Sony kdl 40ex720 firmware update
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4343
    • Italy - Milan
    #61
    Re: Sony kdl 40ex720 firmware update
    ok then keep pressed one of the keys and press togheter also power
    • dinosglxaros
      • Nov 2016
      • 57
      • greece
      #62
      I do have to keep pressed the keys then plug the power or in standby mode(redlight)?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4343
        • Italy - Milan
        #63
        i said standby mode, but if you want you can try both
        • cheeky2
          • Dec 2012
          • 337
          #64
          I have found on when upgrading the firmware on some of the Toshiba TV's that I have to format the usb drives not using the quick format option. I found that if I used the quick option when formatting the usb flash drive it would not accept the firmware (this was when using a Windows 10 OS). Worth a try?
          • dinosglxaros
            • Nov 2016
            • 57
            • greece
            #65
            I also tried without quick format.. I am still waiting to find onother flash drive
            • lotas
              • Jan 2016
              • 4620
              • Russia
              #66
              Try another option (sometimes it helps), turn on the TV, as soon as the diodes flash, wait 20-30 seconds. and after that insert the usb flash into the TV, the update should go.
              • dinosglxaros
                • Nov 2016
                • 57
                • greece
                #67
                Ok I will try that thank you..
                • dinosglxaros
                  • Nov 2016
                  • 57
                  • greece
                  #68
                  Hello i come back to this TV after a long time. I think the problem is that a have an italy(EIA) version of a batv board that i bought from italy and according the manual they use different firmware from EUA and i cant find anywhere the firmware(EIA) for italy, does anyone have it?
                  • nippur2
                    • Sep 2022
                    • 5
                    • Hungary
                    #69
                    I ran into the same issue. I want to take KDL-32EX720 mainboard (works fine in original TV) into the KDL-40EX726. G and Y Leds blinks, but USB fw update not starting, only 1 sec communication visible on status led. I use an old 4GB Kingstone pendrive, which worked well in any TV so far. Tried EUA and AAA sw., original .bin and upgrage_loader.pkg, etc.
                    • lotas
                      • Jan 2016
                      • 4620
                      • Russia
                      #70
                      Try this: after the LEDs start blinking, wait 30 - 40... seconds and only then insert the USB flash drive with the software into the TV. Old Sony TVs are very sensitive to the USB flash drive itself, try old ones with 512 - 1 - 2 Gb.
                      Software update sony_tvupdate_2011_4027_eua_auth?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4343
                        • Italy - Milan
                        #71
                        if i remember until 2gb can be formatted using fat12, try partitioning in 2 x 2 gb fat12
                        • lotas
                          • Jan 2016
                          • 4620
                          • Russia
                          #72
                          FAT12 is not suitable for USB Flash, there is FAT16 or FAT32, FAT12 is usually used for floppy disks.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4343
                            • Italy - Milan
                            #73
                            ok so was 16bit, try that so, i cant check every thing with a cellular, the idea was that, user can use google or what he wants,
                            fat16 -> up to 2gb..
                            • Diah
                              • Feb 2013
                              • 6376
                              the size of the Stick doesn't matter, it should be before formatted converted in MBR mode, so the TV will boot from it, most USB stick are GPT mode TV will pass them
                              • lotas
                                • Jan 2016
                                • 4620
                                • Russia
                                #75
                                Doesn't work or have you lost your USB flash drive?
                                • Diah
                                  • Feb 2013
                                  • 6376
                                  the fact are, old USB from manifacture 2-4 Gb are all MBR , the later 8Gb and above they are GPT. so need to convert them to MBR. that's allt
                                  i have one 64Gb.converted in MBR mode... on it many Firmware copy... i just rename the extension i need then will be booted to install update or downgrade
                                  • nippur2
                                    • Sep 2022
                                    • 5
                                    • Hungary
                                    #77
                                    I have copied "00000100_07e8046a.bin" to the pendrive from "sony_tvupdate_2011_4027_eua_auth.zip". There is no change if I wait for 30-40sec. after G-Y blinking. Also tried to rename upgrade.loader.pkg
                                    I will try to obtain a max. 1GB pendrive and try again.
                                    I also confirmed my stick has MBR partition.
                                    • lotas
                                      • Jan 2016
                                      • 4620
                                      • Russia
                                      #78
                                      Why, in the root directory of the USB Flash a folder with the name sony_dtv0FA10A01A0A1_00000100 should be created, and in it a bin file with the firmware.
                                      Just copy the folder from the archive to the USB Flash.
                                      • nippur2
                                        • Sep 2022
                                        • 5
                                        • Hungary
                                        #79
                                        A big thank you for all!
                                        That was the problem: I copied only the file not the folder. And also a good news that, I reformatted my 4GB chinese led stick with RUFUS to MBR partition and USB update went down easily immediately, so doesn't need special low capacity stick for it.
                                        PS: So far I have done many USB update, but almost all need to copy the (bin, pkg, etc.) file to root, not the folder. This is exception.
                                          • 12206
                                          • U.S.
                                          #80
                                          That's GREAT info Diah and solves an age old problem. You are definitely the first one on this site to have this solution.
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                          • TheUser
                                            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                            by TheUser
                                            Hello to everyone ,
                                            This is my first post here, and i would like to share with you a small story in case you can help me.
                                            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                            02-10-2024, 02:07 PM
                                          • madyoyo
                                            Sony KDL60w685a need firmware update
                                            by madyoyo
                                            Hello everyone.
                                            I replaced the mainboard on a KDL60w685a, and now it blinks green and yellow. I think i need to update the firmware. But it's not available from Sony website.
                                            Does anyone have the firmware for this TV?
                                            01-06-2023, 01:41 PM
                                          • thesteve
                                            Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
                                            by thesteve
                                            So I bought another main board from eBay and the same thing happened.
                                            I got the firmware file from the Sony website. My model was listed and everything matched.
                                            sony_tvupdate_2011_4027_aaa_auth.zip was the file.
                                            Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
                                            with file: 00000301_07e8046a.bin inside.
                                            Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
                                            The file reads perfectly. Lots of "disk activity"...
                                            07-17-2021, 04:59 PM
                                          • rumpumpel1
                                            ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
                                            by rumpumpel1
                                            Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
                                            10-24-2024, 08:59 AM
