Sony kdl 40ex720 firmware update
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4326
    • Italy - Milan
    #61
    Re: Sony kdl 40ex720 firmware update
    ok then keep pressed one of the keys and press togheter also power
    • dinosglxaros
      • Nov 2016
      • 55
      • greece
      #62
      I do have to keep pressed the keys then plug the power or in standby mode(redlight)?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4326
        • Italy - Milan
        #63
        i said standby mode, but if you want you can try both
        • cheeky2
          • Dec 2012
          • 337
          #64
          I have found on when upgrading the firmware on some of the Toshiba TV's that I have to format the usb drives not using the quick format option. I found that if I used the quick option when formatting the usb flash drive it would not accept the firmware (this was when using a Windows 10 OS). Worth a try?
          • dinosglxaros
            • Nov 2016
            • 55
            • greece
            #65
            I also tried without quick format.. I am still waiting to find onother flash drive
            • lotas
              • Jan 2016
              • 4598
              • Russia
              #66
              Try another option (sometimes it helps), turn on the TV, as soon as the diodes flash, wait 20-30 seconds. and after that insert the usb flash into the TV, the update should go.
              • dinosglxaros
                • Nov 2016
                • 55
                • greece
                #67
                Ok I will try that thank you..
                • dinosglxaros
                  • Nov 2016
                  • 55
                  • greece
                  #68
                  Hello i come back to this TV after a long time. I think the problem is that a have an italy(EIA) version of a batv board that i bought from italy and according the manual they use different firmware from EUA and i cant find anywhere the firmware(EIA) for italy, does anyone have it?
                  • dkneyle
                    Sony KDL-46HX850 Can't upgrade/update firmware
                    by dkneyle
                    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                    09-25-2024, 10:44 PM
                  • TheUser
                    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                    by TheUser
                    Hello to everyone ,
                    This is my first post here, and i would like to share with you a small story in case you can help me.
                    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                    02-10-2024, 02:07 PM
                  • madyoyo
                    Sony KDL60w685a need firmware update
                    by madyoyo
                    Hello everyone.
                    I replaced the mainboard on a KDL60w685a, and now it blinks green and yellow. I think i need to update the firmware. But it's not available from Sony website.
                    Does anyone have the firmware for this TV?
                    01-06-2023, 01:41 PM
                  • thesteve
                    Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
                    by thesteve
                    So I bought another main board from eBay and the same thing happened.
                    I got the firmware file from the Sony website. My model was listed and everything matched.
                    sony_tvupdate_2011_4027_aaa_auth.zip was the file.
                    Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
                    with file: 00000301_07e8046a.bin inside.
                    Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
                    The file reads perfectly. Lots of "disk activity"...
                    07-17-2021, 04:59 PM
                  • rumpumpel1
                    ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
                    by rumpumpel1
                    Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
                    10-24-2024, 08:59 AM
