Sony kdl 40ex720 firmware update
  • dinosglxaros
    • Nov 2016
    • 57
    • greece
    #81
    Originally posted by nippur2
    A big thank you for all!
    That was the problem: I copied only the file not the folder. And also a good news that, I reformatted my 4GB chinese led stick with RUFUS to MBR partition and USB update went down easily immediately, so doesn't need special low capacity stick for it.
    PS: So far I have done many USB update, but almost all need to copy the (bin, pkg, etc.) file to root, not the folder. This is exception.
    After a long time with no luck for me, from your success a started digging about that problem again. I tried what you suggested but for me still nothing. Can you please give us the exact procedure how do to the update? Thank you in advance!
    • nippur2
      • Sep 2022
      • 5
      • Hungary
      #82
      As you can read above I made the update a chinese 4GB MBR FAT32 stick. Copied the above folder into its root, and attached it to the TV in power off. Pushed the connector to the mains, the TV was in out of order state. Then I pushed power+source together on TV tast, and then started to blinking Y-G led and the stick too, it started update immediately. If stick blinking continously Wait for long time. I think it restarted 2 times and finally started with baclight and normal working.
      (I think the most important that the TV let in Y-G blinking state, the update will start if usb attached before or later.)
      • dinosglxaros
        • Nov 2016
        • 57
        • greece
        #83
        So i have to put the folder with the file inside on the root of the usb stick or just the bin file?
        • nippur2
          • Sep 2022
          • 5
          • Hungary
          #84
          YES (folder name: sony_dtv0FA10A01A0A1_00000100)
          • saeed mogadamy
            • Aug 2025
            • Iran
            #85
            sony tv frimvare 40ex720 (PKG4.027GAA) For Asia Pacific
            can send me this file
            • saeed mogadamy
              • Aug 2025
              • Iran
              #86
              no everyone have this file?
              please
              • lotas
                • Jan 2016
                • 4752
                • Russia
                #87
                Here is your firmware in Telegram
                https://t.me/fileres/7515
                • saeed mogadamy
                  • Aug 2025
                  • Iran
                  #88
                  but this is for 32ex420
                  my tv is 40ex720
                  is same?
                  • lotas
                    • Jan 2016
                    • 4752
                    • Russia
                    #89
                    my tv is 40ex720
                    is same?
                    There is no difference here, they have the same firmware, it is common for this chassis.
                    • saeed mogadamy
                      • Aug 2025
                      • Iran
                      #90
                      thx alot i updated with your file
                      this 40ex720 cannot find digitad hd channels?
                      • lotas
                        • Jan 2016
                        • 4752
                        • Russia
                        #91
                        Motherboards for different regions can be equipped with different tuners...
                        • dkneyle
                          Sony KDL-46HX850 Can't upgrade/update firmware
                          by dkneyle
                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                          09-25-2024, 10:44 PM
                        • madyoyo
                          Sony KDL60w685a need firmware update
                          by madyoyo
                          Hello everyone.
                          I replaced the mainboard on a KDL60w685a, and now it blinks green and yellow. I think i need to update the firmware. But it's not available from Sony website.
                          Does anyone have the firmware for this TV?
                          01-06-2023, 01:41 PM
                        • thesteve
                          Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
                          by thesteve
                          So I bought another main board from eBay and the same thing happened.
                          I got the firmware file from the Sony website. My model was listed and everything matched.
                          sony_tvupdate_2011_4027_aaa_auth.zip was the file.
                          Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
                          with file: 00000301_07e8046a.bin inside.
                          Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
                          The file reads perfectly. Lots of "disk activity"...
                          07-17-2021, 04:59 PM
                        • ahmedtou
                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                          by ahmedtou
                          help me please
                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                          I will share all the details with you, including the disc information.
                          Code:
                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                          Current Profile: BD-R
                          Disc Information:
                          Status: Empty
                          State of Last Session: Empty
                          Erasable: No
                          Free Sectors: 12,219,392
                          Free Space: 25,025,314,816 bytes
                          Free Time: 2715:27:17 (MM:SS:FF)
                          Next
                          08-27-2025, 08:49 AM
                        • TheUser
                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                          by TheUser
                          Hello to everyone ,
                          This is my first post here, and i would like to share with you a small story in case you can help me.
                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                          02-10-2024, 02:07 PM
