Sony kdl 40ex720 firmware update
  • lotas
    • Jan 2016
    • 4753
    • Russia
    Re: Sony kdl 40ex720 firmware update
    You have that the backlight is not working, you can insert the cable back when error 5 appears.
    • dinosglxaros
      • Nov 2016
      • 57
      • greece
      You mean if I plug back the lvds cable when error 5 appears I am gonna have backlight?
      • dinosglxaros
        • Nov 2016
        • 57
        • greece
        Originally posted by lotas
        Try disconnecting the LVDS cable from T_CON and turning on the TV, when the backlight turns on without turning off the TV, insert the cable carefully back quickly and without distortions, an image should appear, reset and update via usb. Do you have firmware PKG4.027EUA?
        yes i have that firmware
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4463
          • Italy - Milan
          To Lotas, if the tv shows an error code i think is in standby protected mode, it can't turn back to On mode.. To Dino: alternating green-yellow is typical of Sony when detected an hardware pairing change between mb<>tcon, you need to find the key conbination to force update, since tv is already updated it normally refuses updating... have you read the service manual?
          • dinosglxaros
            • Nov 2016
            • 57
            • greece
            Yes I saw the service manual and I read that you can't update if it has the latest firmware but I I didn't find anything about force update.. Do you know the key combination for the force update?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4463
              • Italy - Milan
              #26
              no i was meaning the reset procedure
              • dinosglxaros
                • Nov 2016
                • 57
                • greece
                #27
                And how can do that please?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4463
                  • Italy - Milan
                  #28
                  i don't have the manual on the tablet, don't have wish to watch non the pc.. for now
                  • dinosglxaros
                    • Nov 2016
                    • 57
                    • greece
                    #29
                    Ok i will check the manual thank you
                    • lotas
                      • Jan 2016
                      • 4753
                      • Russia
                      #30
                      When it enters recovery mode, it doesn't matter to it what firmware you installed on usb, as long as it is not lower than the one that is currently installed. How do you prepare usb flash for upgrade?
                      • dinosglxaros
                        • Nov 2016
                        • 57
                        • greece
                        #31
                        I format it to fat32 and I unzip the folder to the root of the flash drive as the manual says.
                        • lotas
                          • Jan 2016
                          • 4753
                          • Russia
                          #32
                          Try it - the firmware file itself is "00000100_07e8046a.bin" (without folders). And without quotes.
                          • dinosglxaros
                            • Nov 2016
                            • 57
                            • greece
                            #33
                            I try it but no luck
                            • lotas
                              • Jan 2016
                              • 4753
                              • Russia
                              #34
                              There is another option, do you have a good command of a soldering iron for smd components?
                              • dinosglxaros
                                • Nov 2016
                                • 57
                                • greece
                                #35
                                Yes I can solder smd components
                                • lotas
                                  • Jan 2016
                                  • 4753
                                  • Russia
                                  #36
                                  I understand from your topic that you replaced the T-con board, I hope the old T-Con board remained (what happened with the old board and which one you changed to (diagonal, model ..). Write in detail your actions.
                                  • dinosglxaros
                                    • Nov 2016
                                    • 57
                                    • greece
                                    #37
                                    No sorry maybe I didn't explain well.. I replace the batv board not the tcon board
                                    • lotas
                                      • Jan 2016
                                      • 4753
                                      • Russia
                                      #38
                                      Then this option, which I wanted to offer, will not help (I thought it was T-con), then only an update via usb.
                                      And can you buy a native T-con, where did you get the motherboard? Or he had a different diagonal.
                                      • dinosglxaros
                                        • Nov 2016
                                        • 57
                                        • greece
                                        #39
                                        What do you mean a native tcon? I bought a used batv board from 46ex720 tv not for the 40 inches one that I have.
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4463
                                          • Italy - Milan
                                          #40
                                          he means the tcon originally mounted in the same tv where the spare mb came from..
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                          • madyoyo
                                            Sony KDL60w685a need firmware update
                                            by madyoyo
                                            Hello everyone.
                                            I replaced the mainboard on a KDL60w685a, and now it blinks green and yellow. I think i need to update the firmware. But it's not available from Sony website.
                                            Does anyone have the firmware for this TV?
                                            01-06-2023, 01:41 PM
                                          • thesteve
                                            Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
                                            by thesteve
                                            So I bought another main board from eBay and the same thing happened.
                                            I got the firmware file from the Sony website. My model was listed and everything matched.
                                            sony_tvupdate_2011_4027_aaa_auth.zip was the file.
                                            Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
                                            with file: 00000301_07e8046a.bin inside.
                                            Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
                                            The file reads perfectly. Lots of "disk activity"...
                                            07-17-2021, 04:59 PM
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                          • TheUser
                                            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                            by TheUser
                                            Hello to everyone ,
                                            This is my first post here, and i would like to share with you a small story in case you can help me.
                                            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                            02-10-2024, 02:07 PM
