence the ERR label. So main board is probably fine? What types of things on the inverter can cause the error? And yes I kept the plugs in when I jumpered. Just shoved in the top.
                    • R_J
                      • 9607
                      The first thing I would check are the transformers, The transformer has two secondary's so check the resistance of each winding, they are usually around 1000Ω so check each transformer and see if one of the readings is not like the others.
                      • berrmich
                        • Aug 2023
                        • 30
                        I think I'm checking these right? didn't find a diagram in service manual. Look at picture to see if I'm doing right. If so I'm getting consistent readings on all of them.
                        • R_J
                          • 9607
                          If I remember this should be the secondaries
                          • berrmich
                            • Aug 2023
                            • 30
                            No that doesn't work. Here is the only thing I could find on the transformers.
                            2874026700 transformer
                            • R_J
                              • 9607
                              The original way you checked the transformers is the correct way so I suspect they are ok. On these inverters, transformer failure is common, but so is having a bad ccfl in the panel, or even bad connections between the ccfl tubes and there sockets can cause a problem.
                              • berrmich
                                • Aug 2023
                                • 30
                                Anyway to figure that out?
                                -Mike
                                • R_J
                                  • 9607
                                  -Mike
                                  Remove one of the transformers so you can see and check the windings, with it removed there will be nothing else effecting the readings, sometimes transformer pins are just used for mounting and are not connected to a winding.
                                  If all the transformers checked the same I suspect they are all ok, 1.7k seems fine, if one was 1.5k or something like that I would suspect it was bad.
                                  I suspect it is like this picture
                                  • PantherDave
                                    by PantherDave
                                    Hi all!
                                    05-29-2024, 02:01 PM
                                  • STKR123
                                    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                    by STKR123
                                    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                    I wonder if re-flashing the BIOS might be of any use here.
                                    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                    11-03-2024, 06:58 AM
                                  • TVAddict
                                    Sharp LC-32D44U - Power and OPC lights flashing
                                    by TVAddict
                                    Hello everyone, so the problem is the tv would seem to power up when i hit the power button as i would hear a relay click, sometimes it may give me a good picture for about 5 secs or so, sometimes i get a black screen, then shortly after it will click back off and i get power and opc lights flashing together twice followed by one flash of the opc light then it repeats.
                                    Please correct me if i'm wrong but i understand the flash sequence indicates a possible power supply problem, can anyone say if this is accurate information? So going on that i went ahead and tried a factory reset, checked...
                                    02-09-2022, 06:36 PM
                                  • GLISIT
                                    by GLISIT
                                    01-16-2025, 02:29 PM
                                  • WVUfan
                                    PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
                                    by WVUfan
                                    hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
                                    08-11-2025, 01:12 PM
