Sony kdl 40ex720 firmware update
  • dinosglxaros
    • Nov 2016
    • 57
    • greece
    #41
    Re: Sony kdl 40ex720 firmware update
    No I don't have access to the tcon board from where I bought the batv board
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4462
      • Italy - Milan
      #42
      Try this: with TV in standby keep pressed cursor up on the remote then press Power key on the front panel, this will make an hard reset. If this doesnt work, try enter service mode: Display key, 5, Vol+, Power, this with remote, Display is the key that represents an old 4:3 empty screen, then press 8, Mute, 0, this makes the hard reset, to exit turn off tv.
      • dinosglxaros
        • Nov 2016
        • 57
        • greece
        #43
        Ok I will try tomorrow and report back thank you!
        • dinosglxaros
          • Nov 2016
          • 57
          • greece
          #44
          Guys I tried everything u suggested but I cant make the update to start..I cant enter the service mode also when try the combination and after pressing the 5 button on the remote the TV just power on.
          • lotas
            • Jan 2016
            • 4753
            • Russia
            #45
            Try to pick up different USB flash (old, not large).
            • dinosglxaros
              • Nov 2016
              • 57
              • greece
              #46
              I tried an old one with 1gb even an Sony card reader with small SD cards.
              • lotas
                • Jan 2016
                • 4753
                • Russia
                #47
                Try to look for and select different USB flash drives, it won’t make sense that you found one on 1Gb, you need different manufacturers (with old controllers inside) so that the TV can determine.
                • dinosglxaros
                  • Nov 2016
                  • 57
                  • greece
                  #48
                  If I find and buy the same board from a 40ince tv do I have to do the update or its plugsplay?
                  • lotas
                    • Jan 2016
                    • 4753
                    • Russia
                    #49
                    Yes, you will also need to update (they have a main + T-con binding), then it’s easier for you to buy a native main + T-con kit the same as yours with the same matrix.
                    • dinosglxaros
                      • Nov 2016
                      • 57
                      • greece
                      #50
                      I understand but its an extra cost and I don't think that worth the money..
                      • lotas
                        • Jan 2016
                        • 4753
                        • Russia
                        #51
                        Yes, then it's easier to pick up a usb flash drive with which to pick up the update.
                        • dinosglxaros
                          • Nov 2016
                          • 57
                          • greece
                          #52
                          I don't know sir I think its not the problem with the flash drives but maybe the board i bought its faulty
                          • lotas
                            • Jan 2016
                            • 4753
                            • Russia
                            #53
                            Rather, the board is working, since it needs to be updated, but choosing the right usb flash is problematic for older TV models.
                            • lotas
                              • Jan 2016
                              • 4753
                              • Russia
                              #54
                              Before each attempt to update, you need to unplug the TV from the outlet and wait 20-30 seconds, then just turn on the power with the USB flash drive inserted.
                              • dinosglxaros
                                • Nov 2016
                                • 57
                                • greece
                                #55
                                Ok I will try to find onother old ones and try again..
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4462
                                  • Italy - Milan
                                  #56
                                  Describe which local keys you have.. or try different combinations when in standby
                                  • lotas
                                    • Jan 2016
                                    • 4753
                                    • Russia
                                    #57
                                    Look for flash drives from the years when your TV was released, I have a very old Sony flash drive at 512Mb and never had a problem with updating old TVs.
                                    Also, try cleaning the USB contacts on the TV itself (when unplugged) and on the flash drive itself.
                                    • dinosglxaros
                                      • Nov 2016
                                      • 57
                                      • greece
                                      #58
                                      What do you mean?
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4462
                                        • Italy - Milan
                                        #59
                                        the keys that are on the body of tv
                                        • dinosglxaros
                                          • Nov 2016
                                          • 57
                                          • greece
                                          #60
                                          I have power - channels- volume - source - home
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                          • madyoyo
                                            Sony KDL60w685a need firmware update
                                            by madyoyo
                                            Hello everyone.
                                            I replaced the mainboard on a KDL60w685a, and now it blinks green and yellow. I think i need to update the firmware. But it's not available from Sony website.
                                            Does anyone have the firmware for this TV?
                                            01-06-2023, 01:41 PM
                                          • thesteve
                                            Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
                                            by thesteve
                                            So I bought another main board from eBay and the same thing happened.
                                            I got the firmware file from the Sony website. My model was listed and everything matched.
                                            sony_tvupdate_2011_4027_aaa_auth.zip was the file.
                                            Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
                                            with file: 00000301_07e8046a.bin inside.
                                            Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
                                            The file reads perfectly. Lots of "disk activity"...
                                            07-17-2021, 04:59 PM
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                          • TheUser
                                            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                            by TheUser
                                            Hello to everyone ,
                                            This is my first post here, and i would like to share with you a small story in case you can help me.
                                            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                            02-10-2024, 02:07 PM
