Sony kdl 40ex720 firmware update
  • dinosglxaros
    • Nov 2016
    • 57
    • greece
    Hello can you please tell me the exact steps for updating the tv after logic board replacement.. I try everything I can find online but no luck. I have green and amber light blinking.. thank you in advance
  • nomoresonys
    • 12276
    • U.S.
    Re: Sony kdl 40ex720 firmware update
    put your model in there, check downloads, they may have made it no longer available in January 2022: https://www-sony-gr.translate.goog/e...n&_x_tr_pto=sc
    • dinosglxaros
      • Nov 2016
      • 57
      • greece
      Yes sony stop the support for firmware download for this tv.. I find the firmware from various sites and I tried many of them but with no luck. But I don't think is the firmware file the problem but the procedure I am taking to update the tv
      • lotas
        • Jan 2016
        • 4752
        • Russia
        The firmware must be PKG4.027EUA, unpacked on usb flash (old, not large 512Mb -1Gb), not all flash drives are suitable, you need to select it.
        • dinosglxaros
          • Nov 2016
          • 57
          • greece
          Ok i didn't do it with a small flash drive I will give it try and I will tell you the results thank you!
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4460
            • Italy - Milan
            do this: rename file on the usb drive folder as: upgrade_loader.pkg, use a usb drive with led light, then put the key on the unplugged tv, now keep pressed power key and plug tv in mains socket, watch if a light will glow, wait for the key light to stop blinking, remove mains plug, wait 10 sec. then plug back, press power on tv, watch if something blinks on tv, when all leds stops blinking turn on tv..
            • dinosglxaros
              • Nov 2016
              • 57
              • greece
              Ok thank you I will try with that sequence.. but the only firmwares I can find are in .bin format
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4460
                • Italy - Milan
                it doesn't matter, you have to rename in fact
                • dinosglxaros
                  • Nov 2016
                  • 57
                  • greece
                  I used an 1gb flash drive and I tried all the information u give me but still the same thing.. when I power on the TV the flash drive flashes for two seconds and then stops and the TV keeps flash amber and green.. do I have to wait longer for the usb drive start flashing again to read the software?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4460
                    • Italy - Milan
                    ok i suspected it because its a method for newer Sony , i remember there was many versions of service manual for that series on electrotanya.com , one of those was filled with info on how to use service menus , and other servicing infos
                    • dinosglxaros
                      • Nov 2016
                      • 57
                      • greece
                      Ok I will check and I will report back thank you
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4460
                        • Italy - Milan
                        there was a reset procedure..
                        • dinosglxaros
                          • Nov 2016
                          • 57
                          • greece
                          Do you know how to do that?
                          • nomoresonys
                            • 12276
                            • U.S.
                            Listen to Lotus, try another small flash drive, sonys can be fussy.
                            • dinosglxaros
                              • Nov 2016
                              • 57
                              • greece
                              Ok I will try to find onother one
                              • dinosglxaros
                                • Nov 2016
                                • 57
                                • greece
                                I try every usb flash I can find still nothing..I think the problem its somewhere else.. the story is that I had this tv with double picture and I thought that it was a logic board issue and ruined the cpu on the board.. so then I thought its a tcon problem and I order onother logic board (same model number like the old one but for 46ex720 tv)and when I plug the mains and by pressing the power button on the TV i have immediately green and amber flashing light.. can the tcon with a minor problem cause the TV not to update? Please help me to revive my tv
                                • lotas
                                  • Jan 2016
                                  • 4752
                                  • Russia
                                  Try disconnecting the LVDS cable from T_CON and turning on the TV, when the backlight turns on without turning off the TV, insert the cable carefully back quickly and without distortions, an image should appear, reset and update via usb. Do you have firmware PKG4.027EUA?
                                  • dinosglxaros
                                    • Nov 2016
                                    • 57
                                    • greece
                                    When I disconnect the lvds cable I get 5 red blinks indicating tcon error.
                                    • lotas
                                      • Jan 2016
                                      • 4752
                                      • Russia
                                      I know that the error will be "5" - T-CON error, did you then try to insert the LVDS cable back without turning off the TV?
                                      • dinosglxaros
                                        • Nov 2016
                                        • 57
                                        • greece
                                        No I didn't because I had no backlight.
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                        • madyoyo
                                          Sony KDL60w685a need firmware update
                                          by madyoyo
                                          Hello everyone.
                                          I replaced the mainboard on a KDL60w685a, and now it blinks green and yellow. I think i need to update the firmware. But it's not available from Sony website.
                                          Does anyone have the firmware for this TV?
                                          01-06-2023, 01:41 PM
                                        • thesteve
                                          Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
                                          by thesteve
                                          So I bought another main board from eBay and the same thing happened.
                                          I got the firmware file from the Sony website. My model was listed and everything matched.
                                          sony_tvupdate_2011_4027_aaa_auth.zip was the file.
                                          Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
                                          with file: 00000301_07e8046a.bin inside.
                                          Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
                                          The file reads perfectly. Lots of "disk activity"...
                                          07-17-2021, 04:59 PM
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                        • TheUser
                                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                          by TheUser
                                          Hello to everyone ,
                                          This is my first post here, and i would like to share with you a small story in case you can help me.
                                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                          02-10-2024, 02:07 PM
