SHARP LC-40LE814E does not turn on 2 flashes
  • Egidio85
    • Jul 2019
    • 38
    • italia
    hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
    the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
    reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
    now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
    to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
    with the new card it only flashes 2 times on the front LED and the backlight doesn't even start for a few seconds.
    you can't even enter adjustment mode with the procedure shown in the manual.
    Any advice on what it could be or what to try?
    Thanks in advance
  • cajoeg
    Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
    by cajoeg
    Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
    The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
    02-10-2025, 04:01 PM
  • SONY_E-WASTER
    Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
    by SONY_E-WASTER
    Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
    The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
    then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
    does...
    12-26-2021, 05:46 PM
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • twonk9098
    Lenovo Legion 5 high fan spin turns off after 34 seconds
    by twonk9098
    I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
    I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
    I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
    I have tried a few new bios but exactly...
    07-14-2024, 11:19 AM
  • odie34
    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
    by odie34
    I am a hobbyist (not a professional) so please be gentle...
    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
    02-18-2024, 09:11 AM
